Old 08-21-2006, 02:16 AM   #1
drez14
Member#: 57318
Default Church Tuned WRX using Street Tuner
I finally had my car tuned by Shawn Church using street tuner software. I guess i was the first car he has tuned using the Street tuner but but it looked like he had been using it for years. Here are the numbers.
Car: 04 WRX 2.0 91oct
Engine mods:
Turbochargers.com GT Big16G
RC 650cc Injectors
Walbro Fuel Pump
Private Label Exhaust manifold
Private Label Up-Pipe w/ no cat.
Invidia downpipe
Invidia N1 Catback w/ resonator
Private Label Front Mount Intercooler
Greddy Type-RS BOV
Injen Cold Air Intake modified to work with the front mount.
Cobb Accessport
Cobb Street Tuner
Tuned by Shawn Church @ Church Automotive
HP: 293.2 @5651 rpm
TRQ: 305.3 @4414 rpm
Boost: 21.74lbs @ 4248 rpm tapered down to ~19 [email protected] rpm
I will post dyno printouts tomorrow.
drez14 is offline   Reply With Quote
Old 08-21-2006, 08:38 PM   #2
boundy3
Member#: 54598
2004 WRX Sedan
WR Blue Pearl #68 STX
Nice #'s especially on 91 oct.!!!
What type of dyno was this on, do you know what normal wrx's put down?
boundy3 is offline   Reply With Quote
Old 08-21-2006, 08:49 PM   #3
Clark Kent
Member#: 75682
2004 WRX
really good numbers for a 16g
Clark Kent is offline   Reply With Quote
Old 08-21-2006, 11:23 PM   #4
drez14
Member#: 57318
It was done on a dynapack so im sure its reading higher than on another dyno.
after i installed all my new turbo i just ran the Cobb OTS map modified in street tuner so that my injectors would work. Baseline with that map was 276HP w/ 311 trq.
thanks again to Shawn Church for even attempting to tune with street tuner. I highly reccomend anyone with street tuner to have him tune their car!
Old 12-05-2006, 06:09 AM   #5
kenny08
Member#: 79907
02 blue wagon
18g goodnesss
how are you safely running 21psi on 91 octane?
kenny08 is offline   Reply With Quote
Old 12-05-2006, 08:25 AM   #6
hondaeater69
Member#: 60324
wow nice numbers on 91 octane.
Old 12-05-2006, 12:10 PM   #7
Zumble
Member#: 34860
2005 Forester CGM
Nice numbers. I thought Church was a honda guy.
Zumble is offline   Reply With Quote
Old 12-08-2006, 03:57 PM   #8
TJRCS
Member#: 59199
2008 STI
Something isn't right.... you have a big dip right after peak torque, and another one near your peak horse power
TJRCS is offline   Reply With Quote
Old 12-08-2006, 04:03 PM   #9
dingobite
Member#: 82391
08 OBP Sti
td06SL2, 20g 299hp 300tq
............ Im terrible with reading some dyno plots but the question above has me wondering to.
dingobite is offline   Reply With Quote
Old 12-08-2006, 05:23 PM   #10
jays05
Member#: 78165
05 STI 35r + e85
Boost control needs to be dialed in more, I think. Nice numbers nonetheless, but I think the hp/tq dips are due to boost fluctuations.
jays05 is offline   Reply With Quote
Old 12-13-2006, 01:14 AM   #11
drez14
Member#: 57318
Any suggestions on how to get that fixed. Im assuming more dyno time huh...
Old 12-13-2006, 07:01 AM   #12
TJRCS
Member#: 59199
2008 STI
you said you used StreetTuner, right?? Do some datalogs and report back to us. If it's only boost problem, you can dial in your WGD map and turbo dynamic maps to match the target boost. This won't mess up AFR or timing as long as they were tuned right from beginning.
Old 12-13-2006, 10:19 PM   #13
Clark_Kent
Member#: 114299
So did I.
Clark_Kent is offline   Reply With Quote
Old 12-13-2006, 11:25 PM   #14
WeldingHank
Member#: 98645
2002 WRX Wagon
it looks like the car is knocking in the dyno chart. if your dropping power right after peak, you can be almost assured your knocking. Peak torque is also peak cylinder pressures.
WeldingHank is offline   Reply With Quote
FS: 02 wrx Ap + street tuner wrxsubej20 Engine/Power/Exhaust 8 02-11-2008 06:06 PM
Cobb AP V1 02-03 wrx w/ street tuner WrXtaCy2003 Engine/Power/Exhaust 6 08-03-2007 12:21 PM
Tuning with a Street Tuner vs Getting a Protune Black-STi AccessPort 2 01-23-2007 09:40 PM
Tuning Timing With Street Tuner - By a Noob for a Noob Sausage AccessPort 9 12-29-2006 06:35 PM
KS: WTT 2006 WRX AP + Street Tuner for TXS Delta scooby24 Engine/Power/Exhaust 2 09-28-2006 05:40 PM
