#1 |
Member#: 39562
Vehicle:My02 WRX Sedan 5MT WR blue |
Hi
I would like to setup my PSI3 dash display to activate my Aquamist 2d system. This would allow me to use adjustable WI injection point (in car). I was thinking of using the 3/4 pins to drive a relay that opens the blue wire electrical circuit on the 2D. Any thoughts would be appreciated.
#2 |
Member#: 177
NWIC
Vehicle:The 93 Imp W/EJ20K flat black |
mmmm
i suppose you coudl fire it off the shift light but i don't think the resolution (8-9/sec) of the psi3 is fast enough that you want your injection to becontrolled by it |
#3 |
Member#: 39562
Shift light is pins 1/2 on connector 2
I am using pins 3/4 on connector 2. These are setup to trigger WI injection on boost threshold. |
#4 |
Member#: 47769
You can run it off 3/4 (technically just 3 as 4 is a ground), but as jaxx said it does not have the resolution to be able to kick on at the exact same point everytime. There's only so much info info that can be pulled from the ECU at a time. This slows down the unit a bit.
#5 | |
Member#: 85153
Vehicle:2004 Citroen Picasso Silver |
Richard PS may be it is simplier to use a 5-pin relay. |
#6 |
Member#: 73190
Vehicle:2005 Impreza WRX STi Silver |
i used to have this setup working in my car. i opted out of it because of the following:
- i've found the dash unit to react too slow for tuning on the edge with water. you have to set the activation pressure much lower just to try and get it spraying at the right time. - you need the dash unit to be connected ALL of the time for your water injection to work. this effectively eliminates tuning for water since you'll need to have the laptop monitoring the diagnostic output. it also eliminates effective diagnosis, should you have problems, because you cannot have both working at the same time. its ease of use to change the activation pressure is a great incentive to try it but the con's far outweigh the pro's. calvin. |
#7 | |
Member#: 85153
Hello Calvin,
We can set the DDS3 to any response time, from ms to S. The problem is false triggering during gear shift where duty cycle or manifold pressure drops. I can tell you how to modify the delay if you email me directly. The DDS3's junction box is under furhter developments where the "map switch" output engages at all time until fault is detected during set boost or above a certain fuel duty cycle. Richard Quote:
#8 | |
Member#: 73190
the delay isn't with the aquamist product but rather the dash monitor unit developed by psi3. it tends to read slowly and the trigger to drive the pump is delayed. i had spoken to you about this setup a month or 2 back. elegant solution but hop-switch included with 2d is much better. calvin. |
#9 |
Member#: 39562
Richard this is exactly what I am doing. I am using a 5 way bosch relay(N?C) to open the hop switch circuit to the FIA.
Calvin I understand the resolution issues with the PSI 3. What happens to current between pins 3/4 when the WI injection boost is reached. i.e if boost is reached , does the PSI3 energise(close) the pin 3/4 circuit(current flows)? ATM the volt meter is not showing any current even at/passed boost point. PS I am doing this to test the efficiency of my boost activation point(currently 1 bar). It is hard to change the hop switch everytime and to set the boost activation point easily. Also by setting only one parameter on data page 7 the map reading mirrors my boost guage quickly enough. I agree you cannot use the PSI 3 as a primary trigger for the 2D system. Unfortunately it takes time to fine tune the hop switch and then datalog and start all over again. |
#10 | |
Member#: 73190
calvin. |
#11 |
Member#: 39562
Calvin
Excellent. Then I can use a N/C relay (change over) to open the hop switch circuit. Thanks dude. |
#12 | |
Member#: 85153
You have to think logically and to act illogically. This will save using a relay and extra wiring. Just connect the FIA2's blue wire to your controller and try. Richard |
#13 |
Member#: 39562
I already wired it up over the weekend. And it works very well for testing.
The PSi3 system responses is only adequate below 5500 rpm. I am going to use the adjustable WI setpoint to determine the most effective boost setting. I will then adjust the hopswitch and leave it to control the 2D. Thanks for the help. |
| Thread Tools | |
| Display Modes | |
| FS (WA): Aquamist 2D, Maddad Catted downpipe, TGV's and more | leonbmx | Engine/Power/Exhaust | 4 | 05-08-2009 09:46 PM |
| Grimmspeed EWG, Aquamist 2D, Maddad Catted downpipe, TGV's and more | leonbmx | NWIC Private Classifieds | 7 | 05-08-2009 09:44 PM |
| fs: Aquamist 2D water alcohol injection kit, new 100cc aquamist accumulator | fastwrx25 | Engine/Power/Exhaust | 5 | 06-30-2008 07:38 AM |
| FS: Aquamist 2D Water/Methanol Injection with Prototype Bracket and DDS3 Control Unit | Wrinkleboi | Engine/Power/Exhaust | 4 | 10-10-2007 02:36 AM |
| aquamist 2d and nitrous? advantages? | cbourbs | Water/Methanol Injection, Nitrous & Intercooler Cooling | 2 | 03-13-2007 09:50 AM |
