Old 08-14-2006, 02:58 PM   #1
Hum Bum
Member#: 118494
2000 impreza obs
Default 2.2L engine injector noise
Hi, I have a 2000 impreza obs completely stock. I have noticed that when the engine is idling it makes wispy sounds. Its coming from both sides of the engine bay. Someone said its the injectors, does that sound right? I havnt tested to see if the sound increases with rpms. I cant hear it while I am in the car. Thanks
Hum Bum is offline   Reply With Quote
Old 08-14-2006, 03:16 PM   #2
BURTONRIDR
Member#: 72132
2000 Legacy GT
are you having any trouble with it idling or accelarating strangly? if you are then you might check your vaccum lines for a leak.
BURTONRIDR is offline   Reply With Quote
Old 08-14-2006, 03:53 PM   #3
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
You could use a stethoscope on the injectors to see if they are the culprit.
Plays_With_toys is offline   Reply With Quote
Old 08-14-2006, 11:55 PM   #4
Hum Bum
Member#: 118494
2000 impreza obs
The car idles great and accelerates great. The sound is also not constant so thats what makes me not suspect a vaccum leak, it more like ticks. Its a high pitch sound that does increase with rpms but gets drowned out by engine noise as it revs higher.
Hmmm, I am just going to have to find a stethoscope.
Old 08-15-2006, 10:53 AM   #5
BURTONRIDR
Member#: 72132
2000 Legacy GT
Hmm Ill listen to my engine tonight... I think mine does the same thing, it is probably just the valves or injectors. I believe mine does it on the left side of my engine because I messed up putting it back together and bend a valve just a hair I was so freakin pissed off, Stupid chilton manual
2.2l Engine For Sale Rags North West Impreza Club Forum -- NWIC 14 06-08-2016 07:55 PM
FS: Version 2 STi Intercooler, Subaru Water to Air Intercooler, FSB, 2.2L engine munkis Tri-State Area Private Classifieds 0 11-14-2008 09:32 AM
'97 2.2l impreza trans noise question initialx Transmission (AT/MT) & Driveline 1 09-21-2002 07:59 PM
2.2L AT - Whining Noise Gar-Man Transmission (AT/MT) & Driveline 3 08-16-2001 03:46 AM
'95 2.2L engine same as '97 2.2L? I need the part quick! chyisan Normally Aspirated Powertrain 1 12-22-2000 03:33 PM
