Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum > Western Canada
Old 08-11-2006, 01:11 PM   #1
Blew.by.u
Member#: 111513
06 STi APS SR56
CGM RocketRally Tuned
Default Can I remove my back seat without a chainsaw?
OK…Cobb Stage 2 suspension kit is installed, front stabilizer bar is very time consuming, back is some what easy…BUT I have the rear strut tower brace to install now and I have no clue how to access the rear strut towers. The instructions are in Chinese LITURALLY and there are no diagrams. My assumption is I need to remove my back seat but I don’t know where to start…who has done this maneuver and any suggestions would be appreciated.
Thank you
Matt
Blew.by.u is offline   Reply With Quote
Old 08-11-2006, 01:22 PM   #2
Zuffy
Member#: 35268
2004 WRX Stg2 & with
added PDX goodness
Removing the back seat is super easy. I've done it dunno how many times now.
1: First remove the two bolts (10mm I think) right below the seat cushion. The seat cushion is secured by these two bolts.
2: Pull out the seat cushion and remove from car. This will reveal the 4 bolts that secure the seat back. These bolts are at the bottom of the seat back, two in the middle, and one on either side by the seat belts. Remove these bolts. (also 10mm I think.)
3: Move the seat belts to the sides of the seat back so you have room to pull up on the seat back to unhook it from the car and pull out the seat back. Oh, make sure the pass through is secured and it the upright position. Voila, done!
Zuffy is offline   Reply With Quote
Old 08-11-2006, 03:01 PM   #3
cringeR
Member#: 80100
2008 STi
SSM
Everything Zuffy said is correct, but the bolts are 12mm, not 10mm
cringeR is offline   Reply With Quote
Old 08-11-2006, 03:23 PM   #4
Blew.by.u
Member#: 111513
06 STi APS SR56
Success! Thank you and yes..12mm
I would have to say PERSONALY, the suspension upgrade has been my greatest mod....wow is the car tight now!!! Lowered and tight, just the way I like them!
Speed is good, handling is better!
Old 08-11-2006, 05:15 PM   #5
Flexx999
Member#: 36302
2006 Big 16G WRX
Addicted to Blue
cool that you got it...I was just going to add when your taking the seat back off make sure you push up first and not just try to pull it straight out.
Flexx999 is offline   Reply With Quote
Old 08-11-2006, 08:48 PM   #6
RexSex
Member#: 79088
2004 300hp WRX
I would also suggest buying the "Rear Subframe Locking Bolts" ...Whiteline makes them (I have a pair but Im putting them back on my car). They are about $30 and worth every penny. They lock down the rear of the car, so it doesn't move side to side as much. I loved that mod. Cheap and significant.
Install is just a matter of screwing them in (you will need an airgun tho...so go to a mechanic's).
RexSex is offline   Reply With Quote
Old 08-11-2006, 11:41 PM   #7
Nanners
Member#: 66306
2001 2.5 RS Sedan
BRP
Did you have to remove the seatbelt tensioner's? and was there any wiring run directly over the strut top like on my rs?
Nanners is offline   Reply With Quote
Old 08-12-2006, 04:12 AM   #8
RexSex
Member#: 79088
2004 300hp WRX
Yes, there is wiring running over the struts, but they can be moved aside easily. Also, yes, you have to remove the seatbelt tensioners, since the ends of the strut bar need to be angled in, and the tensioners are in the way.
Old 08-12-2006, 02:07 PM   #9
markus
Member#: 438
2004 STi
White on Gold
Zuffy would know how to do the seats, because half the time I see him, they aren't installed.
markus is offline   Reply With Quote
Old 08-12-2006, 05:38 PM   #10
Zuffy
Member#: 35268
added PDX goodness
Hehehe, yah the car is so much louder without the sound deadening of the seat. BTW, Markus I thought yours was got too?
Yah, you would think I would remember having removed those stupid things so much...
Old 08-13-2006, 01:34 AM   #11
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
man I could do it in 5 min, back seat is uber easy....zuffy has it right
Chp_Stix is offline   Reply With Quote
How to remove WRX back seat?? DarkShadow Car Audio, Video & Security 10 04-02-2007 03:06 PM
How do i remove the back seat? AlbanianImpreza Interior & Exterior Modification 2 05-13-2006 01:25 PM
How to remove the back seat? Barok'sWrX Newbies & FAQs 1 03-18-2003 02:15 AM
If you remove the back seats.... -JB- General Community 7 12-18-2001 03:40 AM
