Old 08-19-2006, 11:56 AM   #1
ruggedman
Member#: 17590
2006 WRX Limited
WR Blue
Default 2006 WRX Sway Bar Questions
Well i've had the car for a few days so far, and in going from a car with a full suspension to this I've noticed a few things.
1) I feel that the springs and dampers on this car are about right for my needs (seems like i'm in the minority here, but i think they're actually pretty firm!)
2) I feel there's a pretty healthy amount of roll, but nothign that's too severe.
3) The f/r bias is really dummied down for the general ease of driveability.
So where can you help me? Well i'm an auto-x man, been at it for about 3 years now. I also use my car for everyday driving. As a result i've always been a fan of big bars and less spring. This subaru is no different, it seems that the swaybars are really the weak link here in the suspension. How big are the stock bars? Will the previous sway bar kits (whiteline, cusco, cobb, etc) fit an '06 WRX? It seems that endlinks and mounting should be upgraded to, do most of the kits come with this?
I've been leaning (no pun intended) at a front and rear bar. The stock rear looks absolutely rediculous for a 3200 lb car! Thanks for helping me with my newbie WRX questions. To let you know what my end goals are: this car will be set up for ESP so I'll be running R compounds, more boost, perhaps some alky injection, and a catted TBE.
ruggedman is offline   Reply With Quote
Old 08-19-2006, 12:03 PM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
your front bar is 20mm
your rear bar is 17mm
Any 2002-2005 wrx (not sti) sway bar kit will fit on your 2006
Some kits include end links. some do not
My WRX is setup 20mm front, 20mm rear
My 2001 Impreza is now 19mm front 21mm rear
I love em both
Jamie
Old 08-19-2006, 02:58 PM   #3
ruggedman
Member#: 17590
2006 WRX Limited
WR Blue
Good news! Thanks, now it's decision time. How much of a PITA are these to put in? The front one on my focus was god-aweful, had to drop the crossmember out and all that jazz.
Old 08-19-2006, 03:11 PM   #4
Dentspeed
Member#: 75360
2004 STi
I can change the front without taking off the subframe, but it takes some work. Take off both tires and you can do it. You might have to jack up one side of the suspension to clear the tie-rods.
My only other comment is be careful about putting too big a bar on the rear. You may end up lifting the inside rear tire in a turn.
Dentspeed is offline   Reply With Quote
Old 08-19-2006, 03:15 PM   #5
ruggedman
Member#: 17590
2006 WRX Limited
WR Blue
That's probably not a good thing to do with AWD eh?
Old 08-19-2006, 03:18 PM   #6
Dentspeed
Member#: 75360
2004 STi
No, it throws off the diff, plus you can't get as much power to the ground with a tire off. Having a stiffer front bar may help though. I have run my car without bars at all with 600/500 f/r springs, stock bars, and stock rear and 24mm front. You definitely want bars, but I would consider putting coilovers or stiffer springs and going with the stock bars. There are a lot of ways to handle this though.
Old 08-19-2006, 03:23 PM   #7
ruggedman
Member#: 17590
2006 WRX Limited
WR Blue
The big thing is I don't want to increase NVH, but i'd like better control. I'm thinking a 22/22 setup would be about right for me.
Old 08-19-2006, 06:14 PM   #8
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
ruggedman, I'm sorta in your position and goal for my 06 wrx wagon.
I just recently bought whiteline stuff which comes adjustable.
The front bar is wagon specific, and whiteline only has a 22mm as the largest available front. I got the adjustable one and it only has 2 adjustment positions.
The rear one is the same as sedan/wagon, and due to the size limit in the front on the wagon, I went with the 22mm adjustable.
chimchimm5 is offline   Reply With Quote
Old 08-19-2006, 07:48 PM   #9
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Yes, but it is worth the effort to remove the subframe to do the install. It makes it a lot easier & it will go a lot faster.
R&R the subframe is no big deal. It's just 12 bolts. And you don't have to remove the last bolt on either side. You can loosen those bolts and slide the subframe off since the subframe is slotted for those 2 bolts.
Samurai Jack is offline   Reply With Quote
Old 08-20-2006, 03:45 PM   #10
JnJassociates
Member#: 69539
2004 wrx wagon
red
Just my 2cents.
A stiffer rear bar like the 3 way adj. Whiteline bar (24mm), will not make a stock spring or even a STI spring, with stock struts car lift a wheel. It will allow you to tailor the car according to the course (autocross) all without affecting the ride... We have many customers with this set up and they love it!
A FRT bar is a great idea as well. A 22 mm frt bar will compliment the rear bar and help with lean and understeer. Frt and rear bars is the way to go for a balanced approach...
Don't forget about a good alignment! Most stock specs and settings on the car can be off, but the car will drive straight. A bit of negative Camber in the frt can only help (on a street car, about -1.5 degrees will work great)!
Bryan
JnJassociates is offline   Reply With Quote
Old 08-20-2006, 06:14 PM   #11
ruggedman
Member#: 17590
2006 WRX Limited
WR Blue
Originally Posted by JnJassociates
Just my 2cents.
Bryan
I couldn't agree more. I'm actually thinking the 24mm adjustable whitelines are what I'm going to go with both F&R.
Do the bars come with endlinks? Will I have to by those seperate?
Old 08-21-2006, 02:33 AM   #12
sperry7
Member#: 110079
06 WRX
Black on Black
^^ They come separate. I just ordered mine and some kartboy endlinks, expecting great things!
sperry7 is offline   Reply With Quote
Old 08-21-2006, 03:22 AM   #13
uathatis
Member#: 117300
ya i'm not surprised that a guy who bought a leather seated wrx would think the spring rate was stiff enough just playin
anyways if your looking for moderate difference cusco has a front bar thats 21 and also one thats 22(not sure if the 22 would fit though, its for the sti)
also cusco has a 22 mm rear adjustable bar thats pretty moderate, i've heard good things about it. its a good deal too.
you may like the stock struts.. i think there pretty good too, i still love having stiffer springs on though, i think that made a large difference, then again i'm only running a moderate 20f/20r mm bar setup ( i guess stiffening the springs made the effects exagerated?_)
uathatis is offline   Reply With Quote
Old 08-21-2006, 09:10 AM   #14
99ways2die
Member#: 96269
... blond with
long legs
Can't say how this works on pre-06, but I just did a set of sways on my 06 and I must comment that doing the front w/o removign the subframe is a "no go."
You simply have no access to the bolts which hold the brackets.
I was trying to weasel my way into doing it this way.......but there simply isn't enough room to get a grip with any wrench to break the bolts loose.
You could try, but the risk of excessive cursing and stripped bolts/knockles is extremely high.
...for what it's worth.
-99
99ways2die is offline   Reply With Quote
Old 08-21-2006, 11:22 AM   #15
JnJassociates
Member#: 69539
2004 wrx wagon
red
Endlinks are seperate, but many vendors can build you a package.
Bryan
02 WRX sway bar question bverschage Brakes, Steering & Suspension 4 11-26-2009 02:39 PM
2006 WRX sway bars Bernie1 Suspension/Brakes/Handling 1 11-06-2009 10:32 PM
Quick 2006 wrx sway bar question? Rock_Strongo Brakes, Steering & Suspension 4 05-23-2006 11:48 AM
[B]wrx sway bar question.[/B] siubaru Brakes, Steering & Suspension 1 04-19-2005 06:08 PM
Sway bar question, will a cusco front sway bar from a sedan fit on a wagon slprwrx Brakes, Steering & Suspension 5 05-10-2003 09:41 AM
