#1 |
Member Sales Rating: (33)
Member#: 53731
Vehicle:2002 CountTougeKing |
Please read below to see what I still have as I do not have anything that is not listed.
So I total my car, while going through a turn at about 40-50 mph a deer decided to run out in front of me, so I cut the wheel and hit the brakes, in an attempt to avoid the deer but ended up hitting a tree. All parts are in very good condition with normal ware, unless noted. I am located in New York and will ship anything out. Prices do not include shipping, please PM me for a quote. Pictures are available upon request. All prices are or best offer. All sales are final. I am PayPal verified and prefer to be paid in that way (PayPal). Please read below to see what I still have as I do not have anything that is not listed. Power Window Motors (I still have all four) ………………………….$110 Each Power Window Regulators (I still have all four) …………………….$30 Each Door Glass/Widows Rear (I still have both) …………………………….$70 each Door Glass/Widows Front (I still have both) ………………………….$150 each Rear trailing arm bars (comes by itself)………………..$60 Pass Side Sold Rear lateral arm bars (comes by itself)……………………..$40 each. The pass side front has been sold Axles…………………………………………………………….$180 each 4EAT dash cluster (68-9XXX miles)……………………………$150 Rear seat belts (does not come with buckle)………………………$80 each Master cylinder…………………………………………………….$60 Brake booster………………………………………………………$120 Main air bag controller (under HVAC)…………………………….$250 Side air bag controller (in the B-pillar)…………………………….$150 each Front air bag sensors………………………………………………$50 each Steering column (comes by itself)…………………………………$150 Steering column coupling (box)……………………………………$60 HVAC controls…………………………………………………………….$80 Blower motor assembly…………………………………………………………$100 Center blower (sits on top of part above)…………………………………..$80 A-pillars……………………………………………………………………..$15 Driver side sold Upper B-pillars………………………………………………………………$15 each Lower B-pillars………………………………………………………………$25 each Upper C-pillars……………………………………………………………….$15 each Lower C-pillars……………………………………………………………….$15 each Front door sills………………………………………………………………..$15 each Rear door sills………………………………………………………………..$15 each Drive side lower dash………………………………………………………….$35 Lower center console…………………………………………………………..$40 Front defroster vent…………………………………………………………….$40 Hazard button (I have two of these and does not light up)……………………$10 Inner window seals…………………………………………………………..$20 each Carpet (has holes cut out for a roll cage, but with the floor mats in they are not very noticeable)…………………………………………………………………….$50 Door speakers…………………………………………………………………$10 each Dash support bar……………………………………………………………$160 Outer window rubber trim………………………………………………….$40 Driver side is sold Outer Window trim……………………………………………………………$100 each Outer B-pillar trim piece…………………………………………………….$15 each Wiper arms……………………………………………………………………..$30 each Wiper trans (one bolt/mount point has broke but will still work fine)…..$60 ABS Pump/Unit …………..........................................……$1 80 Steering rack (comes by itself w/ tie rods, pass. side tie rod is bent)………………………………………………………………………………$100 Rear subframe (comes by itself)……………………………………………………..$150 “Middle” drive shaft/rear diff sub mount (the part you use outtrigger bushings on)…..$80 4EAT Shifter with linkage (comes with the linkage, shifter rod, and lower plastic housing………………………………………………………………………………$50 Rear seat lower bar…………………………………………………………………$40 Rear seat upper parts……………………………………………………………….$75 Trunk seal………………………………………………………………………….$15 Trunk arms………………………………………………………………………$20 each Fuel pump sending unit/fuel gauge sensor assembly…………………………….$100
#3 |
Member Sales Rating: (25)
Member#: 87629
BAIC
Vehicle:05 6spd LGT |
Do you have a clear (not fogged up) passenger side headlight? Mine is cracked, need a replacement...
ben bmack@tulane.edu |
#6 |
Member Sales Rating: (21)
Member#: 11218
SCIC
Vehicle:2005 Legacy GT Wagon 99 Miata, 91 Miata turbo |
I'll give you $40 shipped for the driver side foglight.
I'm also looking for the center vent assembly (vents on either side of hazard light button) if you happen to have it. |
#7 |
Member#: 53731
Ratboy - sorry no AC compressor.
Blown95ImpalaSS – The headlight on this car was damaged, but I will be getting a new (used) 02 in a few days. I’m pretty sure it is in condition, so I’ll PM you and post a pic as soon as it’s available (replacing with JDM projectors a.s.a.p.). STi-JDM – I do not have any stock side skirts at this time, but I will have a pair as soon as I get the new (used) car in a few days. Also the side skirts will not be painted. Evan – please PM me your address so I can get an idea of what shipping will be, I am sure we can work something out. As for the center vents, I will have them as soon as I get the new (used) car, so I’ll PM you and post a pic as soon as it’s available, as the one off my car has been painted gun metal. |
#9 |
Member Sales Rating: (20)
Member#: 97130
SCIC
Vehicle:2004 WRX STI Stock as can be ... |
Damn dude, that really sucks to hear bro. But hey! Congrats on getting another WRX! You never got back to me on the APR Wing though. Let me know what's up!
Peace- Tod ![]() |
#10 |
Member Sales Rating: (5)
Member#: 44168
SCIC
Vehicle:2003 Yellow WRX with too many lights... |
I would like the seatbelt buckle from one of the front seats. The metal male portion only which is on the belt itself (not the female part attached to the seats). You'll have to cut the seatbelt to remove it. Should be easy to mail too since it's flat.
![]() Lemme know if you can get it and a price. Thanks! |
#12 |
Member#: 53731
wrx360 – Let me check, I believe I do have it. I’ll PM you when I find out.
TURBOTOD – Sorry to keep you hanging, you have a PM. Psydotek – I would rather sell the entire seatbelt harness, clip, and assembly as one. If I find that it will not sell all together, the clip is all yours. Sher1485 – As soon as I get the new (used) car I’ll post pics and PM you a price shipped for both. |
#14 | |
Member Sales Rating: (4)
Member#: 120421
SCIC
Vehicle:2002 Impreza Outback |
interested on headlights!! |
#15 |
Member#: 53731
LetumAWD – I’m sorry but the headlights are not available yet, but as soon as I get my new (used) car I’ll PM you and post pics.
#17 | |
Member#: 97130
SCIC
Peace- Tod ![]() |
#19 | |
Member#: 11218
SCIC
I've already paid IceColdRex for the driver side foglight. |
#20 |
Member Sales Rating: (3)
Member#: 110850
Vehicle:2003 WRX Black Pearl |
Hey, I am interested in the right Taillight. Is this available still? I only need the housing, not the wiring or anything. Can you do 60 shipped for this?
#21 |
Member#: 53731
thatguyinwrx – I think I have to agree with Evan but I will double check tomorrow and I’ll PM you. By the way the drive side one is sold to Evan.
TURBOTOD – NOW you have a PM. Sorry about that. SubyDuz - -PMed ya back. Silentdawn – Both tail lights are still available. Do you need the pass. or driver side? PM me your address so I can get an idea of what shipping will be, I am sure we can work something out. |
#23 |
Member Sales Rating: (15)
Member#: 110035
NESIC
Vehicle:2002 Built Hybrid MBP |
Sorry to hear that, but at least your getting something new.
So do you still have the front o2 sensor (AF sensor) or the rear defogger wiring harness? PM me. |
#25 |
Member Sales Rating: (26)
Member#: 111268
SCIC
Vehicle:.... MLTMFA2 \,,,/ |
Do you have the stock ashtray thing that goes right in front of the shifter? Used to have an EBC in there now its a gaping hole.
| Thread Tools | |
| Display Modes | |
| Parting out 02 WRX 50K Miles! Lots of Parts! | Farvardeen | Complete Car Part-Out | 39 | 07-15-2008 06:23 PM |
| Totaled Out 02 WRX Part Out Lots-O-OEM | IceColdRex | Suspension/Brakes/Handling | 37 | 10-10-2006 06:56 AM |
| Totaled Out 02 WRX Part Out Full PTS Trans Plus More | IceColdRex | Drivetrain | 43 | 10-10-2006 06:56 AM |
| Totaled Out 02 WRX Part Out Hyperflow TMIC GFB Walbro | IceColdRex | Engine/Power/Exhaust | 31 | 10-10-2006 06:55 AM |
| huge part list, 02 wrx part out, 04 sti parts, jdm st v7 parts | gotti | Private 'For Sale' Classifieds | 34 | 03-10-2006 09:32 AM |
