08-19-2006, 06:35 PM | #1 |
Member#: 55935
Vehicle:2004 Impreza WRX PTE BB 67mm Powered |
Aem Ems + Avcs
OK, i posted a thread on aempower.com. But i figured nasioc sees more traffic then that so i will post here as well.
My current setup on my 2004 Subaru Impreza WRX: -Axis Stage 3 block -JDM Version 7 ported STi heads -Ultimate Racing T04S 61mm turbo -All supporting mods. Is there anyone that has parameters of how to get AVCS working via AEM? We dont want to go into it and do trial and error, one small error when messing with cam timing could result in engine failure. So my question is, is there a way someone can show me a stock ecu map of how AVCS works on a stock ecu? That would give us an idea of how exactly it works, giving us a better starting position on creating a map. Any info will be much appreciated. -Keith
08-22-2006, 11:42 PM | #2 |
Member#: 55935
Ya, apparently noone has done this?
08-23-2006, 01:19 PM | #3 | |
Member#: 94494
NWIC
Vehicle:2005 Element 92x Black |
I don't know anybody who has done this via aem. Many of us have used it via the Hydra. I know the AVCS advances the timing 5 degrees, I believe. How it's tuned, I don't know. Good luck. |
08-28-2006, 06:35 PM | #4 |
Member#: 94494
NWIC
The only people I've seen do this is with a Hydra, for a stand alone.
08-28-2006, 07:00 PM | #5 |
Member#: 56468
NWIC
Vehicle:04 Improved STI Dirty White |
No one will share their map as it's just too dangerous to do that. You really need to sneek up on the values. I tuned mine, but I must say without a dyno you just don't know a whole lot about how much you are improving. I had Phil's map to give me a basic outline too, that help tremendously.
OK, I don't want to leave you high and dry so here is an example: http://www.forums.evolutionm.net/att...chmentid=93138 This is a MIVEC map for the Evo, but the basic shape and principles remain the same. Your peak intake advance will occur in the mid RPM range. You want avoid too much advance at low RPM as you can cause the car to buck. No advance at idle. Look at that map, the load values are basically 100 equals 1 psi and 200 equals about 16-18 psi. You'll see the peak values occur mid RPM and "in boost". In high vacuum to early boost the values are lower. All the maps I've seen has this basic shape more or less. My current map is much like the EVO's where whole regions are basically at the same level of advance and there are some transition values in between basically "plateaus" of advance values. There is 20 degrees total advance on the STI. In the Hydra this is broken into 40 steps or 1 step = 0.5 degrees of intake cam advance. I tuned by increasing of decreasing in 2 units steps or 1 degree changes, so very slowly. If you advance too much at mid-high RPM the cams will "flutter". The sound is unique. It sounds like someone opened a little door on the motor and all the sudden you can hear the valves opening and closing (because they are). Based on tuning with a cold car the flutter is somewhat a function of the oil pressure, higher oil pressure, more likely to reach "flutter" pressure. This fact may also suggest that the weight of your oil may affect AVCS tuning as well even though with the Hydra it is closed loop. Maybe we should start an AVCS tuning thread and get a bunch of people with their experience. I've been able to slightly improve boost onset, and anyone who has turned the AVCS off can tell you how much it affects lag. |
08-29-2006, 12:31 AM | #6 |
Member#: 56468
NWIC
I started an AVCS tuning thread in the main/general Tuning forum.
08-29-2006, 12:47 AM | #7 |
Member#: 7555
South East
Hmmm, is there a Start up cal for the Subaru. I remember seeing one but not sure. I'm actually tuning a Honda Motor right now so I've got a some insight with the AEM ECU. If it was me, I woud leave the AVCS alone until you've dialed in a decent map above and beyond the startup map. Once that's out of the way, start adding in advance (I think 15* max is possible). This is of course assuming you're comfortable with all of the various data feedback (knock activity, AFR, Timing, etc) which is really the basics for tuning any other ECU.
08-29-2006, 03:30 AM | #8 | |
Member#: 55935
Excellent. I'm waiting for this 'hurricane' to blow over, then i will start the tuning process again. Thanks for the info, hopefully we can get some more ppl to comment on this topic. |
08-29-2006, 04:38 PM | #9 |
Member#: 45494
Vehicle:95 impreza L awd green |
Any idea of what the signal is to control the cams? 5v, pulsed 12v signal, pulse width signal?
08-29-2006, 06:16 PM | #10 |
Member#: 55935
06-01-2007, 07:39 PM | #11 |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
bumpity for an update...
really torn between hydra and AEM because of this. get a price break on AEM and like some of the features (real antilag and 4 channel EGT especially) |
08-07-2008, 08:58 AM | #12 |
Member#: 120339
RMIC
Vehicle:02 WRX Alliance Motor Sports |
any updates on this? its been awhile.
08-07-2008, 05:54 PM | #13 |
Member#: 87653
South East
Vehicle:97 Supra / 17 GTR 16 Z06 / 07 STI / 05 Evo |
car is back to stock being sold.
08-07-2008, 06:59 PM | #14 |
Member#: 55935
08-09-2008, 10:27 AM | #15 |
Member#: 87653
South East
yeah.. <3
08-09-2008, 08:58 PM | #16 |
Member#: 120339
RMIC
Did you ever get it to work with AVCS? How much are you selling the AME EMS for?
08-10-2008, 01:14 AM | #17 |
Member#: 55935
08-10-2008, 11:13 PM | #18 |
Member#: 120339
RMIC
Thats the solution for everything More Boost!
08-11-2008, 09:08 PM | #19 |
Member#: 67958
Vehicle:MY96 Time Attack and 06 STI daily |
Since this got brought back up and it applies to the new AEM EMS for STi...
Yes it comes with a startup cal. The AVCS solenoids receive switched 12+ and ground. Depending on which EMS you're using power or ground may be pulsed, generally ground with a PWM out (stock and AEM EMS work this way). The RH and LH cam sensors are hall effect units which receive 5+ switched power. All those are involved in cam control since it operates in closed loop with the AEM EMS, same as stock. You'll have to play with the values yourself to optimize them, but the startup cal has a base table already set up. Like most standalones, the potential is there for you to pull a bonehead move and really screw something up. If you change the table for VVC#1, make sure you duplicate the changes in VVC#2 so both sides of the engine operate the cams the same. The cruise control stalk is used to calibrate the DBW throttle system which is a cool little feature and the EMS even controls the TGVs, although I can't imagine a car with a standalone still having the TGV guts intact. Last edited by Innovative Tuning; 08-11-2008 at 09:25 PM. |
08-24-2008, 12:56 PM | #20 |
Member#: 18384
Vehicle:2004 STi: 580 AWHP Java Black Pearl |
Mike, does the new AEM DBW unit for the STi run low impedance injectors as well as high impedance ones or do you still need an upgrade?
Thanks, Russ |
08-25-2008, 09:12 AM | #21 |
Member#: 67958
It doesn't drive them directly. Resistor boxes out of old DSMs and Accords are 5-25 bucks.
08-25-2008, 10:27 AM | #22 |
Member#: 18384
Good to know!
I did some digging on Injector Drivers vs. resister boxes. There are a couple popular aftermarket Low Impedance Injector drivers out there. One from AEM that can do 10 injectors (overkill) for $300 and one from FJO that drives 4 injectors (perfect) for $150. These are true Peak & Hold drivers, so I imagine would be better than a resister pack. Sounds like you can get away with resister packs on smaller (850cc and less) injectors, but for larger ones, you want the full power of the peak & hold driver. Thanks! Russ |
08-26-2008, 11:02 PM | #23 | |
Member#: 107569
NWIC
Vehicle:1998 Forester S SRP |
08-27-2008, 12:31 AM | #24 |
Member#: 120339
RMIC
here is what i have found about AVCS and the 30-1810u
The AVCS will allow you to advance the intake cams up to 40 degrees at lower engine speeds which will greatly increase the amount of low end torque the engine makes. This will spool the turbo sooner and makes the low end throttle response better because the engine is making more power. With the AVCS properly tuned on a stock USDM STi, I've seen gains of 30-40 ft.-lbs. of torque in the lower RPM ranges as compared to having the AVCS deactivated. On Nissan VQ engines, I've seen gains of over 100 ft.-lbs. with the cam timing properly tuned vs. deactivated. You will want to use the AVCS, unless you like not having more power. To use the USDM STi motor's AVCS using the 30-1810 EMS, you will need to make the following changes: 1. The JPT2 jumper must be changed inside the EMS to switch the cam input from magnetic to hall effect as the cam sensors are different between the '02 WRX and the STi. 2. Wire the signal wire from the right hand cam sensor to the CAM input (B1) on the 1810. 3. Wire the signal wire from the left hand cam sensor to the VSS input (A1) on the 1810. 4. Wire switched 12V & ground to both the cam sensors to power them. 5. Wire the right hand side AVCS solenoid to switched 12V and the Injector 9 output (E16/C16) on the 1810. 5. Wire the left hand side AVCS solenoid to switched 12V and the Injector 10 output (E17/C17) on the 1810. With it wired in this manner, you can then copy over the VVC settings from the 30-1820 base map to get it going. |
08-27-2008, 10:24 AM | #25 | |
Member#: 33782
the more of those you choose, the less room you have to play with cam timing and more of a gamble AVCS becomes. back to on topic...sorry |
AEM EMS -Trade- for Hydra EMS, 02-05 wrx | AwdBoostCreep | Engine/Power/Exhaust | 2 | 05-22-2009 11:14 AM |
FS: (Toronto) AEM EMS + AEM UEGO Wideband | LuvJuggs | Canada Region Private Classifieds | 13 | 04-14-2009 01:42 AM |
Hyrda EMS, AEM EMS, or upgrade to sti ecu/wiring harness | 03SuBbYWrX | Other Engine Management | 3 | 11-27-2007 04:47 PM |
AEM Products - AEM EMS, Tru-Boost, UEGO, Tru-Time and gauges!!! | HorsepowerFreaks | Engine/Power/Exhaust | 5 | 11-20-2006 05:40 PM |
