#1 |
Member#: 72132
NWIC
Vehicle:2000 Legacy GT White |
Ok I know Im supposed to change the head bolts everytime the head gaskets are changed but, I just changed them the last time I did the heads, which wasnt very loing ago. However the reason Im changing the head gasket is because the engine over heated very bad
So should I change them or not?I also need so help with the following information (I dont trust haynes). Does someone own or have access to a service manual? Head torque pattern Head torque spec cam retainer pattern and torque spec camshaft torque spec Crankshaft torque spec Idler pulley torque spec Water pump bolt pattern and torque spec Oil pan bolt torque pattern and spec Oil pump torque pattern and spec
#2 |
Member#: 43602
NESIC
Vehicle:2005 Outback Sport |
The head bolts don't need to be changed every time.
#3 |
Member#: 72132
NWIC
What im concerned about is that the engine got really hot, I think they should be ok (the fact that the set costs around $70 makes me think there "ok") but I just want to be sure, I dont want to have to do this again for awhile
#4 |
Member#: 27261
NWIC
Vehicle:1999 www.prjct1.com I'm Ron Burgundy? |
They nshould be changed because they stretch when torqued, But its been discussed before so do a search on it also.
#5 |
Member#: 11808
www.endwrench.com may have the head bolt sequence.
#6 |
Member#: 6486
Vehicle:00 Impreza 2.5 RS Blue Ridge Pearl |
Head bolt torqueing sequence for a ej25/ej22 sohc:
C A F E B D <----- front of motor 1. apply a coat of engine oil to washers and bolt threads 2. tighten all bolts to 22 ft. lbs. in alphabetical sequence. then tighten all bolts to 51 ft. lbs. in alphabetical sequence. 3. back off all bolts(in sequence) by 180 degrees. back off all bolts again (in sequence) 180 degrees. 4. tighten bolts A & B to 25 ft lbs. 5. tighten bolts C,D,E and F to 11 ft. lbs. 6. tighten all bolts (in sequence) 80-90 degrees. DO NOT EXCEED 90 DEGREES 7. Further tighten all bolts (in sequence) by 80-90 degrees. BETWEEN STEPS 6&7 NO NOT EXCEED 180 degrees. Done. More to come. |
#7 |
Member#: 58779
Vehicle:95 WRX RA replica, 98 Tacoma (300k Club) |
A Haynes manual is your friend.
It goes through it step by step, however Tim has it down for you. |
#8 | |
Member#: 72132
NWIC
#9 |
Member#: 6486
Camshaft cap install for ej25/ej22 sohc
m c k e o i a g b h j p f l d n 1. oil journals and lobes of cam with engine oil 2.place correct cam in head 3. apply a 3mm bead of liquid gasket along outer edge of cam cap channel. 4. temporarily hand tighten bolts g through j (above sequence) g ac e f db h 5. install rocker assemblies and tighten bolts a through h in alphabetical order to 19.5 ft. lbs. k i m n j l 6. tighten torx plus bolts i through n in alphabetical order to 14.4 ft. lbs. using st 499427000 o q u s v t r p 7. tighten bolts o through v (hex head) in alphabetical sequence to 8.6 ft. lbs. w x 8. tighten bolts w and x to 8.6 ft. lbs. done. Sorry, my bolt label spacing did not take. |
#10 |
Member#: 6486
Camshaft sprocket bolts are 60.5 ft lbs.
crankshaft pulley bolt is: ej22--94 ft lbs. ej25--134 ft lbs. |
#11 |
Member#: 6486
oil pan torque specs
no pattern, use a liquid gasket, 3.6 ft lbs. idler pulleys: two big ones on the left side are both 31 ft lbs toothed one under water pump is also 31 ft lbs. belt tensioner bolt is 20 ft lbs. |
#12 | |
Member#: 43602
NESIC
#13 | |
Member#: 72132
NWIC
#14 |
Member#: 6486
Water pump bolt torque spec and tightening pattern for ej motors
Start with bolt at 2 o:clock position and go clockwise. first pass torque to 9 ft lbs second pass torque to 9 ft lbs again. |
#15 |
Member#: 6486
oil pump bolt torqueing sequence and torque spec for ej motors
no sequence listed I just start at the top and skip two going clockwise Useing a liquid gasket make a thin bead around the outside of the pump staying inside of the bolt holes and outside of the o-ring hole. Looking at the back of the pump. run a bead from the left side alignment dowel hole diagonally downward to the right along that ridge and down to meet your existing bead. put a small dab of sealant on the new oil pump seal and affix it onto the recess in the block after you wipe the oil out of there. Torque spec is 5 ft lbs. go around twice to be sure. |
#16 |
Member#: 6486
Anything else?
#17 | |
Member#: 6486
ACtually no, the head bolt torqueing pattern is a little different for the dohc motor. Try searching for head bolt torque pattern.
#18 |
Member#: 6486
Burton rider, the cam cap instructions up there are not for you either.
I believe yours are: a c e b d f Tighten a through f through f to 10 ft lbs. tighten c through f to 16 ft lbs. You should really verify that because it's from memory. |
#19 |
Member#: 72132
NWIC
Sorry I should have specified which one I was talking about
#20 | |
Member#: 72132
NWIC
#21 |
Member#: 73398
South East
Vehicle:04 Forester XT JBP Springs, RSB, wheel/tires |
And this is why I go to a shop........
Kudos to you guys for doing it yourself and doing it the right way! |
#22 | |
Member#: 72132
NWIC
Dude pray you took it to a good shop, I dont trust shops. Everytime I take it to one (unless its an oil change or tire work) they either do it wrong or they forget something and I pay way to much. For example just before I decided to do this I took it to a shop to fix what Im fixing myself right now($900 dollar mistake). It is now going to cost me around $500 to replace gaskets, buy tools, etc and do it right. Sorry im still a little angry with them. ![]() |
#23 |
Member#: 58779
Should I just scan the pages of the Haynes manual for you guys or do you have it all figured out now?
#24 | |
Member#: 72132
NWIC
#25 | |
Member#: 58779
| Thread Tools | |
| Display Modes | |
| ARP head studs V's OEM sti head bolts | bugeyes | Built Motor Discussion | 82 | 03-19-2009 04:47 PM |
| Re used head bolts... caused head gasket to blow again? | brian3676 | Normally Aspirated Powertrain | 14 | 05-01-2008 07:00 AM |
| WTB: ej257 gasket kit, ARP head bolts and case bolts | 69_Lex | Private 'Wanted' Classifieds | 3 | 02-20-2008 10:38 AM |
| Can I reuse block bolts/head bolts | Tattoo Collector | Normally Aspirated Powertrain | 19 | 01-22-2005 01:35 AM |
| Head Bolts & Cams Bolts Torque Specs | Imprezd | Factory 2.0L Turbo Powertrain | 3 | 03-20-2003 07:30 AM |
