Welcome to the North American Subaru Impreza Owners Club Friday February 27, 2015
Old 08-21-2006, 03:47 PM   #1
Snoopy
Member#: 700
99 Impreza RS
Silverthorn Metallic
Default How long before you AC's freon ran out?
Mine just ran out recently after 7 years. Is that about right?
Mechanics couldn't find a leak anywhere so I guess my 99 RS just ran out.
Snoopy is online now   Reply With Quote
Old 08-21-2006, 04:42 PM   #2
linsavy
Member#: 11620
1997 GF4-STiV3 clone
I just had the 99 Legacy recharged. There was a slow leak in the pipe between the drier and compressor. New 0-ring and all is good.
A friend of mine just recharged his 1983 Porche 924. No leaks works great.
linsavy is offline   Reply With Quote
Old 08-21-2006, 07:17 PM   #3
Outback Jack
Member#: 120999
The AC is a closed system. Freon doesn't get used up. if it runs out, it is leaking.
Were the mechanics using an electronic leak detector? It's hard to detect small leaks without one.
Outback Jack is offline   Reply With Quote
Old 08-21-2006, 10:28 PM   #4
Snoopy
Member#: 700
99 Impreza RS
Yeah, they were. I don't know much about the AC system. Believe it or not, this is the first car I ever owned that needed the AC to be recharged.
Old 08-22-2006, 01:00 AM   #5
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
2001 RS 114k miles
AC on 24/7 365 days per year
and it's not run out yet
there must be a leak.... if it has run out...
Jamie
Old 08-22-2006, 12:51 PM   #6
Hayes
Member#: 11808
Cool
Technically the AC is not a closed system because of the compressor i.e. the shaft seal. My 2000 Forester w 108,000 miles still puts out cold air at ~ 37 degrees below ambient temp which is within specs. Florida car that runs AC about 9-10 months a year.
Hayes is offline   Reply With Quote
Old 08-22-2006, 12:56 PM   #7
horrorbiz
Member#: 77290
13 SSM BRZ
06 Impreza 2.5i
I had mine charged in the spring on my 2000 RS with 120k. It stopped blowing cold air mid-last summer.
horrorbiz is offline   Reply With Quote
Bailing out GM. How long before the Bailout money runs out? Snoopy Off-Topic 186 12-19-2008 09:47 PM
programmers/software engineers: if you lost your current S.E job, how long before you koloa Off-Topic 7 07-18-2006 08:34 PM
how long before you adjusted to your car under pressure Newbies & FAQs 22 12-16-2005 04:26 AM
How long before you should change your clutch fluid? 0260B4U Service & Maintenance 16 02-27-2005 11:02 PM
('93-'01) Synthetic oil users...how long before you change your oil? redobs Impreza Forum 38 10-26-2001 05:42 PM
