View Poll Results: Which gauge setup should I go with?
Option 1: Greddy boost, Omori EGT and Oil pressure 3 25.00%
Option 2: Greddy boost, Omori EGT and Oil TEMP 0 0%
Option 3: Omori EGT & Oil temp and pressure. Greddy boost on the column 1 8.33%
Option 4: All 3 Omori's & trade Greddy boost for a 45mm Omori boost (on the column) 1 8.33%
You're an idiot an you just waisted 3 min of my life 7 58.33%
Voters: 12. You may not vote on this poll
Old 08-20-2006, 03:48 PM   #1
wrxskier18
Member#: 88005
2002 WRX PSM
GS500
Default Poll: help me decide my gauge set up.
For some reason, I cannot make my decision for my gauge set up. Help me by voting and let me know why if you have the time...I know it's a kinda stupid discussion, but I just cannot decide.
I have a 02 wrx w/cobb stg 2. I have a 60mm Defi triple gauge pod with the following gauges: Omori oil temp, oil pressure, and EGT and a Greddy electrical boost gauge. My ideal setup would include a Omori Boost gauge to match, but they stopped making them and I cannot find one. All are 60mm and the Omori's have a peak/warning/hold feature.
Here are my options
Option 1: This is my current set up - Greddy boost, Oil pressure, EGT in the Defi pod and that's it. Sell the oil pressure gauge
Option 2: Greddy boost, Omori Oil temp, EGT in pod. Sell the oil temp gauge
Option 3:
All 3 Omori's in the pod and the boost on the steering column (would block water temp and and gas gauges on stock cluster)
Option 4: All 3 Omori's in the pod. Sell the Greddy boost gauge and buy a Omori 45mm boost gauge to match and mount it on the column w/ less obstruction.
Thanks for your input!
wrxskier18 is offline   Reply With Quote
Old 08-20-2006, 05:50 PM   #2
MobbDeep222
Member#: 98199
2007 Impreza WRX STi
CGM Cosworth GT4094r
None of them. Maddad Clarity FTW
I got the new surround for the speedo cluster and have EGT and boost in the corners. Gauges match the speedo lights well, except needles are red, but good luck finding yellow needles in AM gauges.
MobbDeep222 is offline   Reply With Quote
Old 08-20-2006, 05:53 PM   #3
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
I voted option 4, but I am almost positive that nobody sells a single gauge pod A-pillar... So you'd need at least two gauges to put there. If I had to get 4 gauges, I'd go with two in the bezel pod, and two on the A-pillar. But I stuck with only three gauges - Boost and EGT in the bezel pod, and WBO2 in a single DIN slot where the radio was.
And it's "wasted."
RP31 is offline   Reply With Quote
My hood was keyed help me decide my next step SlverEJ20 Interior & Exterior Modification 31 11-03-2009 08:18 PM
Poll: Help me decide path of repair zmaster Off-Topic 5 08-25-2009 06:04 PM
Help me decide on a set of headlights! atenzany62 Member's Car Gallery 36 02-12-2009 01:33 AM
Help me finalize my FPGreen set-up, please? UltimateLurker Factory 2.5L Turbo Powertrain 54 07-31-2007 01:39 PM
pls help me decide my stage 1+ parts no_rex_yet Factory 2.0L Turbo Powertrain 3 07-15-2003 02:13 PM
Message Board Statistics All times are GMT -4. The time now is 02:23 AM.
