#1 |
Member#: 51519
E. Canada
Vehicle:2000 SRP GF AKA Lilwgn |
Well i blew my 99 2.2L (phase 2 i think), so i bought an 97 EJ22 from a wrecked impreza. I tought they would have been the same motor, but when i received the motor, it didnt have the same valve cover on it.
So my 99 one is pulled out and i'm stuck there. Will the intake and wiring from my 99 fit on the 97 one? I know i'm losing like 10 hp by going from phase 2 to phase 1, but i need my car to run.... Any help is appreciated. I'm taking a rain break since i'm doing this in the street in front of my house Thanks
#2 |
Member#: 51519
E. Canada
k well it stoped raining for a little bit and i went to try to exchange the intakes from both engines and........... they dont fit. Just my luck
The 97 intake has alot of stuff that i dont have on my 99, so only changing the wiring from the other doesnt work. |
#3 |
Member#: 58329
Vehicle:97 Legacy GT Rio Red |
i thought phaseII started 97+
but another route is swaping blocks |
#4 |
Member#: 51450
NWIC
Vehicle:2004 FXT |
Phase II started in '99-- if they look different as you say, then you probably had a Phase II block in your Impreza (there was some overlap that year).
Bummer that it won't directly swap... what blew on your 2.2? Can you cannibalize parts from the '97 to fix your motor? |
#5 |
Member#: 62629
Vehicle:1996 OBS in Green 2.5 N/A w/ full exhaust |
Hmm...
#6 |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
Different valve covers and the intake manifold won't fit?
Check to make sure they didn't give you an EJ25.... Or maybe someone put Ej25 SOHC heads on an EJ22 block and they shipped it out not looking further..... Jay |
#7 |
Member#: 51519
E. Canada
The engine was out of a 97 impreza hit in the rear, so it's an EJ22 for sure. I toasted the bearings in one of the idler puleys of the timing belt at 140km/h, one head is good and the other probly has a few bent valves. It runned after i timed it back but REALLY ruff and had a clapping noise in the same head.
#8 |
Member#: 122875
Vehicle:1999 Impreza L Wagon Silver |
Your problem is deeper than that. I also have a 99 EJ22 Phase II (some came out in 1998, mostly in legacy's) and the problem is: the wiring is incompatable without canabalizing both harnesses, and getting an aftermarket computer to sort out all the remaining conflicts (of which there are a lot). It can be further complicated by the fact that some early phase II engines are OBD I and others are OBD II. If they are different OBD generations, you relly have a problem (this is all from personal experiance by the way.) I ended up just canabilizing what I could (restrict this to hard ware only, not electrics, and make SURE they are identical before commiting.) and sourcing out for what I couldn't (this may mean some new and fun experiance with japanese import parts is headed your way. I got lucky and didn't have to do that.) Tell me more specifics on your problem and I might be able to steer you away from cost and frustration.
#9 |
Member#: 51519
E. Canada
Well an idler pulley for the timing belt came out of the front of the engine. The right head read 225psi on both pistons, but the other one read around 100. I redid the timing twice and it still runs like a sewing machine.
I'm going out now to pull the bad head out to see whats wrong with it. |
#10 |
Member#: 51519
E. Canada
Took the bad head out this morning to find 2 bent valves. Why is there notches on the pistons if the valves can still hit the piston. Or is it normal of having 2 notches on the piston for each valves or did i f*^&up my pistons too?
Thanks to every1 whos is helping me in my moment of despair |
#11 |
Member#: 5218
PMd you about the pistons.
Jay Storm |
| Thread Tools | |
| Display Modes | |
| NEED help! 2.5RS in Central Jersey | pMak26 | Tri-State Area Forum | 9 | 06-04-2010 08:50 PM |
| Anyone need help with an install? | RubbleDTD | Mid Atlantic Impreza Club -- MAIC | 0 | 06-03-2010 05:23 AM |
| Need help from the guru's | noonagon | Factory 2.5L Turbo Powertrain | 2 | 10-01-2009 10:17 PM |
| guage q's need help | grndc2gsr | Newbies & FAQs | 12 | 04-11-2004 12:56 PM |
| Perl/cgi guru's? I need help with a Perl Script. | dsmperformance | Off-Topic | 4 | 11-11-2003 05:16 PM |
