Old 02-18-2010, 12:36 AM   #276
swilli42
Member#: 128027
2006 WRX
I am doing my vf39 swap tomorrow and have a grimmspeed 3port bcs, but after reading the warnings in the instructions I have to wait until I can get protuned to run the bcs. So looks like I will be trying to find a #57 bit tomorrow
swilli42 is offline   Reply With Quote
Old 02-18-2010, 02:29 AM   #277
neg_matnik
Member#: 132389
2006 WRX Wagon SGM
2003 SV1000S, 2014 DL650
I bought a Tactrix cable a while back and I'm now running the Stage 3 XPT map with a VF43 and a Grimmspeed BCS. The map calls for a GM 3-port BCS but I've very slightly altered it to run the Grimmspeed BCS instead. The car runs fine and boost is right on target. But, if you're going to get protuned, then, indeed, you're going to have to get by with a pill until you're ready for the protune. I hope you'll find that #57 bit for your install tomorrow and good luck with the install.
neg_matnik is online now   Reply With Quote
Old 02-18-2010, 07:42 PM   #278
swilli42
Member#: 128027
2006 WRX
well I had no problem finding the 57 bit....the problem came when I attempted to get the pill out of the line and ripped it. This sucks. Do I have to replace the hose with a subaru part or can I just pick something up from the local auto store? PLEASE ANYONE HELP!!
Old 02-18-2010, 07:51 PM   #279
Tahoe SC
Member#: 131996
2006 CGM WRX Wagon
Yimi Tuned 296AWP/322TQ
It's just a vacuum line. get it in the right size from your local napa, pepboys, etc. and you're good to go!
Tahoe SC is offline   Reply With Quote
Old 02-19-2010, 12:05 PM   #280
wrxsti04gt35r
Member#: 193028
2004 Impreza wrx STI
Nice thread. Maby it will convince me to get another wrx and go vf39.
wrxsti04gt35r is offline   Reply With Quote
Old 02-19-2010, 01:07 PM   #281
Nickarub
Member#: 230509
06 vf39 wrx
ugm
I did it!! not bad for a noob. thanks for all the info guys. it was a relativly smooth install. NO Boost creep, No overboosting, Im hitting Target Boost. dang she pulls hard. in first gear she wanted to go sidways. The pill thing wasnt to bad. i left it in the line and just drilled it.
Nickarub is offline   Reply With Quote
Old 02-19-2010, 02:23 PM   #282
Tahoe SC
Member#: 131996
2006 CGM WRX Wagon
^ good going!
What map are you running with it? I ran the COBB OTS map and it was horrible compared to the OTS Stage II map i was running...and tons worse than the Protune Stage II map.
Old 02-19-2010, 02:33 PM   #283
Nickarub
Member#: 230509
06 vf39 wrx
ugm
Originally Posted by Tahoe SC View Post
^ good going!
ots vf39 93 octane. she does feel a little laggy. and a little less throtle response than the stage2 ots.. i think im going to go clark turner when i get a few more bucks.
Old 02-19-2010, 03:01 PM   #284
Tahoe SC
Member#: 131996
2006 CGM WRX Wagon
yea i couldn't stand how it took forever to spool up and how all the pull was way up in the RPM. got a protune within 2 weeks because i couldn't stand it.
Old 02-19-2010, 07:50 PM   #285
Jkmaynard
Member#: 155178
2005 STI 385WHP
Aspen white
Nice guide looking to do this in the next couple of weeks
Jkmaynard is offline   Reply With Quote
Old 02-19-2010, 10:03 PM   #286
swilli42
Member#: 128027
2006 WRX
replaced my vac line that got ripped, drilled my pill. now I am ready to put the line back in, tmic, top it off and reflash in the a.m.. I cant wait!!!!
Old 02-21-2010, 01:44 AM   #287
Nickarub
Member#: 230509
06 vf39 wrx
ugm
ok i got dynod today. mustang dyno. hitting 17.4 boost at 265hp/267ft.lbs. thats with the cobb ots map.. i think i did well considering
Old 02-22-2010, 04:34 AM   #288
amroof
Member#: 211224
2005 Saabaru
Who knows
hey man if you have a cable and the computer with software to do it you can have braden from xpt tuning flash your ride. i have the same setup except i have a cai and a walbro fuel pump and he changed my map quiet a bit form the gm bcs. so good luck and give him a try
amroof is offline   Reply With Quote
Old 02-22-2010, 10:28 PM   #289
swilli42
Member#: 128027
2006 WRX
everything went well on my install. Only little hang-up was, I was accidentally shipped p'n'p manifolds for a 2.0 instead of my 2.5 But now I have an accuse to work on my car again this weekend! The car runs good and hits target boost. But I must agree with everyone who thinks the cobb map is...
wait for it.....wait for it.....almost.....not quite....ok....boosting...redline
I talked to clark yesterday, gonna get tuned this weekend.
Old 03-13-2010, 08:42 PM   #290
flimflamman
Member#: 147328
2007 WRX
FlimFlamRacing
Thank you OP, and other contributors. This thread helped a lot with my turbo swap.
flimflamman is offline   Reply With Quote
Old 03-16-2010, 12:21 PM   #291
mQumQu
Member#: 190927
2006 WRX vf39ed
Hi i have a 2 questions
I am going to have vf39 along with sti TMIC installed this saturday.
I wana make sure I have all the parts.
I will be running cobb ofs map
Question 1) THe vf39 comes with the stock hose along with the restrictor pill, should i use that pill off the vf39 or should i get a new pill with the cobb suggested size.
question 2) I have a STI TMIC that comes with the y-pipe and the 90degree elbow, will that fit perfect on the vf39 or do I require to extend it?
Thanks.
mQumQu is offline   Reply With Quote
Old 03-16-2010, 02:25 PM   #292
amroof
Member#: 211224
2005 Saabaru
Who knows
Okay you should also think about getting some new gaskets to save you from the unexpected. If the vacuum tube is the stock tube that came on the VF39 then you should be fine to directly install the turbo. The intercooler should bolt in to place perfectly and you shouldn't have any problems with them matching up.
Now a suggestion I would highly recommend that you purchase a 3port BCS some day as it gives you better throttle response and faster spool. I have a gs bcs and it is night and day difference over stock. And seeing your gonna need a tune anyways its worth the extra 80 bucks for a 3port bcs.
GL with the install hit me up if you have issues as I have done many of these swaps
Old 03-22-2010, 06:06 PM   #293
mQumQu
Member#: 190927
2006 WRX vf39ed
Thanks, Finally got the swapped done, everything fits perfectly. Other than the STi Intercooler hitting the strut tower bar here and there.
But I got a question does the vf39 whines a lot louder than the td04?
Because I am hearing a lot of the whinning noice.
Yes its defintly a great upgrade with the extra power on top. However I was expecting a bit more from it. Maybe its just cobb's off the sheleve stage3 map. Or I should of installed the 18/20g
Old 03-22-2010, 06:34 PM   #294
flimflamman
Member#: 147328
2007 WRX
FlimFlamRacing
Does your sti tmic hit the bar when you get on it?
Yes it is the Cobb ots map that sucks. Get a protune and you will have much more fun with it.
I noticed the vf39 seems to whine a little louder than the td04, but isn't anything dramatic.
Old 03-22-2010, 06:54 PM   #295
mQumQu
Member#: 190927
2006 WRX vf39ed
ya it makes this stupid vibrating noice here and there
I just went to home depo and got one of those hot/cold water tube protector and wrap it over the bar for now.
I got a question too.
I also had the cobb sf intake installed from before. But now the by pass sound is like 2x as loud when i have the td04, should i be worried or I am fine with it?
It sounds like a freaking BOV now..
thx
Old 03-22-2010, 07:18 PM   #296
flimflamman
Member#: 147328
2007 WRX
FlimFlamRacing
Personally, I would get rid of the Cobb intake. The stock air box with a k&n filter (or similar) works great for this mod.
Old 03-22-2010, 07:56 PM   #297
amroof
Member#: 211224
2005 Saabaru
Who knows
^^ it depends on the map you might run later down the road. the intake should be okay and you shouldnt worry about the whine or the bov its just and added effect for you.
and the cobb ots map sucks horribly wait till you get a protune or real tune for the car it will be even better. and by the way sick looking car!
Old 03-25-2010, 08:04 AM   #298
mQumQu
Member#: 190927
2006 WRX vf39ed
Default Re: VF39 swap instructions w/pics
^^. Hi I just wanna know what dyno numbers will I be pitting down on vf49 Cobb off the shelve map. I try to push it further last night and it was pretty fun to play with. I just wana compare the power lvl from a stage 2 wrx MY06. Thx
Old 03-25-2010, 10:28 AM   #299
amroof
Member#: 211224
2005 Saabaru
Who knows
hey man so with a TD04 stage 2 map i was putting down 250hp and 315 trq, and now with vf39 im putting like 330hp and 320 trq on an opensource tune. those are conservative numbers as i havent had the car on the dyno yet. those are ffrom airboys spread sheet. so keep pushig it
edit: i think you will be like 289 and like 305trq with the ots map
Old 03-25-2010, 04:51 PM   #300
xTourniquet
Member#: 177477
2006 WRX Limited
Do you have a WRX 5 speed transmission? How is it holding up with the new power levels?
xTourniquet is offline   Reply With Quote
Trunk Swap Instructions Sti-lysh Interior & Exterior Modification 15 01-11-2006 07:41 AM
N00b JDM STi swap instructions? perret318 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-31-2005 06:26 PM
clutch swap instructions? sailil Mid Atlantic Impreza Club -- MAIC 5 08-03-2004 08:03 AM
Trunk and lock swap instructions? Fair Oaks STI Interior & Exterior Modification 2 08-16-2003 01:59 PM
Bring back the bumper swap instructions! AccidenT General Forum Archive 1 03-16-2001 11:33 PM
