Old 08-14-2006, 12:47 AM   #1
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Question Diference between 2.5RS and STi engine blocks?
As it asks above.
Looking to replace my block and the question came up.
TIA,
Leo
Leonardo is offline   Reply With Quote
Old 08-14-2006, 01:09 AM   #2
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
Well the block itself, the diff is the sti is semi- closed deck and IIRC the sti block has an extra crankcase vent the rs is open deck. Internals are different as well.
speed_freak27 is offline   Reply With Quote
Old 08-14-2006, 01:12 AM   #3
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Thanks but I have the STi internals so I don't want to know about that.
Just asking about the block itself.
might it withstand 400hp or a bit more?
Old 08-14-2006, 01:19 AM   #4
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
Well he's right. The main difference is that the STi block is semi closed and has a little more support arount the cylinder walls. So the short answer is yes, it can handle 400hp. But so can a Phase II SOHC EJ253...
The EJ257 is almost a DIRECT bolton to everything EJ25...
There is a retarded amount of literature on this in the AFI forums, you know?
-Brett
ExecNav is offline   Reply With Quote
Old 08-14-2006, 02:15 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Before the Ej257 hit, Quirt Crawford built a large number of the Ej251/4 blocks for that kind of power. Many will argue that you want to do a closed deck modification to the block, but others will say it's fine as is, with the addition of turbo internals. Personally, I think if you limit is 400chp you can do it pretty easily. If you want to go past that, you will want to look at reinforcing the block, which quickly becomes very expensive and suggests just starting with an Ej257 case in the first place...
Old 08-14-2006, 07:20 PM   #6
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
thanks guys!
Old 08-14-2006, 10:19 PM   #7
Division By Zero
Member#: 7555
Not to hijack the thread, but I just bought a 2002 Forester engine and am considering using it for the heads. However, I'm thinking of possibly using the crank as well. How does the crank compare to the 257 one? Is it forged (I'm assuming so) and are the journals the same size? I would want to re-use my 257 rods since they've already been balanced.
Oh yeah, got any idea of the original specs from the '02 Forester 2.5L as far as cams duration, lift, cyl head dish CC's, and of course the static CR? I found CR numbers from 9.7 to 10:1. My pistons are spec'd for 8.4:1 for a EJ257 using WRX 2L heads.
Division By Zero is offline   Reply With Quote
Differences between 2.5i and STi impreza2.5i2010 Newbies & FAQs 20 09-28-2009 03:13 PM
whats the difference between 2.5RS and WRX suspensions FromEvoToRS37 Brakes, Steering & Suspension 4 02-28-2007 04:45 PM
2.5rs and sti engine the same? shutupnshift04 Newbies & FAQs 21 12-03-2005 10:13 AM
Big diffrence in towing between 2.5RS and WRX? glockgod Newbies & FAQs 4 12-24-2004 11:52 PM
whats the difference between the 2.5Rs engine and STI engine? MaxPower STi Forum Archive 6 01-07-2003 08:15 PM
