Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 08-11-2006, 10:31 PM   #1
GenX'r
Member#: 121740
1997 Legacy GT Wagon
Dark Green
Question Best place to buy stock head gaskets?
I'm rebuilding the 2.5 in my 97 Legacy GT wagon and need to swap the heads from my old motor to the new motor, a 85k junkyard short block. Where's a good place to get stock parts on-line?
Also is there anything I should be on the look out for while it's this far apart?
The new block appears to be a phase II from what I've read here.
Thanks, New member
GenX'r is offline   Reply With Quote
Old 08-11-2006, 10:48 PM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
theres a HG kit for the phase I motor on ebay right now, but you need the SOHC hg kit......havent seen one of those on ebay yet. but i know that you can use the DOHC HG on the SOHC block. if you use the SOHC gasket, you will get a bump in compression ratio, not enough to make you run higher grade fuel though. replace all the seals. if you dont know the condition of the new shortblock, i would buy new piston rings, main and rod bearings and rebuild it. unless you need to have your car back on the road A.S.A.P.
~Josh~
Old 08-12-2006, 11:15 AM   #3
GenX'r
Member#: 121740
Dark Green
Do I need to get SOHC HG set even if the phase II motor had DOHC heads on it already? It's from a 97 outback and going into my 97 GT. I'll take a bump up in compression if I can get it. I'm thinking of throwing on some headers and possibly some mild cams, while I got it out.
Old 08-12-2006, 06:14 PM   #4
SubeTek
Member#: 1714
1999 RS-T COUPE
You need the phase 1 DOHC headgasket kit.
SubeTek is offline   Reply With Quote
Best place to buy new gaskets and bolts for Helix Downpipe? STiMUL8 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-31-2006 07:46 AM
Mac heads, where's the best place to buy a 17" G4? Undepelo Off-Topic 16 12-15-2005 12:46 PM
Best Place To Buy Gaskets? Urgent!! redeemedsoul Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 11-16-2005 08:00 PM
Best Place to Buy Gaskets Killian Maynard Private 'Wanted' Classifieds 2 12-03-2004 01:05 PM
Best place to buy stocks for short term $$ mrtrex Off-Topic 28 01-12-2004 05:15 PM
