Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 10-27-2001, 04:08 PM   #1
phooka
Member#: 8486
2002 Impreza WRX
Default Turbo Timer + Alarm = Impatience.
I got my HKS turbo timer installed today - works great.. however I can't set the car alarm until the engine stops running. I don't guess anybody has found some work around to this problem?
dale
phooka is offline   Reply With Quote
Old 10-27-2001, 05:39 PM   #2
tdman77
Member#: 9832
2004 STI
Yes we have found a solution. I can't remember off hand which wires you need to cut but there are two if you have the factory alarm system. Try doing a search, that's how I found it. Sorry to hear you got the HKS TT. I just junked my in favor of the better Blitz DC TT. The HKS one runs your car much longer than necessary. It's not smart enough to know when there is boost or not.
tdman77 is offline   Reply With Quote
Old 10-27-2001, 07:19 PM   #3
syntrix
Member#: 9211
2002 wrx wrb
swankmonkey.com
syntrix is offline   Reply With Quote
Old 10-28-2001, 11:15 PM   #4
t-bone
Member#: 5737
2002 APS/JUN WRX
Blazn' Banana Yeller
That above link sounds like a standard TT install. I too would love to be able to set my alarm while the TT was active and the car running so I would not have to wait for it to shut off to set the alarm.
t-bone is offline   Reply With Quote
Old 10-29-2001, 08:04 AM   #5
phooka
Member#: 8486
2002 Impreza WRX
I finally found it after a search.. (duh). It's really pretty simple. Disconnect the green/black wire on the control module above the fuse box, you have to remove the knee panel under the steering wheel to get to it. Unplug it, and either back it out or cut the wire. Under the e-brake center console is another security box that you must disconnect the gray wire. I'm not entirely sure what all this is 'disabling'.. but it does work.
<br><br>
As for the HKS turbo timer. I already don't like it. It can apparently only do one of the fuctions at a time???? If you don't have it set to that particular mode you want, it doesn't perform that function. That's pretty lame.
dale
Old 10-30-2001, 01:05 PM   #6
syntrix
Member#: 9211
2002 wrx wrb
swankmonkey.com
and you forgot to wire a jumper acc wire to each of the modules where you cut the wire. Everything is not fine... set off you alarm and then try to reset it
if you do the jumper wires for acc on the link above that I wrote, everything works just fine, take key out, set alarm and wrx keeps on idling.
It's not a standard turbo timer install at all.
Old 11-01-2001, 11:05 AM   #7
phooka
Member#: 8486
2002 Impreza WRX
Ok.. since getting the proper instructions (thanks!) and splicing an acc wire to both of the control modules wires which were cut, now the alarm doesn't set at all until the engine stops (back to square one before cutting wires). After cutting the wires, it worked.. after splicing the acc into them it no longer works. Whad I do wrong?
Thx.
dale
Old 11-01-2001, 01:19 PM   #8
wrx182
Member#: 9531
2002 WRX Sport Wagon
instructions are on my site www.angelfire.com/ego/wrx182
if you can't figure out the problem from the instructions, PM me or email me and I'll help you out
wrx182 is offline   Reply With Quote
Old 11-01-2001, 01:34 PM   #9
syntrix
Member#: 9211
2002 wrx wrb
swankmonkey.com
splice the acc into the wires coming out of the modules. Oh, and it's car acc, not TT acc
Old 11-01-2001, 02:24 PM   #10
phooka
Member#: 8486
2002 Impreza WRX
yep.. that's what I did, double checked with a meter. no 'beep beep' when i take the key out and press the button.. once the engine stops it works fine.
dale
Old 11-01-2001, 02:29 PM   #11
syntrix
Member#: 9211
2002 wrx wrb
swankmonkey.com
Then you hooked up the acc wire from the tt to the acc wire of the ignition. You don't use the acc wire from the tt. If you used a harness, you might want to cut it.
If that's hooked up, it will give the symptoms you are describing!
Old 11-01-2001, 02:35 PM   #12
phooka
Member#: 8486
2002 Impreza WRX
Hmm. wait. I think I get it. Thx. I'll check it this afternoon.
dale
Turbo timer + alarm Ctracer911 Electrical & Lighting 1 01-12-2006 07:54 AM
Turbo Timer Alarm Bypass Wire on an 04 WRX Wagon ? jawbrkr Car Audio, Video & Security 1 07-22-2003 03:24 PM
Turbo Timer Alarm....followed instructions but no luck. cook32 Electrical & Lighting 0 07-20-2003 05:00 PM
Turbo Timer/Alarm problem stilesg57 Electrical & Lighting 7 03-25-2003 02:04 AM
help:how to make turbo timer+alarm work at same time? DarkImpreza Car Audio, Video & Security 10 01-22-2002 12:29 PM
