Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 03-02-2007, 12:16 PM   #51
06rexwagon
Member#: 114730
2006 WRX Limited Wag
Originally Posted by t3ch9 View Post
i drive a 02 wrx. Do I have to purchase pink injectors or is there a cheaper alternative. So the stock fuel pump will work with this turbo? Will the cobb 2 reflashed ECU work with the new turbo or should i purchase an access port?
Your stock injectors won't work. I'm not sure which one's you should get, but the pinks or the new '06 injectors flow enough, just not sure if they'll fit.
Fuel pump, I think you'll need a walbro
Your stage 2 reflashed ecu will definitely not work with this turbo.
06rexwagon is offline   Reply With Quote
Old 03-02-2007, 03:48 PM   #52
sluflyer06
Member#: 111641
08 BMW 135i MSport
tuned/full exhaust/intake
both the pinks and the 06' oem injectors will fit your car and you will need them, oh and yea you'll need a fuel pump as well...either the pump off the 06' a STI pump or (and best choice) a Walbro 255 for like $90.
you could also search on modding your stock injectors if your going for cheapest route possible.
adn as said ^^^ your current reflash won't work with the vf39 and neither will any of Cobb's shelf maps. The only year cobb has shelf maps for the vf39 is the 06-07 wrx.
sluflyer06 is offline   Reply With Quote
Old 03-06-2007, 02:10 PM   #53
amayhem
Member#: 137236
Default hey
does anyone know if this install will work with a 06 wrx upgrade to a STI TMIC and a FP18G? cuz ima do this tomorrow.. and i dont have any dyi... if anyone knows where ican find one.. please let me know
amayhem is offline   Reply With Quote
Old 03-09-2007, 10:07 AM   #54
sluflyer06
Member#: 111641
08 BMW 135i MSport
yes it will...it should work for almost all stock mount turbos out there.
Old 03-09-2007, 10:42 AM   #55
SixSick6
Member#: 76658
Where is the link on Cobbs website?
Just so you guys know, the brass restrictor is common with IHI turbos because their wastegates are so small and open at a relatively low threshhold. The brass restrictor is there to even the boost pressure out. If it weren't there, the pressure leaving the compressor would hit the wastegate at once and open it that much earlier than it already does. The stock wastegate on the RHF55 series starts to open at 8 psi and is fully extended by 10 psi. Putting the restrictor in place changes the dynamic of how/when the wastegate diapragm operates when it recieves it's signal.
Here is more info from my own forum. We have IHI turbos too:
http://www.mx6.com/forums/showthread.php?t=104772
Here is a simple test for your own wastegates:
http://www.mx6.com/forums/showthread.php?t=118043
And here is my wastegate thread:
http://forums.nasioc.com/forums/show...php?p=17298704
SixSick6 is offline   Reply With Quote
Old 03-11-2007, 05:39 PM   #56
jeeps1998
Member#: 99473
2006 WRX TR stg 2
SCribed
jeeps1998 is offline   Reply With Quote
Old 03-14-2007, 11:23 AM   #57
Weakness
Member#: 92588
2005 STi
I hope you are kidding, but for post count sake (hehehe) it is http://www.cobbtuning.com.
Weakness is offline   Reply With Quote
Old 03-18-2007, 08:39 PM   #58
06rexwagon
Member#: 114730
Originally Posted by tankerWRX View Post
I think this is the one you need. http://www.subaruparts.com/cart/?pn=15197AA060
Part #15197AA060
As for modifying it you basically just drill a hole because the spacing for the bolts are different.
That's the same one as the TD04. I just bought it and it's not for the VF39 so now I have to modify it or order another.
Old 03-22-2007, 01:02 PM   #59
NRTmotorsports
Member#: 16517
09 WRX
Dumb question, but if I have a VF39 with the pill in the vacuum line, theres no need to drill? Drilling is only neccessary if sawpping the stock TD04 pill to the VF39 correct? Just wanted to clear that up, its going in this weekend. Thanks
NRTmotorsports is offline   Reply With Quote
Old 03-22-2007, 01:49 PM   #60
06rexwagon
Member#: 114730
I believe the pill that comes with the vf39 is slightly larger than the #57 drill bit that cobb uses. You may have trouble hitting target boost. I'm installing my vf39 next week with the vf39 pill and I'll let you know how it does. Since I'm tuning it myself, I can adjust my WGDC's if I don't hit target boost.
Old 03-22-2007, 03:16 PM   #61
NRTmotorsports
Member#: 16517
09 WRX
Im still confused a bit, if I order a stock vacuum "T" with the pill do I still need to modify?
Old 03-22-2007, 03:20 PM   #62
06BlackSTIwith550WHP
Member#: 116325
2006 BLACK STI
UR Rotated GT30R
Originally Posted by djennison View Post
+1 for swapping turbos with flip flops on!
thats funny, when i work on my car in my garage I work barefoot, whenever someone walks the first thing I hear is why the hell are you barefoot?
06BlackSTIwith550WHP is offline   Reply With Quote
Old 03-22-2007, 09:03 PM   #63
E6V6I6L
Member#: 123710
I spoke with cobb before I did mine and they told me first hand that an 04/05 sti restrictor pill is the right size. I decided to drill mine cuz the bit was only
0.70 but if a local dealer has one might as well get it.
E6V6I6L is offline   Reply With Quote
Old 03-22-2007, 09:29 PM   #64
sluflyer06
Member#: 111641
08 BMW 135i MSport
i would start smaller (stock td04 pill) and work your way up to the #57...i've been running the cobb stage 3 shelf map for a month and a half or so and can't hit target boost whether its 83F or 10F in any gear....i ordered the stock vacuum line with pill at the parts department at my dealer and is coming in tomorrow, i'm gonna run it stock size and see what happens....the highest boost i get is about 15psi in 4th gear.
also for you guys already running the 39's in your 06-07 when are you getting full boost? i'm not getting full spool until around 4K.
Old 03-22-2007, 09:39 PM   #65
06rexwagon
Member#: 114730
My coworker hits 16.5 lbs by 3200 rpm on his vf39 with a fmic. That's with a protune though.
Old 03-22-2007, 09:39 PM   #66
06rexwagon
Member#: 114730
Good to know. Mine came with all the vacuum lines and the stock sti boost solenoid.
Old 03-23-2007, 09:17 AM   #67
ray101381
Member#: 131327
2012 Audi A7
2013 Raptor, 2013 Ducati
i got a used vf39 off a 06 sti, does that means i should use my stock vacuum line and drill it to the #57 bit or use the vacuum line that came with the turbo?
ray101381 is offline   Reply With Quote
Old 03-23-2007, 09:25 AM   #68
biker921
Member#: 118236
2004 Audi S4
Wow, now that's a funny thing. Google has a search bar that does most of the hard work. A person just need to know the name of what they're looking for. Come on now sixer.
biker921 is offline   Reply With Quote
Old 03-23-2007, 09:28 AM   #69
biker921
Member#: 118236
2004 Audi S4
I'm running pretty much stock as far as intake/exhaust goes on my 06 WRX. Will I need to upgrade my fuel pump or injectors for this swap?
Old 03-23-2007, 03:13 PM   #70
ray101381
Member#: 131327
2012 Audi A7
you'll def need a new fuel pump
Old 03-23-2007, 04:05 PM   #71
biker921
Member#: 118236
2004 Audi S4
Any you'd recommend over another?
Old 03-24-2007, 12:10 PM   #72
biker921
Member#: 118236
2004 Audi S4
Would just the STi Pump work with injectors?
Old 03-24-2007, 12:26 PM   #73
TopEndPull
Member#: 126112
93.5 Toyota Supra
Red
just get a walbro, its only a 100 bucks.
TopEndPull is offline   Reply With Quote
Old 03-24-2007, 04:24 PM   #74
06rexwagon
Member#: 114730
VF39 went on yesterday. Shredded my hands up pretty good. On the oil drain rubber line, I used a real screw type hose clamp to hold it to the hard line on the turbo and it kept it in place. I'm running the sti pill and hitting target boost.
Old 03-25-2007, 06:54 AM   #75
alpnwhite96
Member#: 115482
2006 WRX Limited
bleh my setup is only hitting about 13.5 psi, read from the accessport.
alpnwhite96 is offline   Reply With Quote
Trunk Swap Instructions Sti-lysh Interior & Exterior Modification 15 01-11-2006 07:41 AM
N00b JDM STi swap instructions? perret318 Factory 2.0L Turbo Powertrain 5 03-31-2005 06:26 PM
clutch swap instructions? sailil Mid Atlantic Impreza Club -- MAIC 5 08-03-2004 08:03 AM
Trunk and lock swap instructions? Fair Oaks STI Interior & Exterior Modification 2 08-16-2003 01:59 PM
Bring back the bumper swap instructions! AccidenT General Forum Archive 1 03-16-2001 11:33 PM
Message Board Statistics All times are GMT -4. The time now is 01:28 AM.
