Old 08-14-2006, 06:17 PM   #1
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Yeah, that's about right.
Default Whine at WOT - fuel pump or ...???
OK here we go again... I've been trying to diagnose this problem for literally years now and the chance has finally come to pull whatever parts I might need.
Symptoms:
- High-pitched whine under high load / WOT (kind of like "shhhh")
- Car stumbles and hesitates after being driven hard for a while (running lean --> overheating?)
- High NOx reading at emissions check (seems lean to me)
- Otherwise seems to run normal (never throws a CEL)
I pulled the fuel pump and the strainer sock looked perfectly clean. Is it worth replacing the thing???
Any other suspects?
Necromancer is offline   Reply With Quote
Old 08-14-2006, 06:32 PM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
What year car? I am not sure how you could test it. Maybe put in a fuel pressure gauge and somehow test the maximum pressure the pump will hold? You may just want to replace it based on its age and see if it fixes your problem.
Old 08-14-2006, 08:14 PM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
How many miles on the vehicle? When was the last time you changed your fuel filter?
I would test the fuel pressure with and without the vacuum line on the fuel pressure regulator.
Tim Sanderson is offline   Reply With Quote
Old 08-15-2006, 01:09 PM   #4
msm98lw
Member#: 55849
2000 Impreza 2.5RS
'97 legacy GT wagon
My '97 LGT (95K) has a whistle at wOT that I thought was a vacuum leak, but the dealer told me it was a failing muffler baffle.
msm98lw is offline   Reply With Quote
Old 08-16-2006, 06:25 AM   #5
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Thanks for the responses so far. The car is an '01 2.5RS with about 70K miles. Fuel filter, spark plugs, and lots more are new.
I guess the fuel pressure test would be the obvious thing to do -- not exactly easy but I'll give it a try.
An exhaust leak wouldn't normally cause this kind of lean situation, right?
Anyway, thanks for the thoughts -- I'll keep the board updated with where this is going.
Old 08-16-2006, 08:35 AM   #6
Nemesis Digital
Member#: 119579
2004 WRX Wagon
San Remo Red
An exhaust leak large enough could allow more Oxygen to cause a false reading. My wideband read higher AFRs when I had a leak.
Nemesis Digital is offline   Reply With Quote
fuel problem, is it the fuel pump or FPR? Unabomber Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 02-24-2012 04:42 PM
WTB:OE Fuel Pump or Walbro Fuel Pump hey1 Private 'Wanted' Classifieds 2 02-20-2007 08:58 PM
Wierd whine at wot, like a supercharger Supra95 Newbies & FAQs 43 05-27-2006 02:16 AM
Torque mods: Do I need a bigger fuel pump or TMIC with a vf24 upgrade? chazbott Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 12-05-2004 11:39 AM
high pitched sound at speed; fuel pump?? Dave G Outback Forum 11 11-22-2004 10:18 PM
