Old 08-24-2006, 11:58 AM   #1
rudyWRX
Member#: 64230
2002 dirty & dented
Black & PSM
Question Questions about upgrading my rotors and pads
to start this is what i'm working with...
17" motegi MR7 6 spoke wheels during the summer and stock suby 16" rims in the winter... on a 2002 WRX
i have never done brake work and i have a limited knowledge of the 2002 wrx set up....
i have read the info under the sticky at the top and my searches keep coming up with "for sale" threads and stuff .... i had some bent rims and i think it contributed to my "warped" rotors.... in either case i wanted to upgrade my brakes now that i'm getting into power mods...so...
the questions...
1) for a daily driver that sees some "spirited" driving here and there, is it worth getting drilled-slotted rotors?....or just slotted? or stick with plain rotors?
2) what are good replacements combos for the OEM rotors and pads
3) i'm clueless as to what to buy, i have seen deals on ebay but i would really like to know what you guys recommend before i go ebay or something...
thanks, Rudy
rudyWRX is offline   Reply With Quote
Old 08-24-2006, 12:21 PM   #2
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
0) use the 'Search in Forum(s)' selection box on the RHS of the search form to limit it to just the Technical -> Brakes, Steering, and Suspension forum
1) plain is fine, slotting isn't really necessary, and cross-drilling is generally bad as it lowers the heat capacity and adds stress points
2) & 3) Carbotech, Axxis, Hawk, EBC are all popular pad brands... just make sure you choose a 'street' pad not a 'race' pad because race pads won't stop well from cold. Some are more dusty than others if that's an issue for you. Brembo 'blank' rotors are often recommended but I haven't tried them myself - OTOH I know people who swear by cheap no-name Chinese rotors. If you follow step (0) you will find plenty more opinions. Personally I would look for deals in the NASIOC vendor forum before resorting to ebay.
UkNuck is offline   Reply With Quote
Old 08-24-2006, 12:31 PM   #3
rudyWRX
Member#: 64230
2002 dirty & dented
Black & PSM
thanks.. i will be looking in the vender forum ... i'm going to try and search again...
Old 08-24-2006, 12:53 PM   #4
ESmooth
Member#: 118082
For street only use, get the rotor finish that pleases your eye more than anything. If you arent exceeding 1000 degrees F on a regular basis (which I highly doubt you are), a quality drilled rotor will not have any cracking issues and will even add a little extra initial bite to the system. 90+% of people buying slotted or drilled rotors do it for the appearance benefit which is just fine. The pads and lines will have a far greater impact on braking performance than the rotors on a street only car so focus on those and get the rotors that you like the look of best (as long as they are quality parts).
Erik
StopTech Brake Consultant
ESmooth is offline   Reply With Quote
Old 08-24-2006, 07:05 PM   #5
wrxprowler
Member#: 101493
2004 Silver WRX
I got the powerslot/hawk hps combo from cvrmotorsports. With that and the new brake lines, I'd have to say I'm very happy.
wrxprowler is offline   Reply With Quote
question about upgrading my head unit NismoSkylineGTR Car Audio, Video & Security 4 09-12-2009 02:32 AM
question about upgrading my light bulbs NismoSkylineGTR Electrical & Lighting 4 11-10-2008 09:27 PM
Questions about upgrading my block Shabib67 Built Motor Discussion 14 03-20-2006 04:05 PM
Question about upgrading my L marcus12 Brakes, Steering & Suspension 3 02-23-2004 05:58 PM
