Welcome to the North American Subaru Impreza Owners Club Thursday July 30, 2015
Old 10-27-2001, 03:10 PM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Turbo and Wastegate question
I have the Legacy IHI turbo on my car. There is a hose running from the compressor side of the turbo to the wastegate spring. I was talking to a few members a couple nights ago all very familar with turbos and the said that that hose is supposed to be T-ed into a manifold vacume line. I am just running on the stock wastegate spring and no controller and have been running it this way for nine months since I installed it. I told them it wasn't and they said that it was impossible. It was to dark to see clearly that it wasn't, so they didn't belive me, but it deffinatly isn't. I put the kit in myself and I knew that I never T-ed it in. So what's the deal? Should I be T-ing into the manifold vacume? Is my car special? I know I think it is
Thanks,
Joshua
yebokmj is offline   Reply With Quote
Old 10-27-2001, 03:21 PM   #2
Ethan
Member#: 246
I just looked at my setup, same as yours, and (Before the Tec-2 at least) it just went from the wastegate to compressor. No t's or nothing.
Ethan is offline   Reply With Quote
Old 10-27-2001, 04:34 PM   #3
Avenger
Member#: 1234
I think it is okay as long as you have the line from your boosted side to your waste gate.
Avenger is offline   Reply With Quote
Old 10-27-2001, 05:19 PM   #4
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
That's the way it supposed to be. It doesn't need to be teed into anything.
blaster88 is offline   Reply With Quote
Old 10-27-2001, 10:16 PM   #5
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
Why would it need to be "T"ed into your manifold? Both will show boost, the only difference is the compressor housing on the turbo might show a little more boost than the intake manifold since there are some constrictions between the two that might cause you to lose some boost. (There's a word for this, but I just woke up and can't think of it right now)
So you are using the stock wastegate??? How much boost are you getting? I tried that and it went up to 10psi before I got my new external wastegate.
Chad
93 1.8T
subachad is offline   Reply With Quote
Old 10-28-2001, 01:28 AM   #6
yebokmj
Member#: 2213
Brilliant Red
Default Thought so
I thought I was all set but they did install the doute. As to how much boost I am seeing, I am getting 5psi to 6 psi, mainly 5psi.
Joshua
p/p turbo and wastegate jakedown Southern California Impreza Club Forum -- SCIC 4 05-08-2007 05:47 PM
04-05 / 06 turbo and wastegate? f1uxx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-23-2007 09:13 PM
pictures of my new turbo and wastegate in the car. STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 06-09-2003 09:40 PM
WRX Turbo Internal Wastegate Question seven881 Normally Aspirated with bolt-on Forced Induction Powertrain 12 08-29-2002 12:56 AM
Blow off valve and wastegate question 2.5GT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-06-2001 04:58 AM
