Old 08-23-2006, 02:26 PM   #1
wrxnova1
Member#: 112854
2009 IS-F
2014 Forester XT
Default Changing Spark Plugs in a WRX 2.0T
My car is misfiring and drawing 2 check engine lights (P0300 AND P0301). I figured a good first step is to change my plugs being how I havent yet (at 40k miles). Ive searched the forums and the best walkthrough on how to do so came from a service manuel but it is not legible. The best link I have found is http://www.scoobymods.com/forums/att...achmentid=1038
Any help is appreciated. Thanks.
wrxnova1 is online now   Reply With Quote
Old 08-23-2006, 02:30 PM   #2
subieworx
Member#: 47769
Disconnect neg bat terminal.
1. Remove the air intake box.
2. Remove washer bottle
3. Disconnect clips on coil packs
4. Unscrew bolt on coil pack
5. Remove coil pack
6. Remove spark plugs
7. reverse
subieworx is offline   Reply With Quote
Old 08-23-2006, 02:44 PM   #3
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Now with more clunks!
5. Remove coil pack
7. reverse
^^Yup, it's fairly easy.
You'll want a few short socket extensions.
02WHITEDUB is offline   Reply With Quote
Old 08-23-2006, 03:13 PM   #4
johsti
Member#: 36049
2014 FXT Premium
johsti is offline   Reply With Quote
Old 08-23-2006, 03:41 PM   #5
Dizzy89
Member#: 26589
2003 Impreza WRX
Sedona Red
FYI, the same thing was happening to my WRX. CEL+Misfiring cylinders. Took it to Subaru, replaced spark plugs. A couple weeks later, happened again. This went on twice before the dealer just sent the ECU to Subaru for reprogramming. Fixed for free under warranty and they paid for the rental for the week. Make sure it's really the plugs that are causing the problem, because in my case, it wasn't.
Dizzy89 is offline   Reply With Quote
Old 08-23-2006, 04:03 PM   #6
wrxnova1
Member#: 112854
2009 IS-F
2014 Forester XT
Did replacing the spark plugs temporarily fix the problem? Were you running any performance parts? Im currently running cobb stage 2. Thanks.
How to change spark plugs in an 05 Legacy 2.5 Gondi Service & Maintenance 3 12-11-2007 06:48 PM
Anyone change spark plugs in an STi? jmanSTI Texas Impreza Club Forum -- TXIC 14 12-02-2007 11:47 PM
A shop to change spark plugs on a WRX for less than $200 stees South East Region Forum 14 08-24-2006 11:18 AM
any instructions for changing spark plugs for a WRX? db97 Service & Maintenance 2 05-02-2003 02:29 PM
When to change spark plugs in WRX? scoobyrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-28-2002 07:49 AM
