Old 08-22-2006, 10:33 PM   #1
RichWRX
Member#: 15544
STI hydra,2.65l
BW s374 turbo(twin scroll
Default hard wireing dual fuel pumps
does anyone know how you would hardwire dual walbro fuel pumps. I have a dual fuel pump setup and have the wires spliced into the factory harness,and after a long ride the wires get warm. what size wire would you use and should I use relays. pics would be great
Rich
RichWRX is offline   Reply With Quote
Old 08-23-2006, 05:59 AM   #2
TheMadScientist
Member#: 23717
2005 Big red
I have been thinking about using two fuelpump controlers, one for each pump. That way you should be able to run 2 sets of wires and not have to worry about the wires heating up. Haven't gotten very far still waiting on some tuning to see if the duals are needed.
TMS
TheMadScientist is offline   Reply With Quote
Old 08-23-2006, 01:09 PM   #3
teiva-boy
Member#: 22825
I'd use 10ga wire and relays.
use the factory wires to turn on the relays, which then get their hotside from the 10ga.
10ga should be able to take on at least 20A without breaking a sweat.
Being a Hydra user, talk to Phil from Element Tuning, as I swear he has worked on fuel systems like what you want.
teiva-boy is offline   Reply With Quote
Old 08-23-2006, 01:49 PM   #4
TheMadScientist
Member#: 23717
2005 Big red
The problem with the relay idea is that most "common" relays will die very quickly when pulsed. The stock system has 3 duty cycles that it uses.
TMS
Old 08-23-2006, 06:34 PM   #5
RichWRX
Member#: 15544
STI hydra,2.65l
what relays would be the best choice?
Old 08-23-2006, 06:39 PM   #6
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
/\/\Like TMS was saying
If your car uses an electronic fuel pump controller, stock, just get another and wire it to the battery for source and run another 10 guage from its output to the second pump. The other small wires that control output on the second fuel pump controller could be wired to the first, I'm sure. Anyone else? Correct me if I'm wrong here. I would have also recommended a relay off the original output and a large wire for source power, but if you want to keep the variable speed properly, you'd need two controllers.
2slofouru is offline   Reply With Quote
Old 08-23-2006, 07:07 PM   #7
teiva-boy
Member#: 22825
TMS
Being that I see a Hydra mentioned in the profile of the OP, There has got to be a way around that.
Old 08-23-2006, 07:26 PM   #8
TheMadScientist
Member#: 23717
2005 Big red
Sure it is called a power transistor or if you can find one a solid state relay.
The frequency of the fuel pump controller can't be that high. The transistor is much better suited to a pulsed control voltage.
TMS
Old 08-24-2006, 12:17 AM   #9
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
So are you suggesting some type of mosfet, darlington, or just regular silicon transistor?
Old 08-24-2006, 05:31 AM   #10
TheMadScientist
Member#: 23717
2005 Big red
Just use a second OEM controller.
The logic lines comming from the ECU should have no problem driving 2 of them.
TMS
Old 08-24-2006, 12:07 PM   #11
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
TMS - I spliced the FPC ecu line and connected it to both controllers, is this what you did? I did not connect the other line from the ecu, mainly as I had no idea what it was.
I also ran a positive hard line directly from the battery to power the second controller. i did not want any voltage drop.
mick_the_ginge is offline   Reply With Quote
Old 08-24-2006, 12:10 PM   #12
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Why not skip all of this work and trouble and just buy a more powerful single Drop in pump?
Clark
AZScoobie is offline   Reply With Quote
Old 08-24-2006, 12:16 PM   #13
InfamousDX
Member#: 25413
^ Sure! Please let us know which one and where to get it.
Old 08-24-2006, 12:31 PM   #14
TheMadScientist
Member#: 23717
2005 Big red
Clark
Sugestions that aren't $$$$ please? Not being crass, really wondering what else is out there that is in tank.
I have been wondering if at the dual pump level if new fuel feed lines are needed to flow enough fuel.
TMS
Old 08-24-2006, 12:38 PM   #15
AZScoobie
Member#: 8785
netcom.com
Here ya go
https://secure.buschurracing.com/cat...roducts_id=851
I have tested. They work. I tuned Mikes GT35R setup with the single walbro. Fuel pressure fell off and went lean over 500whp on the mustang. He installed this pump and pressure held strong and over 500whp his IDC was only 82%. I had to pull ALOT of fuel out of the utec map. Like at least 2 full points.. 3 in the high end. I ran 36 psi for a handfull of 4th gear dyno pulls.
Clark
Old 08-24-2006, 01:29 PM   #16
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
82% IDC's at 36psi with a 35R!?!?!
What injectors are you using? C16? AFR's?
I've heard a lot of good things about Buschur's wicked up Walbro. Might have to see if Dave can get me a good deal on one.
SloRice is offline   Reply With Quote
Old 08-24-2006, 02:02 PM   #17
AZScoobie
Member#: 8785
netcom.com
PE850CC injectors. I think Static Pressure is 45 or so. Mike can comment on it.
I tuned the car on:
91 octane
91 octane and SMC Meth injection
100 octane
100 octane and meth
C16
C16 and Meth
Car runs a Utec ontop of a JDM V7 ECU that I tuned with ECutek.
Its a Crawford 2.35 motor V7 STI heads ported with V limited cams. Kingpin GT35R kit, I ran it at 36 psi as logged on Dougs Dynopower Mustang 500. It made 507whp. From 30-36 psi it made more trq but barely anymore power up top. The turbo was finished. AFR was 12.5 to 1 flat across the board on the C16 fuel. Timing was near 25-30 range. Car refused to knock. Just would not make more power... Also Consider that it was 112-115 degrees INSIDE the Dyno room.. LOL.. A super HOT day. Intake temps where showing 140-160 F at the MAF sensor and pegging out on boost.
Trust me. That Buschur Pump is Plenty of pump for 600whp just Like Dave said it was. I am going to order one for my car when I decide to turn it up.
Clark
Old 08-24-2006, 02:46 PM   #18
TheMadScientist
Member#: 23717
2005 Big red
Clark
Once again thanks.
I didn't even know that pump existed. That page is now book marked.
Looks like a much better option than a dual setup.
TMS
Old 08-24-2006, 03:13 PM   #19
InfamousDX
Member#: 25413
Me thinks I'll buy one of those if I go lean on c16. How hard would hte install be... as easy as a Walbro?
Old 08-24-2006, 03:32 PM   #20
AZScoobie
Member#: 8785
netcom.com
Drops in according to other owners. Its a little larger diam and a little shorter. I had no idea it existed either
Clark
Old 09-10-2006, 04:10 PM   #21
greysave
Member#: 62395
2005 STI
On the website it list's this is for an evo. Does the evo and sti use the same fuel pump?
greysave is offline   Reply With Quote
Old 09-11-2006, 02:51 PM   #22
AZScoobie
Member#: 8785
netcom.com
Yes they do..
Clark
Old 09-11-2006, 08:59 PM   #23
burnin4
Member#: 59764
10 sec STi
10 sec Z06
Rich
both pumps will need their own relay, power wire, and ground. recently went through all the same troubles. TopSpeed was able to make everything work perfectly on my setup, give them a call or send them a pm.
burnin4 is offline   Reply With Quote
Old 09-12-2006, 12:40 AM   #24
WRX-Blue-Mica
Member#: 37938
02 WRX
Blue Mica
Originally Posted by AZScoobie View Post
Yes they do..
Clark
Which one has better flow, this buchur single fuel pump or twin walbro (+all the trouble)?
Thanks
WRX-Blue-Mica is offline   Reply With Quote
Old 09-12-2006, 12:46 PM   #25
AZScoobie
Member#: 8785
netcom.com
Buscher pump is rated for 600whp. Twin walbros will have enough fuel for 800+. However, the lines filter ect will not.
Clark
Dual Fuel Pump set-up:Wired and mounted ready to go! Peeblesmx445 Engine/Power/Exhaust 8 01-11-2010 04:29 PM
Best methods to run dual fuel pumps? Token-Negro Engine Management & Tuning 0 09-27-2007 10:24 PM
Hard wiring dual Walbros. mikaust Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-01-2005 12:53 AM
FS: Impreza RS Wiring harness, Fuel Pump, PS pump, sway mounts. SubaruPreza Rocky Mountains Impreza Club Forum -- RMIC 0 06-22-2004 12:11 PM
