Old 08-18-2006, 07:11 PM   #1
Subieformance_Guy
Member#: 108716
2004 2.1L, PT 6069
[email protected] Subarus-R-Us
Question frankenmotor help
I really thinking about building up a frankenmotor for my obs instead of just dropping in a 2.5. Is it better to use the dual port heads or the single port like on mine? And also what kind of hp numbers are people getting thats what im really wanting to know. I had planned on boring the 2.5 block to 100mm, coated pistons, cam regrinds (deltal cams), port and polish heads, 5 angle valve job, and putting it together with sti headgaskets for the extra comp or is the sti gaskets a bad idea. I've searched up top but no help for the questions I have. If anyone has the answers to my questions or information in general please dont hesitate to tell me im planning on starting the build pretty soon.
Thanks Tommy
Subieformance_Guy is offline   Reply With Quote
Old 08-18-2006, 09:54 PM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
as long as you use the phase II ej25 you can use the thin head gaskets. if you use the pahse I you have to use the DOHC gasket. as far as heads go, use the dual port, i dont think anyone makes a EL header for the singleport heads. if you just want a standard borla thats fine, but i would leave yourself some upgrading "room". the CR increase is good for about 5-7 hp IIRC, the ej25 block is good for another 20 over the ej22 block. the cams are good for at least 10-12. and the header (if you get one) is good for at least 5, for the borla, and 10 for the EL header. boring the block really isnt gonna get you much power, unless your block is out of spec or something. unless you want to run forged pistons.......but then i would get custom made pistons and keep the better flowing ej25 heads (just get cams for the ej25 instead). im also ready to put my block back together after it gets back from the "dishwasher". after its all clean and pretty ill be in the rush to get it together and broken in.
~Josh~
Old 08-19-2006, 12:36 PM   #3
Subieformance_Guy
Member#: 108716
2004 2.1L, PT 6069
Post
thanks for the information balli. I am also interested in the stroker motor. I know if u take a 2.2 block and put a 2.5 crank, rods in it it strokes it out to a 2.375. Do you use the 2.5 heads on it and is it a better motor than the frankenmotor?
Old 08-19-2006, 01:21 PM   #4
Rally_wgn
Member#: 62629
1996 OBS in Green
2.5 N/A w/ full exhaust
subscribe
Rally_wgn is offline   Reply With Quote
Anyone need help with an install? RubbleDTD Mid Atlantic Impreza Club -- MAIC 0 06-03-2010 05:23 AM
frankenmotor build help rllyrckt Built Motor Discussion 0 04-10-2008 04:28 PM
question about timing belt for frankenmotor outback2.5 Subaru Conversions 3 07-18-2006 02:50 PM
Frankenmotor C/R FAQ? BOY Subaru Conversions 14 11-07-2005 09:29 AM
Frankenmotor questions STiTuner Normally Aspirated with bolt-on Forced Induction Powertrain 20 04-11-2003 01:15 AM
