Old 08-12-2006, 11:36 PM   #1
Blk_RS01
Member#: 107914
2001 2.5 RS
Black on GOLD
Default Been driving my baby alittle hard lately and...
now everytime i give her alittle gas.. i hear this rattling/knocking noise under the hood..
i checked all the belts and looked around to see if anything is loose.. til my dad looked at me and said something about the cams... started to blow up about racing.
so im wondering.. if it is cams.. will it be easy to fix rather than spend thousands on another motor? which i wouldn't mind but... alittle low in cash.
anybody with any information??
Blk_RS01 is offline   Reply With Quote
Old 08-13-2006, 01:51 AM   #2
ScoobyDoobieBlue
Member#: 71509
2000 Subaru 2.5RS
BRP
Knocking/rattling could be alot of things, my buddies 240 knocked and 2 weeks later he fried the crank bearings. It could be a rod knock. Just giving you the worst case scenario.
ScoobyDoobieBlue is offline   Reply With Quote
Old 08-13-2006, 02:07 AM   #3
FalconRS
Member#: 92913
2005 2.5RS Wagon
Crystal Grey Metallic
Cams? I doubt it. I hope you didn't trash a bearing, cuz that sucks, but I think that's where you're headed dude.
FalconRS is offline   Reply With Quote
Old 08-13-2006, 03:10 PM   #4
Blk_RS01
Member#: 107914
2001 2.5 RS
Black on GOLD
if it is a bearing.. whats the estimate on cost wise?
Old 08-13-2006, 03:41 PM   #5
ScoobyDoobieBlue
Member#: 71509
2000 Subaru 2.5RS
BRP
Its probably cheaper to get a used short block and throw it in, less time consuming also.
Old 08-13-2006, 04:37 PM   #6
Blk_RS01
Member#: 107914
2001 2.5 RS
Black on GOLD
is this common among GC/M's?
Old 08-13-2006, 11:18 PM   #7
ScoobyDoobieBlue
Member#: 71509
2000 Subaru 2.5RS
BRP
No, headgaskets are.
Old 08-14-2006, 08:28 AM   #8
X4 SRT
Member#: 40636
2001 2.5 RS Coupe
Headgaskets seem to be the most common problem, but I have known of a few people with spun bearings. The stories all started out the same way too. They were driving hard, then they heard this rattling sound coming from their motor.
X4 SRT is offline   Reply With Quote
Old 08-14-2006, 09:52 AM   #9
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
If it were bearings or cams.. you'd hear it at idle, not just when you give it gas.
Find out where it's coming from, and then we can help you. Start the car, open the hood and give it some gas by turning the throttle body by hand.
Old 08-14-2006, 10:33 AM   #10
Hayes
Member#: 11808
Or it could be the cam timing belt tensioner. Remove the inspection cover and see if there is ANY looseness to the belt.
Hayes is offline   Reply With Quote
Old 08-14-2006, 03:03 PM   #11
Blk_RS01
Member#: 107914
2001 2.5 RS
Black on GOLD
yes even at idle now.. this is my only ride.. so i had to bear the pain and take it slowly to work *which isn't really far* and back..
when it gets alittle cooler later i'll take another look
does anybody know a good place to get a used short block?
Old 08-14-2006, 03:27 PM   #12
Blurvision
Member#: 63016
2001 2.5rs
Red
How many miles on it? I think rattle sounds shouldnt warrant you buying a new short block. Talk about over kill. First properly diagnose the problem instead of just taking wild guesses. Could be as simple as a loose bolt
-Mark
Blurvision is offline   Reply With Quote
Old 08-14-2006, 03:28 PM   #13
bl_easy
Member#: 91407
Ver. 2 WRX STi wagon
BRetty green
PM ScoobaruRS about it. I think he may have one that would work, but he's in GA. Ask anyway.
bl_easy is offline   Reply With Quote
Old 08-14-2006, 03:29 PM   #14
MikeyP5284
Member#: 104953
2011 WRX
don't rule out the easy, more simple things like heat-shields.
MikeyP5284 is offline   Reply With Quote
Old 08-14-2006, 03:29 PM   #15
BURTONRIDR
Member#: 72132
2000 Legacy GT
I cant remember if mine started making a ticking noise or not when mine got all messed up... I think it was more like a total loss of power... It ended up being a valve (or two....or three) that were totaly fried and I spent around $1200 having the heads rebuilt with new valves and seals, etc... Anyways one thing to remember, if you have a ej25. Make absolutely sure that all of your timing marks are lined up correctly, and dont go off what the Chilton pictures shows you
Something cheap and easy.. Do a compression check on all of your cylinders.
BURTONRIDR is offline   Reply With Quote
Old 08-14-2006, 03:29 PM   #16
SubaruDriver502
Member#: 114182
2003 toyota corolla
RIP wrx, damn u bambi!
ebay for the shortblock. Check your oil/give it an oil change. How many miles you got?
SubaruDriver502 is offline   Reply With Quote
Old 08-14-2006, 04:50 PM   #17
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
-Mark
Agreed. I thrash on my car weekly. 140k miles. Unless you were bouncing off the revlimiter every gear, I can't see you messed it up too bad. These cars are pretty stout.
See if you can find it with the car parked/revving the motor. if you can't find it on the surface, use a stethoscope on the motor.
Has there been any change in idle or in performance of the car?
Plays_With_toys is offline   Reply With Quote
Old 08-14-2006, 08:35 PM   #18
Blk_RS01
Member#: 107914
2001 2.5 RS
Black on GOLD
performance wise.. i haven't noticed any changes..
my rs only has 125k miles.. i've changed oil 1k miles ago..
this is the link to a short vid that took for you guys to check out
http://www.youtube.com/watch?v=4WQLViiqeXo
Old 08-14-2006, 08:49 PM   #19
iownaspec
Member#: 34154
1/2 jew crew
video is borked!
iownaspec is offline   Reply With Quote
Old 08-14-2006, 11:18 PM   #20
mrruins
Member#: 41337
2005 Toyota Tacoma
That sounds pretty nasty. My wild guess is the valves since the noise is consistent.
mrruins is offline   Reply With Quote
Old 08-14-2006, 11:32 PM   #21
iownaspec
Member#: 34154
1/2 jew crew
valves definatly. thats the click of death LOL.
Old 08-15-2006, 12:24 AM   #22
Blk_RS01
Member#: 107914
2001 2.5 RS
Black on GOLD
dammit.. can you get a quote from alex for me..?
Old 08-15-2006, 01:13 AM   #23
iownaspec
Member#: 34154
1/2 jew crew
just get ahold of him either on central carolina forums or call folger and ask for him his extension is 220.
Old 08-15-2006, 03:41 AM   #24
silentbob343
Member#: 57307
sounds like lifter tick
silentbob343 is offline   Reply With Quote
Old 08-15-2006, 12:09 PM   #25
Calamity Jesus
Member#: 44501
1984 That's *Sir*
If it's lifter tick, then I have to ask: What grade oil are you using and have you actually checked it? Lifter tick is nothing to freak out about.
been driving my 09 wrx wagon for over a week. devasta Newbies & FAQs 2 07-29-2009 10:41 PM
My baby is getting old and tired - any thoughts? Subi Ru Mid West Subaru Owners Club Forum -- MWSOC 6 10-19-2006 12:52 PM
I've been missing a lot of OT lately and.. Absolut Off-Topic 6 10-13-2005 05:17 PM
('93-'01) My baby has new paint and Sirius! C-daleRidr Impreza Forum 2 07-23-2003 05:33 PM
I wish i had been driving my suby Impreza2.5 General Community 3 05-06-2002 01:05 AM
