Old 10-27-2001, 08:16 AM   #1
chuglobal
Member#: 10041
2004 STI White/Gold
276whp & 290ft/lbs
Default OE Suspension
I did a search on "suspension" in the warranty section and did not come up with anything useful so here's my previous post under the suspension area ...
"I noticed yesterday for the first time while driving that if I'm corning slowly I get this creaky noise. I never noticed it before until yesterday ... I have 3100+ miles on my WRX and have not yet abused it. I heard that this is a common problem with the WRX, is this true? What can I do to shut it up? I heard even high end aftermarket suspension ( DMS ) will also have the same problem, is that true? The creaking sound makes the car sound cheap ... I would like to get rid of it. Thanks."
I have heard the the sway bar bolts or bushings could be loose or springs have rotate and need to be lubed ... are these common issues on a 2002 WRX? Please help.
chuglobal is offline   Reply With Quote
Old 10-27-2001, 10:35 AM   #2
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
My old WRX did that. I think it was rear way bar bushes.
ANZAC_1915 is offline   Reply With Quote
Old 10-29-2001, 12:49 AM   #3
tt_ttf
Member#: 4431
MY07 STi and '06 WRX
Urban Grey & WRC Blue
I have a really annoying metalic clunk at lowe speed in the front left suspension. It comes and goes as you accelerate or brake and take load on/off the suspension. To me it sound like the rear end of the suspension arm where it attaches to the frame (going on looking at my alloy arms still in the box and where the noise sounds like it is comming from
I have it in for the dealer to look at it on Thursday
tt_ttf is offline   Reply With Quote
Old 10-29-2001, 10:46 AM   #4
chuglobal
Member#: 10041
2004 STI White/Gold
276whp & 290ft/lbs
Default Yo yo yo ...
The creaky problem on my OE suspension was solved this past Sat by Tom ... thanks. He determined right off that the area on the suspension where the spring rests on the cone area od the suspension was either dirty or dry. Tom sprayed some lube and the noise disappeared. The group of us went back to my place afterwards to wash our cars and I hosed all 4 suspension in the same area and there has yet been any noise. I like simple answers. Thanks Tom!
Old 03-19-2002, 11:10 AM   #5
SnortWagon
Member#: 14124
2002 WRX Wagon
tt_ttf:
Your problem sounds exactly like what I am experiencing right now. What did your dealer say or do?
SnortWagon is offline   Reply With Quote
Old 05-02-2002, 10:44 PM   #6
SJwrx
Member#: 14970
1997 GF8
multi
Instead of Stevens Creek Subaru fixing it, they stiffed me. "We can't hear it". My A$$! When I corner my friend in other cars hear it, plus the WRX isn't the best on keeping road noise out of the car anyway.
Rich
SJwrx is offline   Reply With Quote
Old 05-02-2002, 11:59 PM   #7
fpa1974
Member#: 15371
2002 WRX Sedan(gone)
Pearl Blue
Default Re: Yo yo yo ...
Sorry for not being able to make this evening.
Back to the point. I do have this noise on the front (both sides, left is worse) as well under same conditions as you. So did this solution really worked?
Florian
fpa1974 is offline   Reply With Quote
Considering Spec C or other OE Suspension spoolinsuby Brakes, Steering & Suspension 8 12-16-2008 09:12 PM
FS: OE '04 STi suspension sciolist Suspension/Brakes/Handling 5 02-28-2007 04:35 PM
What OE suspensions fit a '95 LS? Siper2 Brakes, Steering & Suspension 12 06-05-2004 07:18 PM
OE Suspension chuglobal Brakes, Steering & Suspension 8 05-17-2002 05:32 PM
Anyone running 225/50/16's on OE RS wheels w/ lowered suspension? GTBGUY Brakes, Steering & Suspension 3 04-23-2001 09:24 AM
Message Board Statistics All times are GMT -4. The time now is 08:38 AM.
