Welcome to the North American Subaru Impreza Owners Club Saturday July 26, 2014
Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 08-12-2006, 03:41 PM   #1
topshotta10
Member#: 70218
2005 WRX sti 20g met
Default where is the outside temp sensor
anyone know where the sensor for the outside temp gauge is (this is the digital temp gauge in the tach of the sti). I have been getting very high readings that are not fully consistent with the outside temp, so I was just curious to know.
topshotta10 is offline   Reply With Quote
Old 08-12-2006, 03:50 PM   #2
flycaster
Member#: 60142
2011 WRX
Grey
If it's parked in the sun, this happens to mine as well - after a couple of minutes with ariflow, however, it seems to cool back down and do the job.
flycaster is offline   Reply With Quote
Old 08-12-2006, 04:02 PM   #3
waktasz
Member#: 86356
I'd like to replace the sensor and move it and make it either an intake temp sensor or oil temp or something. Think it can be done?
waktasz is offline   Reply With Quote
Old 08-12-2006, 04:12 PM   #4
SubeTek
Member#: 1714
1999 RS-T COUPE
It should be located in front of the radiator on the vertical support. Hope this helps.
SubeTek is offline   Reply With Quote
Old 08-12-2006, 04:14 PM   #5
UndertoW101
Member#: 100587
2012 WRX 5D Ltd.
Intake temp would be cooL...post some pics if you get this done.
Good luck
UndertoW101 is offline   Reply With Quote
Old 08-12-2006, 04:30 PM   #6
waktasz
Member#: 86356
Anyone know the max the sensor will read? Moving it into the airbox would probably work...doesn't get much hotter than 120 in there, does it ? (that's the hottest my outside temp gauge has ever read, here in tropical Pennsylvania)
Old 08-12-2006, 06:00 PM   #7
topshotta10
Member#: 70218
okay so my engine temp could affect the reading of the outside temp, what do you all think. You see i just changed my turbo to a fp 20g and i believe that my enigne bay feels much hotter, this could be due to the lack of a heat shiled which i should be getting soon, any other ideas. Also wondering if the heat from the turbo could be affecting my AC lines, does anyone know where to get a wrap or some form of insulation for the AC lines
Old 08-12-2006, 06:06 PM   #8
SubeTek
Member#: 1714
1999 RS-T COUPE
The outside temp sensor should not be effected by a larger turbo/lack of heatshield since it is forward of the radiator & condensor. The a/c performance can be effected by lack of a heatshield. I would suggest putting the heatshield back on.
Old 08-12-2006, 06:44 PM   #9
Picard
Member#: 100204
2006 STI (retired)
If you're sitting in stop and go traffic, yes, it will definitely be affected by a hot engine. Hot pavement/cement will also affect the reading. Once you get going at speed, you should notice that the temp reading will drop. Anyway, that's what I've noticed on my stock car.
Picard is offline   Reply With Quote
Old 08-12-2006, 07:08 PM   #10
topshotta10
Member#: 70218
any ideas where to get a wrap for the ac lines?
Old 08-12-2006, 08:11 PM   #11
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
.....d0000000000ds......the outside temp gauge is pretty useless for any other purpose than what it is used for.....its refresh rate is slow and there is a built in 'averaging' that keeps it from freaking out and reporting wild temperature fluctuations associated with stop and go driving in high temperatures.....this info IS in the owners manual
Old 08-13-2006, 02:36 PM   #12
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Realize that the response time of this sensor is EXTREMELY SLOW and would be pretty much useless for intake air temp sensing.
nhluhr is offline   Reply With Quote
Old 08-13-2006, 04:02 PM   #13
waktasz
Member#: 86356
It would still be cool and useless.
where is the outside temp sensor? metoo STi Forum Archive 1 07-26-2003 09:49 PM
where is the mass air sensor in the picture? STEALTH-WRX Factory 2.0L Turbo Powertrain 4 07-01-2002 01:44 AM
Where is the water temp. sensor located? spshultz Normally Aspirated Powertrain 2 09-06-2001 12:20 PM
