Old 08-21-2006, 05:15 AM   #1
DJNathan
Member#: 122808
1994 Impreza
grey?
Default 1994 impreza 5spd manual 2WD, transmission issues questions
i just bought this car, the car is in good shape however the transmission wont shift in to any gear, now car starts, runs clutch works, with motor on or off you cant put it in to any gear its like its stuck in neutral, any clues as to what could cause this, (i would think if transmission went out it would shift in to gears or at least with the clutch out the motor would not start and run as if nothings wrong, the old owner told me it lost 3rd then 4th wouldent shift in to those gears then lost the rest, well wouldetn shift in to them, i'm thinking somthings wrong with the linkage, but i may be wrong my first subaru, any info would be grately apriciated, also if you know where i can find a transmission for this car in northern cali around sacremento area, that would be grately apriciated also. thanks again
Jonathan
DJNathan is offline   Reply With Quote
Old 08-21-2006, 09:00 PM   #2
jetfan8178
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
might have greneded internal;ly. Its usually not ever "just a linkage" with a subie
jetfan8178 is offline   Reply With Quote
FS: NOVA: 1994 Honda Accord 2dr coupe 5spd Manual eternity0114 MAIC Private Classifieds 4 08-28-2008 06:16 PM
needed in california 1994 subaru impreza 5 spd manual 2WD transmission DJNathan Drivetrain 1 08-21-2006 05:22 AM
92 2wd Loyale wagon ?Transmission issue? awlllwa Transmission (AT/MT) & Driveline 1 01-02-2006 11:39 PM
1994 impreza 5spd transmission: Push or Pull type clutch? What flywheel to use?? lotus2843 Transmission (AT/MT) & Driveline 2 01-04-2005 10:04 AM
2002 WRX manual Wagon Transmission issue subaruowner12 Warranty Issues & SOA Problems 5 05-02-2002 06:36 PM
