Welcome to the North American Subaru Impreza Owners Club Tuesday December 1, 2015
Old 08-21-2006, 02:59 PM   #1
Member#: 116636
2003 impreza
Default mix & match exhaust
im about to put together an exhaust from parts that have been laying back in our parts department. obx headers & converter and an 06 sti pipes the rest of the way back. has any done somthing similar on an n/a? if so, any fitment issues or issues you have run in to?
badtaste is offline   Reply With Quote
Old 08-21-2006, 03:18 PM   #2
Member#: 92913
2005 2.5RS Wagon
Crystal Grey Metallic
Aside from the fact that OBX doesn't make a cat, they just supply a resonated track pipe in its place, it should all fit fine. You *might* have to rotate the STi catback flange to fit the headers, but that would be the only problem.
You will also get a CEL because you're eliminating the cat, but you can get around that with a MIL eliminator or rear O2 sensor spacer.
FalconRS is offline   Reply With Quote
Gears mix & match possibilities juanmedina Transmission (AT/MT) & Driveline 5 03-18-2008 05:18 PM
Need help mixing and matching exhaust components MyFirstDeuce Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-23-2006 12:18 AM
Mix & match STi V8 springs and SPT pink springs sjrhee Brakes, Steering & Suspension 0 07-05-2005 06:33 AM
Mix & Match Sway Bar Companies? BlackAndBlue Brakes, Steering & Suspension 1 09-17-2003 02:23 PM
Mix n matching exhausts TRACER Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-10-2002 11:14 AM
