Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Old 08-13-2006, 09:11 PM   #1
WRC1
Member#: 47803
2000 Impreza 2.5 RS
Blue Ridge Pearl
Default 96 legacy 2.5 head same as 2.5RS?
Is the 96 legacy 2.5 head the same as my 2000 2.5 RS head? I need to replace my head, thanks! If not, what are the differences?
WRC1 is offline   Reply With Quote
Old 08-13-2006, 09:24 PM   #2
Charge
Member#: 3313
I thought the 96 Legacy was a DOHC? The 2000 RS is a SOHC.
Charge is offline   Reply With Quote
Old 08-13-2006, 10:37 PM   #3
illegal2.2
Member#: 58329
97 Legacy GT
Rio Red
^sohc vs. dohc DOHC FTW!
illegal2.2 is offline   Reply With Quote
Old 08-13-2006, 11:34 PM   #4
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
The answer is: No
Old 08-14-2006, 05:11 PM   #5
JoshP
Member#: 94350
different
JoshP is offline   Reply With Quote
Old 08-14-2006, 10:20 PM   #6
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
WAY different. although, i just saw a pair of DOHC heads on ebay last week. why do you want to know? i cant remember if you can run SOHC heads on DOHC engine management.
~Josh~
Old 08-15-2006, 11:51 AM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
The '96 DOHC Ej25 heads are unique to that engine. Those heads have HLA's under their buckets. The '97-99 DOHC EJ25 heads have a shim over bucket design. If you are only replacing one head, it will need to be a '96 head. You could replace them with a pair of later DOHC heads, but the SOHC heads are not an option...
Old 08-15-2006, 12:49 PM   #8
opious
Member#: 57718
99 Impreza OBS WGN
Silver now w/ 20mm rear!P
i'm not usually one to correct (especially not mr. monson), but i think you've got it backwards. he's looking for heads for his 2000 RS, in which case he would have to stick with similar vintage SOHC heads.
opious is offline   Reply With Quote
Old 08-15-2006, 02:10 PM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
When I am wrong I should be corrected...
Any SOHC Ej25 head will work for his car...
Old 08-15-2006, 10:31 PM   #10
redwagon
Member#: 2181
2008 SpecB
Except an '06 head with AVCS of course. Twice in one day, doh!
@OP: What's wrong with your head that it needs replacing?
redwagon is offline   Reply With Quote
Old 08-16-2006, 03:54 AM   #11
WRC1
Member#: 47803
2000 Impreza 2.5 RS
Blue Ridge Pearl
thanks for the info. i thought the '96 was a SOHC, if i knew it was DOHC i wouldnt even ask.
oh and was wrong.... im pretty sure i dropped a valve the over day. i was driving down PCH at about 50mph in 5th gear and i hear a big bang, pull over and the spark plug for cyclinder 3 in sitting near my battery. The threads are completely gone on the head. So best case i need a new head. worst case i broke a valve ****ed the cyclinder walls and need a new engine.... kinda sucks.
im looking at the EJ20"DET" but i cant find a place that knows what they are talking about or has an ecu to go with the engine,
~Leor
Old 08-16-2006, 05:33 AM   #12
andys
Member#: 53455
2004 Forester XTI-RR
dark
maybe the spark plug just got loose and poped out. I've done this before. Are all the threads gonzo? Helicoil?
andys is offline   Reply With Quote
Old 08-16-2006, 04:08 PM   #13
WRC1
Member#: 47803
2000 Impreza 2.5 RS
Blue Ridge Pearl
well when i put a ne plug in it went all the way to the bottom of the threads without having to turn it.
Old 08-16-2006, 04:52 PM   #14
ROC pit-bull
Member#: 67814
1995 legacy L
white
I'm prety sure that the heads must match the ecu.
ROC pit-bull is offline   Reply With Quote
Old 08-16-2006, 09:21 PM   #15
redwagon
Member#: 2181
2008 SpecB
Sounds like the plug was just loose for so long it destroyed the threads. Helicoil repair should fix that.
pic of 2.5 head gasket on 2.2 head JoshP Normally Aspirated Powertrain 9 06-24-2006 02:26 AM
is the 2.5 rs(2002) same as the sti motor? DennisAltered Mid Atlantic Impreza Club -- MAIC 5 03-10-2005 07:27 PM
2.5 heads on a 2.2? Impreza25RS Normally Aspirated with bolt-on Forced Induction Powertrain 6 02-07-2002 06:59 AM
('93-'01) Is a 98 legacy 2.5 engine same as a 99 RS Jimmy Impreza Forum 4 05-21-2001 12:10 PM
2.5 heads on a 2.2 iceman Technical Forum Archive 8 06-20-2000 10:09 AM
