Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 08-11-2006, 06:18 PM   #1
RavSpec
NASIOC Storefront Vendor
Vendor Sales Rating: (88)
Member#: 26854
2002 Impreza
WRX
Default Fujitsubo, Walbro, Koyo, Samco, Wiseco, PE, Sard, HKS, Apexi, Greddy
Greddy EVO2 Cat Back System (WRX) - $559.00 shipped
Greddy EVO2 Cat Back System (STI) - $559.00 shipped
Invidia Non-polished Downpipe For 02~05 WRX/STI - $279.00 shipped
Invidia Divorce Wastegate Downpipe For 02~06 WRX/STI - $319.00 shipped
Invidia Catted Downpipe For 02~06 WRX/STI - $559.00 shipped
Apex-i N1 Cat Back System For 02+ WRX/STI - $539.00 shipped
Apex-i GT SPEC Cat Back System For 02+ WRX/STI - $699.00 shipped
HKS Hi Power Cat Back System For 02+ WRX/STI - $539.00 shipped
ZERO/Sport World League Cat Back System For 02+ WRX/STI - $799.00 shipped
ZERO/Sport Twin Spool Downpipe With Cat- $699.00 shipped
Tomei Twin Spool Downpipe (non-cat) - $499.00 shipped
GTSPEC Twin Spool Header With Uppipe- $699.00 shipped
Some Spec on Fujitsubo System:
Fujitsubo has been the leading exhaust manufacture in Japan. Their system are the most quiet and have a deep tone to it. Their system put out are around 85 to 93 dB at 5000 RPM and around 85 to 89 dB at idle. Fujitsubo also are one of the few company that offer one piece cat back system !!! RM01A is their famous one piece cat back system. Most cat back in the market are two piece. If you need a sound clip, email me !!! [email protected]
Fujitsubo Power Getter Cat Back System For USDM WRX/STI :
- PM For Best Price ! (in stock)
- Weight: 12.9 kg (28 lbs)
- 3.5" piping
- Fit fit any US Spec downpipe !!!
- email me for sound / video clip !!!
- in stock for immediate Delivery !!!
- >> More Info <<
Fujitsubo RM01A One Piece Cat Back System For USDM 02~05 WRX/STI
- Weight: 11.6 kg (26 lbs)
- 3.0" piping
- 87 dB Only !!
- >> More Info <<
Fujitsubo Legalis-R Cat Back System For USDM WRX/STI :
- PM For Best Price ! (Special Order)
- Weight: 14.5 kg (31 lbs)
- 85 dB
- 3.0" piping
- >> More Info <<
Fujitsubo Super EX Header For USDM WRX/STI (header only)
- PM for Price(in stock)
- Weight: 5.4 kg
- Equal Length (w/o Upipe)
- >> More Info <<
RavSpec is offline
Old 08-11-2006, 06:19 PM   #2
RavSpec
Member#: 26854
2002 Impreza
WRX
**** INTAKE SYSTEM ****
- ZERO/SPORT Intake Pipe Kit - $99 Shipped
- ZERO/SPORT Intake Kit - $234 Shipped
- HKS Intake Kit - $119 Shipped
- Greddy Airnix Intake Kit - $139 Shipped
- Injen Intake Kit - $199 Shipped
FUJITA Short Ram Air Intake System With Shield - $277 Shipped
FUJITA Cold Air Intake System With Shield - $277 Shipped
FUJITA Cold Air Intake System W/O Shield (Red)- $269 Shipped
RavSpec is offline
Old 08-11-2006, 06:21 PM   #3
RavSpec
Member#: 26854
2002 Impreza
WRX
PE-1820F With Actuator (A/R 20 Housing)- $1599.99 Shipped
Comes with separative actuator. Running A/R 20 housing. Ball bearing turbo. This turbo allow you hit 350 to 360 WHP. Stock bolt on to 02+ WRX/STi. Full boost at 3800 RPM.
TD05H-16G Stock Bolt On Turbo (350 HP)- $799.99 Shipped
The TD05H-16G is a bolt-on upgrade for the WRX/STI utilizing a Mitsubishi TD05 16G compressor wheel in a TD05 compressor housing capable of supporting 350 HP maximum. The turbine section consists of a Mitsubishi TD05H high flow turbine wheel and shaft assembly and a 7cm 2 nozzle area turbine housing with an internal wastegate port and wastegate actuator calibrated at 9 PSIG. The center housing contains a water jacket and comes complete with coolant pipes installed. Optional actuators are available for this turbocharger in pressures ranging from 10 to 19 PSIG
we will also included the uppipe to turbo and downpipe to turbo gasket
TD05H-EVO III 16G Stock Bolt On Turbo (395 HP)- $999.99 Shipped
The TD05H-EVO III Big 16G is a bolt-on upgrade for the WRX/STI utilizing a Mitsubishi TD05 EVO III Big 16G compressor wheel in a TD05 compressor housing capable of supporting 395 HP maximum. The turbine section consists of a Mitsubishi TD05H high flow turbine wheel and shaft assembly and a 7cm 2 nozzle area turbine housing with an internal wastegate port and wastegate actuator calibrated at 9 PSIG. The center housing contains a water jacket and comes complete with coolant pipes installed. Optional actuators are available for this turbocharger in pressures ranging from 10 to 19 PSIG.
TD05H/TD06 -18G or - 20G Stock Bolt On Turbo (400~440 HP)- $1199.99 Shipped
The TD05H-18G or -20G is a bolt-on upgrade for the WRX/STI utilizing a Mitsubishi TD06 18G compressor wheel in a TD06 compressor housing capable of supporting 400 HP to 450 HP maximum. The turbine section consists of a Mitsubishi TD05H turbine wheel and shaft assembly and a 7cm 2 nozzle area turbine housing with an internal wastegate port and wastegate actuator calibrated at 9 PSIG. The turbine housing is ported and polished in the turbine inlet throat and wastegate port areas to improve exhaust gas flow and boost control via the internal gate. The center housing contains a water jacket and comes complete with coolant pipes installed. Optional actuators are available for this turbocharger in pressures ranging from 10 to 19 PSIG.
TD06H-20G - Bolt On WRX/STi (440 HP)- $1399.99 Shipped
The TD06H-20G is a bolt-on upgrade for the WRX/STI utilizing a Mitsubishi TD06 20G compressor wheel in a TD06 compressor housing capable of supporting 440 HP maximum. The turbine section consists of a Mitsubishi TD06H high flow turbine wheel and shaft assembly for maximum HP potential at high RPM on the 2.5L and a 7cm 2 nozzle area turbine housing with an internal wastegate port and wastegate actuator calibrated at 9 PSIG. The turbine housing is ported and polished in the turbine inlet throat and wastegate port areas to improve exhaust gas flow and boost control via the internal gate. The center housing contains a water jacket and comes complete with coolant pipes installed. Optional actuators are available for this turbocharger in pressures ranging from 10 to 19 PSIG.
BT Dominator I Garret Turbo Charger - Bolt On WRX/STi (480 HP)- $1599.99 Shipped
The Dominator I performance turbocharger is a bolt-on upgrade for the WRX/STI utilizing a proprietary Garrett T04E compressor wheel in a Mitsubishi TD06 compressor housing capable of supporting 480 HP maximum. The turbine section consists of a Mitsubishi TD06H high flow turbine wheel and shaft assembly and a 7cm 2 nozzle area turbine housing with an internal wastegate port and wastegate actuator calibrated at 9 PSIG. The turbine housing is ported and polished in the turbine inlet throat and wastegate port areas to improve exhaust gas flow and boost control via the internal gate. The center housing contains a water jacket and comes complete with coolant pipes installed. Optional actuators are available for this turbocharger in pressures ranging from 10 to 19 PSIG.
Zerosport Twin Spool Turbo (A/R 25) - Similar to PE1825- $2199.99 Shipped
This is the same turbo as the PE1825. As opposed to the single-exhaust entry turbine housing on the previous GDB model, the newer JDM GDB STi has the twin-entry, designed for smoother exhaust gas entry to the turbine housing without having exhaust interference. Torque and response at low to mid range are drastically improved by utilizing the ball bearing and the compressor wheel of big 70pai easily supports monstrous 400+ps of power all the way to the high RPM range.
****** Twin Spool Turbo Upgrade "KIT" ******
Zerosport Twin Spool Turbo Kit For 02+ WRX/STI - $3399 shipped
- Zerosport Twin Spool Turbo
- Walbro GSS-342, (255 L/H) Fuel Pump
- PE 800 cc Injectors For WRX or PE850 For STI
- Tomei Twin Spool Downpipe (JDM Length)
- GTSPEC Twin Spool Header and Uppipe
- All Required Gasket
- STI Oil Pan (only WRX are required)
RavSpec is offline
Old 08-11-2006, 06:22 PM   #4
RavSpec
Member#: 26854
2002 Impreza
WRX
For over 60 years Wiseco has been manufacturing the finest aftermarket forged pistons & performance parts for the snowmobile, motorcycle, ATV, personal watercraft, outboard marine, karting and automotive markets.
1. Valve Pocket designs that allow maximum flow around valve, also allowing oversized valves and high lift cams to be utilized.
2. 2618 extruded material forged for the maximum strength available.
3. High quality piston rings featuring alloy steel contrusction on top ring, cast iron taper faced 2nd, and 3PC oil assembly utilizing atainless expander and carbon steel rails.
4. Wrist Pins constructed of chrome moly steel material for ultimate in strength.
5. No wait time, most piston are available in stock.
********** AVAILABLE APPLICATION **********
- 92.0 mm Stock Bore For EJ20 Engine - $499.99 shipped
- 92.5 mm (0.5 mm / .020) Over Bore For EJ20 Engine - $499.99 shipped
- 93.0 mm (1.0 mm / .040) Over Bore For EJ20 Engine - $499.99 shipped
- 99.0 mm Stock Bore For EJ257 Engine (STI) - $499.99 shipped
- 100.0 mm (0.5mm / .020) Over Bore For EJ257 Engine (STI) - $499.99 shipped
ARP Head Studs Kit For EJ207/EJ257 Engine - $219.99 shipped
Eagle Forged Rods For EJ20/EJ257 Block- $399.99 shipped
RavSpec is offline
Old 08-11-2006, 06:23 PM   #5
RavSpec
Member#: 26854
2002 Impreza
WRX
Koyo Aluminum Radiator For WRX (02~03)- $399.99 shipped
Koyo Aluminum Radiator For WRX / STI (04~05)- $399.99 shipped
Samco 3 Piece Intercooler Hose Kit For WRX - $109.99 shipped
(blue, red and black)
Samco 4 Piece Turbo Hose Kit For WRX / STI - $109.99 shipped
Samco 2 Pieces Coolant Hose Kit For WRX/STI - $109.99 shipped
Samco 7 Pieces Ancilliary Hose Kit For STI (2.5 L) Only - $149.99 shipped
Samco 9 Piece Ancilliary Hose Kit For WRX (2.0 L) Only - $139.99 shipped
Samco 1 Piece Intake Box Hose Kit For WRX /STI (76mm) - $69.99 shipped
***** Injectors (WRX and STI) *****
- PE 800 cc Injector For 02~05 WRX (Top Feed) - $559 shipped
- PE 850 cc Injector For 04~06 STI (Side Feed) - $559 shipped
- STI Pink Top Feed Injector For 02~05 WRX Only (Top Feed)- - $375 shipped
- SARD 650 CC Injector For 02~05 WRX Only (Top Feed)- - $429 shipped
- Walbro GSS 342 Fuel Pump Only - $79 shipped
- Walbro GSS 342 Fuel Pump + Filter/Install Kit - $89 shipped
- Walbro GSS 341 Fuel Pump + Filter/Install Kit - $89 shipped
WEB: www.ravspeconline.com
Email: [email protected]
TEL : 631-586-3520 / 631-964-0032
RavSpec is offline
Old 08-11-2006, 06:32 PM   #6
RavSpec
Member#: 26854
2002 Impreza
WRX
JDM VER 8 STI Complete Clip
We have the complete Ver 8 STi engine here and doing a part out special for them !! Here is a list of what we have. Call us or PM us if any questions !
1. JDM Ver 8 STI Complete Engine - $6500 + Shipping
Including Bulkhead Harness, Fuse Box, ECU, intake manifold, complete wiring
2. 6 Speed DCCD Tranny - $5000 + Shipping
Including DCCD, Switch, Rear Axles, Rear Different
3. Twin Spool VF37 Turbo - SOLD
Including Stock Header and Uppipe
Optional Downpipe Available (Zerosport Catted or Tomei Non-Catted)
4. Intercooler - SOLD
RavSpec
TEL: 631-586-3520
RavSpec is offline
Old 08-15-2006, 08:58 PM   #7
sti_element
Member#: 111174
2015 STi Limited
Crystal White Pearl
Default Twin spool
Does the 06 STi require oil pan to make this kit work? Will this kit work with APS DR725 FMIC and will the new downpipe mate with the APS 3.5 TB? What RPMs for full boost can I expect? Will the APS headers mate to the kits uppipe? Thanks...I'm seriously intrested in the twinspool setup for autocrossing.
sti_element is offline
Old 08-16-2006, 11:23 AM   #8
RavSpec
Member#: 26854
2002 Impreza
WRX
We haven't try on 06 STI yet, but i assume you don't need the oil pan. Yes it will mate with APS DR725 , we have tried that !
Downpipe will not mate to APS directly, need modification ! APS is USDM length, while the downpipe is JDM length. It will be 3000 full boost, but it really depend on tunning, but expect to be at 3000 range.
APS header might mate with the uppipe , but we haven't try it yet.
RavSpec is offline
Old 08-16-2006, 04:55 PM   #9
sti_element
Member#: 111174
2015 STi Limited
Crystal White Pearl
Is the downpipe made by zerosport and what is diameter of pipe. What do you suggest as a good sounding exhaust that will mate to downpipe. Looking for something quieter than aps 3.5.
Old 08-18-2006, 10:21 AM   #10
RavSpec
Member#: 26854
2002 Impreza
WRX
fujitsubo is a great exhaust, mate with the Zsport w/o problem !! Yes DP is by Zsport ! or other option, Tomei if u want !
RavSpec is offline
Old 09-02-2006, 12:13 AM   #11
RavSpec
Member#: 26854
2002 Impreza
WRX
bump .......
RavSpec is offline
Old 09-06-2006, 12:41 AM   #12
RavSpec
Member#: 26854
2002 Impreza
WRX
quick bump
RavSpec is offline
Old 09-06-2006, 12:59 PM   #13
whitson01
Member Sales Rating: (4)
Member#: 100776
2004 sti
white
i didnt know that gt spec made a twin scroll header..? is it equal length? could you post a pic?
also who are the makers of the td06/20g turbos you have up top? thanks
whitson01 is offline
Old 09-06-2006, 01:20 PM   #14
RavSpec
Member#: 26854
2002 Impreza
WRX
whitson01:
yes they did , it's mainly for the Europe and Japanese market. They have it since 2005. Only small amount of the headers circulate in USA market due to the less popular twin spool turbo in US market !
If you , send me an email , i will send you some pictures of the header. They are two version, one with flex joint and one without flex joint. Both version are equal length !
TD06/20G is make by Blouch Turbo.
RavSpec is offline
Old 09-07-2006, 07:28 AM   #15
dtseng01
Member Sales Rating: (3)
Member#: 105323
2005 Impreza WRX STi
Does the Fujitsubo silencer rattle? Beause I used to have a Blitz NurSpec and the inner silencer would always rattle, and I'd have to tighten the bolt once every three days until one day the silencer broke.
dtseng01 is offline
Old 09-07-2006, 11:30 AM   #16
RavSpec
Member#: 26854
2002 Impreza
WRX
dtseng01: fujitsubo doesn't use a silencer !
RavSpec is offline
Old 09-08-2006, 05:49 AM   #17
hanzo918
Member Sales Rating: (17)
Member#: 82148
1992 Daihatsu
Charade
Are the Sard top feed injectors high or low impedance?
hanzo918 is offline
Old 09-08-2006, 02:32 PM   #18
RavSpec
Member#: 26854
2002 Impreza
WRX
these are high impedance , basically make by the same manufacture (Denso) as Power Enterprise
RavSpec is offline
Old 09-08-2006, 11:11 PM   #19
RavSpec
Member#: 26854
2002 Impreza
WRX
more Fujitsubo in stock !!!!
RavSpec is offline
Old 09-09-2006, 10:44 PM   #20
coolray
Member#: 36618
1984 project justy
wrb
hi
any samco turbo inlet hose in stock?
coolray is offline
Old 09-10-2006, 10:36 PM   #21
Hyper
Member Sales Rating: (31)
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
do you have/can get any 105mm piston rings?
Hyper is offline
Old 09-11-2006, 11:30 AM   #22
RavSpec
Member#: 26854
2002 Impreza
WRX
Hyper: nope, biggest i got is 100 mm ! what kind of piston are you running ?
coolray: got blue, black and red in stock !!
Mark.
RavSpec is offline
Old 09-11-2006, 11:41 AM   #23
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
big
we are building N/A monster
I think weisco had this diameter ring in their catalogue, no?
Hyper is offline
Old 09-11-2006, 12:56 PM   #24
RavSpec
Member#: 26854
2002 Impreza
WRX
wiseco only make 100 mm piston for Subaru. I might be able to get you non-subaru spec piston ring at 105 mm from wiseco ! will that work for you ?
RavSpec is offline
Old 09-17-2006, 12:49 AM   #25
RavSpec
Member#: 26854
2002 Impreza
WRX
weekend bump !
RavSpec is offline
Closed Thread
All IN STOCK Electronics! Defi STRI HKS Apexi GReddy Cobb AEM MORE! Z1 Performance Interior/Dressup/Audio & Security 87 09-12-2008 05:16 PM
TXS/Apex'I/Greddy/Crower/Walbro/PE/Mahle/Wiseco/ARP/BC/Koyo/Samco! Match any price!!! Tuning Factory Inc. Engine/Power/Exhaust 195 10-06-2007 03:00 PM
All summer get an extra 5% off on HKS, Sard, Fujitsubo, Apexi, GReddy, Samco RavSpec Engine/Power/Exhaust 55 10-14-2005 12:45 PM
Super Spring Sale HKS, Apexi, GReddy, Blitz, Helix, IHI Gruppe-S Engine/Power/Exhaust 22 05-03-2005 08:35 PM
