#26 | |
Member#: 72132
NWIC
Vehicle:2000 Legacy GT White |
#27 | |
Member#: 58779
Vehicle:95 WRX RA replica, 98 Tacoma (300k Club) |
#28 | |||||||||
Member#: 58779
3-1-6 5-2-4 Quote:
Step 2: 51 ft/lb Step 3: Loosen all bolts 180 degrees Step 4: Loosen all bolts and additional 180 degrees Step 5 (bolts 1 and 2 ONLY): 25 ft/lb Step 6 (bolts 3, 4, 5, and 6 ONLY): 132 in-lbs (11 ft/lb) Step 7: Tighten all bolts an additional 90 degrees Step 8: Tighten all bolts an additional 90 degrees It's a PITA but I've had no problems with it. For step 6, I used a 20-100something Craftsman torque wrench and just turned it down to where 11 would be. There is a faint click, but again, it worked on mine and it worked both times my buddy changed the Cometic on his DSM. Quote:
I have specs for both, so once I get this cleared up I'll post it.Quote:
These are just to hold you over, I'll scan and post the images when the software finishes downloading. (woohoo, 15%!) |
#29 |
Member#: 58779
I'm not going to be able to get these scanned, I have to wait for a cd from HP. If you need anything else, feel to pm me or just reply in this thread.
#30 | |
Member#: 73398
South East
Vehicle:04 Forester XT JBP Springs, RSB, wheel/tires |
Of course, that's the great thing about the community here on Nabisco, you can pop a question when you run into something strange. Mainly, I just don't have the time (commute 2.25 hours a day, work 9 hours, have a 2 year old and a 2 month old, and when I get home, it's MY TURN!) Good luck on your work man. I might even have something to add one day, as I'm not a complete stranger to working on cars! |
#31 | |
Member#: 27261
NWIC
Vehicle:1999 www.prjct1.com I'm Ron Burgundy? |
#32 | |
Member#: 72132
NWIC
#33 | |
Member#: 72132
NWIC
Yesh... I know, I know.... Im gonna replace them, I just really dont want to buy new ones this is getting expensive quick.Head bolts $135.98 Head Gaskets $111 Water pump $50 CV Shaft $80 Light weight pulley $110 Headers $210 Sti motor mounts $98 Crank gear $36 Strap wrench $36 3 prong puller $30 Total $896.98 Plus I just spent over $900 on having a stupid shop do basicaly nothing....arrrgghhh I should have bought an engine off ebay and a cherry picker ![]() |
#34 |
Member#: 27261
NWIC
Yeah Things seem to add up quick. See if you can't find some ARP head Studs for cheaper.
#35 |
Member#: 72132
NWIC
Yay the dealership had the head gaskets for cheaper $40 ea
#36 | |
Member#: 72132
NWIC
Add to christmas wish list ![]() |
#37 |
Member#: 6486
Vehicle:00 Impreza 2.5 RS Blue Ridge Pearl |
Ouch, your doing this in the car?
How's the back holding up? |
#38 | |
Member#: 58779
#39 | |
Member#: 58779
#40 |
Member#: 72132
NWIC
#41 | |
Member#: 72132
NWIC
Now the only thing im waiting on is for the head bolt to get here, I should have them by friday, I hope I get them sooner its getting cold here. I have to ride my motorcycle when I cant drive my car. |
#42 |
Member#: 72132
NWIC
I need the torque spec for the bolt that holds the cam pulleys on and the bolt the holds the crank pulley on. Does anyone know what they are?
#43 |
Member#: 72132
NWIC
***Update: 97 legacy outback
Everything is put back together and its runs amazing. I only ran into one issue after I got it put back together this weekend. I forgot to plug in the water temperature sending unit, so I wasnt getting a reading on my temp gauge. After I plugged it in though everything looked good. Here is a recap of everything that was replaced/upgraded/fixed: 1. Perrin Lightwieght pulley 2. Ground mod 3. Sti Motor mounts 4. Borla Headers 5. Custom short ram intake 6. New Crank gear 7. New idler pulley 8. New head gaskets 9. New Head bolts 10. New water pump 11. New water pump gasket 12. New front main seal 13. New oil pan gasket 14. New Timing belt 15. Fixed front O2 Sensor connection I think thats about it. I still need to do more work next weekend but the engine is taken care of. After all that work I am very pleased with the results. The throttle response is amazing, it is great through the entire RPM range. I love the pull that the engine gives, its hard to be nice on the throttle now I need to be though for a few hundred miles and then change the oil again and I should be good to go Thanks for all the help from everyone ![]() |
#44 |
Member#: 58779
Thanks for the update, glad it all worked out ok.
#45 | |
Member#: 117154
NESIC
Vehicle:2005 OBP STi No mods yet, soon to come |
#46 |
Member#: 72132
NWIC
I did a compression test on all four cylinders before I started and they held pressure fine.
| Thread Tools | |
| Display Modes | |
| ARP head studs V's OEM sti head bolts | bugeyes | Built Motor Discussion | 82 | 03-19-2009 04:47 PM |
| Re used head bolts... caused head gasket to blow again? | brian3676 | Normally Aspirated Powertrain | 14 | 05-01-2008 07:00 AM |
| WTB: ej257 gasket kit, ARP head bolts and case bolts | 69_Lex | Private 'Wanted' Classifieds | 3 | 02-20-2008 10:38 AM |
| Can I reuse block bolts/head bolts | Tattoo Collector | Normally Aspirated Powertrain | 19 | 01-22-2005 01:35 AM |
| Head Bolts & Cams Bolts Torque Specs | Imprezd | Factory 2.0L Turbo Powertrain | 3 | 03-20-2003 07:30 AM |
