Old 08-19-2007, 11:48 PM   #101
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Originally Posted by Matth3w View Post
Looks like it. I bet shipping is more than the price of the bit.
06rexwagon is offline   Reply With Quote
Old 08-19-2007, 11:51 PM   #102
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
Probably...I didn't go that far yet. Wanted to make sure first. So all I should have to do is drill the pill...the oil return was said to work (how can you tell from the picture?)...so I should be good.
Matth3w is offline   Reply With Quote
Old 08-19-2007, 11:54 PM   #103
untuchablez_WRX
Member#: 153890
2007 Subaru WRX/STI
Satin White Pearl
The picture shows the oil return line. Just double check making coolant lines are tight and the oil return line is tight on the turbo. Drill the pill and your good to go.
I have a vf39 swap on my WRX. I hit perfect target boost
untuchablez_WRX is offline   Reply With Quote
Old 08-20-2007, 12:03 AM   #104
Newera09
Member#: 125294
Im not sure if I misread but if I have a '06 wrx and install the VF39 on there does the Cobb AP V1 have an OTS I can use til I get protuned?
Newera09 is offline   Reply With Quote
Old 08-20-2007, 04:48 AM   #105
TicketMike
Member#: 123856
2006 wrx??
amazing black swirl paint
Yes. Cobb has a map for the VF39 that can be used until you get to your tuner.
edit: here is the link http://www.accessecu.com/accessport/...06WRXMaps.html
TicketMike is offline   Reply With Quote
Old 08-22-2007, 03:41 PM   #106
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
Originally Posted by sluflyer06 View Post
both the pinks and the 06' oem injectors will fit your car and you will need them, oh and yea you'll need a fuel pump as well...either the pump off the 06' a STI pump or (and best choice) a Walbro 255 for like $90.
you could also search on modding your stock injectors if your going for cheapest route possible.
adn as said ^^^ your current reflash won't work with the vf39 and neither will any of Cobb's shelf maps. The only year cobb has shelf maps for the vf39 is the 06-07 wrx.
I hate people who give out bad information. According to Cobb (I spoke to them yesterday), you don't need a pump for their maps.
That's why I always take things people on this forum say with a grain of salt. Half of them don't know their ahole from a hole in the ground.
Old 08-22-2007, 05:15 PM   #107
Foska Oats
Member#: 144081
2003 WRX
well...he has 100% positive feedback....I know that doesn't mean the world...but he has sold VF39s before.
I bought mine off ebay for 350, but it has a hair line crack. I am not worried about that because I have read where it does not affect to performance. Aslo the max I think I would push is 21 psi and that is not going to be at that for a daily driver, but to get a 1 pull on the track to see what it can do. It will also be equiped with a water sprayer.
Foska Oats is offline   Reply With Quote
Old 08-22-2007, 05:16 PM   #108
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
Well I can't find any on eBay for a good price since I got outbid. I am contemplating buying a 16G from Spun instead.
Old 08-22-2007, 05:18 PM   #109
06rexwagon
Member#: 114730
[email protected]
Check the forums here and on iwsti.com. I got mine for $300 shipped at iwsti back when I had a vf39 (about 6 months ago)
Old 08-22-2007, 05:19 PM   #110
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
I made posts and everything, believe me. No hits anywhere near that range except cracked ones.
Old 08-22-2007, 05:20 PM   #111
Foska Oats
Member#: 144081
2003 WRX
^^ They are getting more popular and you will have to be patient. They go for varying prices, but be patient.
Old 08-22-2007, 05:30 PM   #112
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
Yea, I'm working it. Now that they are coming with VF43s it seems that the VF39s are becoming more rare.
Old 08-23-2007, 08:38 AM   #113
saloonracer
Member#: 62687
2007 Its a Suby
Yeah..its stock :)
Default Great thread
One question I have. My only mod so far is a 3" catback. What could I expect(if possible at all) if I only run a Vf39 with all else being stock? 07wrx.
If I drill the pill and just swap the TD04 with a Vf39, will this cause any problems? Could I still run a OTS map or should I leave it stock? I assume I would not be making target boost.
I guess in short.. What is the minimum to run a vf39? And what would the result be?
Thanx
saloonracer is offline   Reply With Quote
Old 08-23-2007, 09:10 AM   #114
Foska Oats
Member#: 144081
2003 WRX
I have heard where guys have run the stock boost on the VF39 on the stock pump and stock injectors and they do feel the difference. That swap could up you about 20 horses. But I am a bit skeptical about doing that.
Old 08-23-2007, 09:13 AM   #115
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
Without engine management?
Old 08-24-2007, 10:08 PM   #116
saloonracer
Member#: 62687
2007 Its a Suby
Yeah..its stock :)
yeah..no EM. I would think that by running stock boost on the VF39 the stock ECU should be able to compensate by adjusting parameters. This setup should yield better topend results.
Just a thought. I am looking to do this becasue I only want a little better pull from 4500 to redline.
Any ideas here? could this be possible?
cheers
Old 08-24-2007, 10:11 PM   #117
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
I wouldn't do it but that's just me. I'm not sure the specifics but I am guessing the ECU wouldn't automatically know if you were using a VF39 or TD04 and 15PSI on one is not the same on the other for example.
Old 08-24-2007, 11:04 PM   #118
06rexwagon
Member#: 114730
[email protected]
cheers
Terrible idea, but it's your car. The ol/cl delays on a stock car will mess you up and the fuel and timing tables aren't scaled to the loads that your car will see with a vf39. Don't do it.
Old 08-25-2007, 02:47 PM   #119
Foska Oats
Member#: 144081
2003 WRX
No man, they do get a ecu flash with ECUTec or Tactrix.
Old 08-25-2007, 09:05 PM   #120
06rexwagon
Member#: 114730
[email protected]
He said no.
cheers
Old 08-26-2007, 10:44 PM   #121
06subieWRX
Member#: 116464
2006 wrx sport wgn
white
Default vf-39 on 2006 wrx
I just did a vf39 swap on my 06 wrx. what a huge difference from stage 2. on a mustang dyno it was 280hp but we found that it had a leak at the uppipe so I think it will dyno higher..... getting a pro-tune this week and will post results after the pro tune.
06subieWRX is offline   Reply With Quote
Old 08-26-2007, 11:38 PM   #122
Newera09
Member#: 125294
Almost forgot to do an update. I finally got the turbo upgraded installed and oh man does boost in like a punch from Mike Tyson. I ended up dynoing @ 280HP/330TQ. It was on a Land & Sea Dyno.
Mods are just in case anybody is wondering, Gruppe-S headers, Gruppe-s lightweight crank pulley, Injen CAI, ERZ downpipe, SPT catback, STi tmic and VF-39.
I was expecting higher HP but the car feels awesome either way especially with all that torque. The difference between stock and Stage 2 is nothing compared to Stage 2 and the VF39 upgrade. I managed to hit 120,130, 140 with so much ease (had some open road like at 3am this weekend). You also notice alot more power above 5k rpms unlike when I had the car at stage 2.
Old 08-26-2007, 11:42 PM   #123
Newera09
Member#: 125294
cheers
One of my buddies installed his VF turbo without EM just to drive it to the shop 3 miles down the road and blew one of his cylinders, . But in regards to getting more power til redline definatley a good choice for little money.
Old 08-27-2007, 07:29 AM   #124
06subieWRX
Member#: 116464
2006 wrx sport wgn
white
yea same here..... I was execting round 290 but 280 still is way better than stage 2. I'm running a cobb up-pipe, hks dp, borla xr-1 all catless. also k&n typhoon intake. I want to do the borla header soon and a lightweight pulley set also. what a huge difference from stage 2! can't wait for the protune and another run on the dyno.
Old 08-27-2007, 02:34 PM   #125
Foska Oats
Member#: 144081
2003 WRX
That is just crazy.
He was begging for trouble, and I am sure he never took his time.
Trunk Swap Instructions Sti-lysh Interior & Exterior Modification 15 01-11-2006 07:41 AM
N00b JDM STi swap instructions? perret318 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-31-2005 06:26 PM
clutch swap instructions? sailil Mid Atlantic Impreza Club -- MAIC 5 08-03-2004 08:03 AM
Trunk and lock swap instructions? Fair Oaks STI Interior & Exterior Modification 2 08-16-2003 01:59 PM
Bring back the bumper swap instructions! AccidenT General Forum Archive 1 03-16-2001 11:33 PM
