Old 08-13-2006, 12:58 PM   #1
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Default Need help with injector pulse width settings
I have been experiencing an erratic idle on my car for quite a while but the other day it suddenly started to idle fine. The only thing I noticed was that my volt meter was reading slightly less than 12v. Normally it runs between 13 and 14. The voltage is now back up to where it should be and my erratic idle is also back.
I noticed that at the lower voltage the latency on the injectors changes. This leads me to question the current values I am running. The injectors are PE650's and from the pe website I found that they have a lagtime of 1.5
Here are my current settings:
Any help on what these values should be is greatly appreciated. Any other ideas on how to fix my idle are also welcome.
thanks
Mike K
LiquidForce is offline   Reply With Quote
Old 08-13-2006, 01:49 PM   #2
Freon
Member#: 88322
2009 BMW 135i
You have a problem with your charging system. You shouldn't see less than 13v while idling, and it really should be closer to 14v.
I imagine the standard latency quoted is for normal running voltage, which should be closer to 14v. Your values look like stock injector values.
I suggest having your charging system checked and also taking some logs of your problem.
Freon is offline   Reply With Quote
Old 08-13-2006, 02:21 PM   #3
LiquidForce
Member#: 12811
2002 2.5l Wrx
I resolved my electrical issues that is why I have the idle issues again.
I just dowloaded some stock maps and it does appear that the latency is set to the factory defaults.
Ms Outlook uber nerds -- need help with junk email registry setting drkwtsn Off-Topic 5 09-12-2006 04:38 PM
Need help with Greddy e-01 Settings Fahd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-14-2004 11:50 PM
Got my kit - Need help with injectors!! *PLEASE* trilap5e Normally Aspirated with bolt-on Forced Induction Powertrain 3 08-30-2003 01:06 PM
Need help with Blitz SBC-iD settings Si2WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-29-2002 05:37 PM
Need help with me S-AFC settings??? Xscreamer Normally Aspirated Powertrain 3 02-21-2001 08:13 AM
