Old 08-17-2006, 12:35 AM   #1
Mountainer
Member#: 108246
2000 Legacy GT
Question Front O2 Sensor install....
I have a '00 Legacy GT and I need to replace the fron 02 sensor. I know that I'm going to have to take the passenger front wheel and splash guard off to do this, but can anybody give me better instructions of getting to the sensor and stuff? And is a O2 sensor socket required to get this sensor out, or would it just make things easier? I'm planning on doing it tommorow morning because my car is running like crap with the dead sensor, so please someone help! Oh and will I need to reset my ECU to get everything working normal again?
Mountainer is offline   Reply With Quote
Old 08-17-2006, 09:06 AM   #2
C4NiNjA
Member#: 91964
2003 Impreza WRX WRB
I just did this in my 03 WRX. If it is close to that, then it is right behind the splash guard and you can Borrow the correct tools from Advance Auto or Autozone. It took about 30 minutes. Just be careful when you reroute the 02 sensor wire so it stays away from the parts that get HOT.
C4NiNjA is offline   Reply With Quote
Old 08-17-2006, 09:53 AM   #3
Mountainer
Member#: 108246
2000 Legacy GT
Alright I just finished installing it actually, spent 20 minutes trying to break the previous sensor loose until I found some WD-40 lol. On my car, once I took the wheel off, you could see the sensor right in the middle of the Y pipe, so the splash guard thing didn't apply. Not too hard, alot easier than I thought it would be once I got the old one off. But my last question is, do I need to disconnect the battery now to reset the ECU or will it start working without the reset?
Old 08-17-2006, 12:16 PM   #4
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
It will start up just fine without an ECU reset. It may start a bit rough at first, but it'll even out after a minute or so.
AJ711 is offline   Reply With Quote
Front O2 sensor vs Rear O2 sensor (MY00 RS) Jewbaru Service & Maintenance 3 07-29-2012 10:14 PM
need help with front O2 sensor install. kcismo New England Impreza Club Forum -- NESIC 1 12-19-2007 08:07 AM
Hesitation in 1st gear only -- after new front O2 sensor install? bpwatts UTEC 2 08-03-2007 01:15 AM
Front O2 sensor installation woes Charge Normally Aspirated Powertrain 6 07-07-2006 04:56 PM
Uppipe install - how to get front o2 sensor out? moby4dick Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-16-2005 06:59 PM
