#1 |
Member#: 122703
Ok, so I have a 1/2 rachet, 22mm socket a 3' breaker bar, car is a manual tranny so I have it in 5th gear and I have a piece of wood between the seat and the brake to apply the brake while trying to break loose the pulley bolt.
This method is not working... I can still turn the timing belt and pulleys over without the bolt breaking loose. I am a fairly strong person so strength is not the issue... I need to make sure the crank pulley doesnt move. I dont want to remove the tranny and put something between the flywheel.... Any other ideas?
#2 |
Member#: 95787
SWIC
Vehicle:2003 OBS silver |
I was having trouble getting mine off my auto; a few ways are mentioned here:
http://forums.nasioc.com/forums/show....php?t=1028450 |
#3 |
Member#: 122703
I figured it out... I forgot i had the car jacked up still... long day. I lowered the car and bam it came right off.
I removed the waterpump and took a look at it. It seemed to be working fine. The portion where the belt moves the pump seemed to turn the fins just fine. The gaskets all looked fine as well. I am in the process of trying to figure out how to get the damn timing belt lined back up to my marks. I am having the worst time ever. I replaced the waterpump with a new one, doubt it was the cause of the problem, but at $60 bucks for a new one it needed one anyhow. It has 129k miles on it. At 126k the timing and all other belts were replaced... Hopefully I can track down this over heating problem. |
#4 | |
Member#: 44501
South East
Vehicle:1984 "Skeletor from "He-Man" |
#5 |
Member#: 11808
Hopefully you have an OEM timeing belt. They have white lines to assist in getting the cams/crankshaft timing correct and, the belt has a direction.
#6 | |
Member#: 72132
NWIC
Vehicle:2000 Legacy GT White |
Hehe I hate it when I forget stuff like that..... hope you didnt rack your brains to hard before your noticed that. ![]() |
#7 |
Member#: 82556
Vehicle:1996 Legacy L wagon |
What I did with my SOHC was placed the belt on with the marking, then using a wood clamp (plastic C clamp looking thing) I locked it on the pulley, then I went and did the other side. It was a serious pain, but I eventually got it to go. Luckily with a SOHC I didn't have to worry about knicking valves against each other.
#8 |
Member#: 2112
Put a breaker bar on the bolt, and then brace it against the ground. JUST "BIP" the starter with the breaker bar firmly braced against the ground. It'll come right off
. Breaking the initial torque in the hardest part. |
#9 |
Member#: 1853
TXIC
Vehicle:GC6 Supercharged STM |
There is a far easier way to break free that 22mm bad boy.
My crank pully (00RS) has 4 holes spaced around the 22mm bolt. These holes perfectly fit a standard 3/8 socket extension. Put 2 socket extensions in 2 of the holes. Then, with the 22mm socket and breaker bar in place, I used my tierod splitter wedged in between the extensions and my socket. With the handle of the splitter wedged agains some part of the block. Now.. your not relying on the drivetrain and all of it's slop to break it free. Plus.. when it comes time to torque that sucker back down, you'll get a much better result this way. Last edited by Skidd; 08-15-2006 at 10:04 AM. |
#10 |
Member#: 122703
Is there a certian way I am supposed to have the pulleys lined up? There are two indention marks on the top left pulley and the top right pulley... Then there are white lines from previous technicians on the pulleys... Which ones do I go by? There are total of 3 white lines per pulley and I havent a clue where to start. The bottom pulleys look like they have 1 indention per pulley and 1 white line per pulley.
I know that you are supposed to line up the white marks to the 12 o clock position in conjuntion with the notch on the timing cover deal, but I am unsure of which lines/indention to use. I am using a stock belt with the dotted lines and the two solid lines. Any help would be appreciated as I didnt find the info in the manual. Thanks. |
#11 |
Member#: 6486
Vehicle:00 Impreza 2.5 RS Blue Ridge Pearl |
Is this a sohc or dohc?
Sounds like dohc. Top pulleys/ single mark on top, double mark on bottom. Bottom pulleys/ double mark on top(matches up with top pulley), and single mark facing 90 degrees outward(matches belt) |
| Thread Tools | |
| Display Modes | |
| FS in CO: P&P Headers, Crank Pulley, Stock DP | charlesdixon | Engine/Power/Exhaust | 4 | 06-04-2010 09:11 AM |
| Charleston sc, do any of you have the tool to remove crank pulley | GregBolby | South East Region Forum | 4 | 04-01-2010 06:23 PM |
| Problem Removing crank pulley | ShagginWagon02 | Newbies & FAQs | 7 | 04-22-2009 06:31 PM |
| How do you remove Crank Pulley on an AT? | EdHilario | Normally Aspirated Powertrain | 26 | 09-16-2007 09:59 PM |
| removing crank pulley on auto RS | 2.5 Blue Roo | Service & Maintenance | 13 | 07-06-2004 07:41 PM |
