Welcome to the North American Subaru Impreza Owners Club Sunday November 23, 2014
Old 08-17-2006, 01:07 AM   #1
Motts
Member#: 89738
2000 Impreza 2.5RS
Default CEL p1507 code. Please help Ive tried everything.
Hi,
I have a 2002 WRX. I havent been driving my car alot this summer opting to drive my other vehicle for better gas mileage. Well the other day I decided to drive my car to work which is a 1 mile, <10 minute hike. So about 2 minutes driving my car starts to idle around 2K and after another couple minutes it throws a CEL code. The drive home was the same.
I can tell you nothing has changed on the vehicle other than the fact it sat there maybe 5 days in the garage.
So when I get home I read the code which is, like the title says, p1507. I search for it on NASIOC and find things to try. Heres a list of what Ive done.
The first thing was to clean the IACV. I first used the Alcohol and qtip method. I also bought a new gasket. Reset the ECU and put it back together. Did nothing. I searched cleaning it some more and realized alot of people saying they replaced the valve. Since the thing costs close to $300 I wanted to know what goes bad to consider it replaceable. I took off the IACV sensor and figured out how the thing works. I turned the valve and felt it break the sticky position it was in. Obviously the first cleaning did nothing.
This time I decided to clean it with non cholinated brake cleaner and q-tips. Ater that I let gasoline soak in it. I then used LPS2 lubricant on the sucker. I noticed the valve would turn but its a little resistant. By little, I mean little. I put it back together knowing ALL the gunk is out of it and lubricated. I reset the ECU and started the car. It idles at 2K then dropped to 1500 then to 1250 where it stays now. So obviously it helped but its still idling high and the CEL is still on.
I decided to take it for a drive to try and seat the gasket. I made sure to stay out of boost and to keep the revs a little high. This didnt fix it.
I then readjusted the throttle cables and checked all my vacuum lines by spraying them with soapy water. No leaks.
To summarize:
- Car has a p1507.
- Idles around 1250.
- Normal idle is 500.
- No vacuum leaks found.
- Throttle cables adjusted fine.
Can someone please help me? I dont understand how replacing the IACV will solve the problem since mine does move. It is a little tough. Can anyone tell me if its supposed to rotate VERY loosely? Also, I shouldnt worry about replacing the sensor correct (that things another 300 bucks)?
Thank you.
Motts is offline   Reply With Quote
Old 08-17-2006, 01:10 AM   #2
Motts
Member#: 89738
2000 Impreza 2.5RS
One more question. Does anyone know where I can find a new IACV for under $250 bucks. That is SUCH a HIGH price for something so simple.
Old 08-18-2006, 01:47 AM   #3
Motts
Member#: 89738
2000 Impreza 2.5RS
Today the CEL went away for awhile and the car idled around 1250. After about 15 minutes total driving time the CEL came back. I double checked the code and found that I also have the p0507 code. Does this help anyone make a suggestion on whats wrong?
Old 08-18-2006, 02:03 AM   #4
TMessick
Member#: 882
2004 WRX Wagon
very blue
Auto or Manual? Found this for automagic:
http://www.endwrench.com/pdf/fuel/Di...odeInfoW99.pdf
TMessick is offline   Reply With Quote
Old 08-18-2006, 12:56 PM   #5
Motts
Member#: 89738
2000 Impreza 2.5RS
No its actually a manual. Thanks though.
Old 08-18-2006, 01:25 PM   #6
rallymarty
Member#: 17418
2002 S6 Avant
try sourcing one from a junkyard or maybe finding someone parting out a wrecked car here in the forums or locally. good luck
rallymarty is offline   Reply With Quote
Old 08-21-2006, 02:10 AM   #7
Motts
Member#: 89738
2000 Impreza 2.5RS
Can you get these CEL codes if there is a vacuum leak? It seems that the p1507 and p0507 lights are a pretty common problem. Since the errors seem to be for Idle Control issues are the codes not specific to the IACV?
Old 08-25-2006, 05:14 PM   #8
Motts
Member#: 89738
2000 Impreza 2.5RS
Bought a new IACV and put it on. Thing idles great now! I guess some IACV are just not able to be cleaned.
Old 08-25-2006, 05:42 PM   #9
Grover85
Member#: 122689
02 WRX
Usally a vacuum leak sets a lean code.
Grover85 is offline   Reply With Quote
Old 10-28-2006, 08:49 PM   #10
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
what is a IACV. I just got this code in my 2002 RS an need to source it.. thank you.
-Ellz
ejicon is offline   Reply With Quote
Can someone please help. Ive tried other forums but nobody answers :( Nemesis Digital Newbies & FAQs 7 01-07-2008 01:39 PM
****need Help With Cel Codes-please Help************** stito Subaru Conversions 4 07-29-2007 05:55 AM
p0136....seriously ive tried everything. BoostedAWD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 05-02-2004 05:54 PM
CEL, Knock Code, please help Turbo GC4 Normally Aspirated with bolt-on Forced Induction Powertrain 8 05-23-2003 04:50 PM
Help i've tried everything? XROLLER General Forum Archive 1 12-21-2000 07:17 AM
