Old 10-27-2001, 02:24 AM   #1
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
Default Vibration 80-100MPH
I get a vibration somewhere between 80-100MPH. It feels like the drivetrain is out of balance. Is this normal? Does anybody else have this quirk? Thanks.
LVSUBARU is offline   Reply With Quote
Old 10-27-2001, 02:29 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
if it was driveline i'd expect you'd see it more between 55-65....have you had your tires high speed blananced??
Jeremy
Old 10-27-2001, 03:22 AM   #3
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
You might want to post htis in the general forum to see what responses you get. I haven't riven my car in such a long time I don;t even remember anything about driving it
Eric
Eric SS is offline   Reply With Quote
Old 10-28-2001, 04:03 PM   #4
SGOSWRX
Member#: 10921
04 04 STi
12.8 @ 105 mph
How many miles on the current tires. Most vibrations are a result of uneven tire wear or a tire that is out of balance.
I had brand new tires put on my z28 and it had a vibration at 80mph. I had the tires check out and put on a computerized balancer and the tires where not in balance. This was a flaw in the tires themselves. The were made that way and couldn't be balanced perfectly.
I also had a bad vibration at speeds of 90mph + in my z28 when I had a crack housing around the tranny. I cracked it on a dyno when the stapped my car down to hard. So it is very possilbe to have a vibration coming from the tranny/driveshaft but thats usually not the case.
SGOSWRX is offline   Reply With Quote
Old 10-28-2001, 06:34 PM   #5
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
The speed linit is 75 mph and below in most places.
You should not be experiencing this vibration.
blaster88 is offline   Reply With Quote
Old 10-28-2001, 09:18 PM   #6
preza
Member#: 1454
2000 2.5 RS-T
preza is offline   Reply With Quote
Old 10-28-2001, 09:48 PM   #7
Andrew
Member#: 1170
2005 STi
i used to have this weird ass vibrating feeling when i was around 60+mph. it made me scared to drive the car. i checked out the suspension and there was one bolt that was loose. it was the bolt holding the a-arm and the brakes together. when i tightened them both (driver and passanger on the front) the car felt WAY better. it allowed me to regain the confidence i had lost in the car.
check it out, it could be the same problem...never know.
good luck. you could also always take it to the dealer.
Andrew is offline   Reply With Quote
Vibration from 55-80 MPH Jard Brakes, Steering & Suspension 3 03-18-2004 09:23 PM
vibration above 50, really bad above 80? Jared703 Brakes, Steering & Suspension 5 03-11-2004 05:22 PM
Vibration at 80 mph jetsiphon Rocky Mountains Impreza Club Forum -- RMIC 5 04-10-2003 01:24 AM
vibrations between 70 and 80 fabulous12 Normally Aspirated Powertrain 14 10-15-2002 12:24 AM
Vibration at 80 or so.. Branwell Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-01-2001 10:50 PM
