Old 08-24-2006, 11:55 AM   #1
BURTONRIDR
Member#: 72132
2000 Legacy GT
Default Engine Rebuild Tips
OK I wanted to start this thread to help out the guys that are eventualy going to have to do this themselves. Please add to the list
When you get to the point where you have to take off the cam retainers on a ej25 you have to be careful not to mix up shims if they fall out. Your going to have this problem on the exhaust side but not so much on the intake. To prevent them from falling out in the first place try this. Get a (2) 20mm, 3/8 drive socket and wrap it once with some electrical tape(it will help keep them from sliding out of place). Then once you have removed all the retainers carfully remove the cam shaft, watch out for the shims. Then replace the (2) retainers that are towards the back, no the front one. Then slid the (2)20mm socket in place of the camshaft and tighten the retainers down slightly. They should hold the shims in place while you finish removing the head.
To hold the camshafts in place while you change the timing belt this was suggested by Tim Sanders
Originally Posted by Tim Sanderson
Try two small breaker bars. One bent up, one bent down. Rubber band them together. They won't line up perfectly but you should be able to get them close.
Please add on your own tips and tricks
BURTONRIDR is offline   Reply With Quote
Old 08-24-2006, 05:21 PM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
I tilt the motor on the stand so the exhaust buckets don't fall out.
A "plano" plastic organizer with 16 compartments makes a great storage container for valve components. Label each one with a position to keep everything in order and clean.
A magnetetic dental pick is great for inserting/removing keepers and the little spring seats under the valve springs.
Old 08-25-2006, 02:51 PM   #3
BURTONRIDR
Member#: 72132
2000 Legacy GT
If you wanna save yourself some money when you have a ton of stuff to buy, check everyones prices first... learned that one the hard way.
Old 08-26-2006, 12:23 AM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
On that note....call around first, as you get lower prices on the phone sometimes. Just get the person's name and price to reference.
Jay
Engine Rebuild in So Cal (SD, LA, OC...) Spaf Southern California Impreza Club Forum -- SCIC 24 12-21-2009 11:57 AM
Holiday Engine Special-GT30$1799-VF34$825-Manifolds$325-Engine Rebuild Kits$899 Gruppe-S Engine/Power/Exhaust 38 01-10-2008 08:53 PM
Post your Engine Rebuild Tips HERE thejean Built Motor Discussion 56 01-03-2008 12:07 AM
Free Crank Pulley-Free Dampers-Engine Combos-Engine Rebuild Kits$699-Manifold Combos Gruppe-S Engine/Power/Exhaust 24 11-16-2007 09:25 PM
Rebuilding Engine Heads - Tips? (and some other things) Kostamojen Subaru Conversions 18 01-06-2004 10:48 PM
