Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Engine/Power/Exhaust
Old 08-19-2006, 05:38 PM   #1
scooterforever
Member Sales Rating: (4)
Member#: 55011
Default USDM Throttle Body, JDM Throttle Body, USDM IACV
I have some stuff around the garage, time to clear some space. Note: these items were used, and were parts of other things I acquired over the last several months (e.g., namely, intake manifolds). I have not used these parts personally. I am selling:
1. a USDM WRX throttle body, without IACV (idle air controller). This is used, appears to be from an '02 (I got it from a guy off ebay who sold me his entire intake manifold, this part I don't need), and appears to be usable though it needs a good cleaning before use (grime, and bits of metal that appear to be turbo fins or aluminum or something... guy must have blown the motor).
$70 shipped
2. a USDM idle air controller, currently attached to TB #1 above. I am unaware of its condition. These are the parts that over time get dirty and sometimes just need to be replaced, though often they can be cleaned (I wrote the sticky thread in Service and Maintenance on cleaning these bad boys). When cleaning fails... replacement is the recourse. Dealers charge > $300 for this part. For $70, you can see if this one works for your problem.
$70 shipped
I'll let 1 and 2 go together for $120 shipped, a savings of $20!!!
3. a JDM throttle body with JDM IACV. I am not sure whether this is JDM V 7 or V 8, but it's the throttle body attached to the TGV-less straight through JDM STI red intake manifold, the ones that come with the pink injectors. I am switching to the TGV'less manifold, but am re-using my stock throttle body, so this one can go. Note: there only appears to be one cable connection for the throttle, not two in the case of USDM applications (throttel + cruise). Please research this throttle body before purchasing. Is used, appears in good condition.
scooterforever is offline   Reply With Quote
Which ECU for USDM STI with cable throttle body brazymstrp Subaru Conversions 23 10-21-2010 03:58 PM
WTB: 02-03 wrx Throttle body with accessories or just IACV dukeduster Private 'Wanted' Classifieds 2 07-20-2007 12:23 PM
FS USDM WRX intake manifold + Throttle body CHEAP elsanto Engine/Power/Exhaust 16 08-10-2006 04:10 PM
FS: Aquamist 1s, USDM STi Heads, LGT Throttle Body, ect.... ShaggyGT South East Region Private Classifieds 13 07-29-2006 07:22 PM
USDM STI I/C...throttle body hose ? silverstreakwrx Factory 2.0L Turbo Powertrain 5 08-02-2005 01:33 PM
Message Board Statistics All times are GMT -4. The time now is 03:15 AM.
