Old 10-28-2001, 01:38 PM   #1
scootr
Member#: 2649
00 2.5RS-t cpe BRP
64 chevelle SS
Default IS there a way to double-check my timing belt alignment?
I already put it back in on the marks. But I want to be absolutely sure before I go starting it. I had both cam gears pointed directly up and same with the crank gear, and then I line up the marks on the belt with those. Anyone.
scootr
scootr is offline   Reply With Quote
Old 10-28-2001, 11:32 PM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
you can roll the motor over and when it hit's TDC all the marks should line up....the belt will only line up like once every 9 revolutions or so.
Jeremy
Old 10-29-2001, 02:26 AM   #3
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Shouldn't it line up every other revolution?
Eric
Eric SS is offline   Reply With Quote
Old 10-29-2001, 02:35 AM   #4
scootr
Member#: 2649
00 2.5RS-t cpe BRP
64 chevelle SS
I cranked it around by hand a bunch of times and once it came back with the marks on the gears lined up facing upwards. I have not got the marks on the belt to line up yet but have probably only cranked it around like five times. So how often should it go to TDC with all of the marks facing straight up?
Old 10-29-2001, 01:16 PM   #5
Procyon
Member#: 8471
2016 Outback
Well, the 2.5L/3.0L Ford Duratech engines that we build here at work (they go in Contour/Taurus/Escape...etc) take 30 crankshaft revolutions for all the timing marks to line up again.
Procyon
Procyon is offline   Reply With Quote
Is there a way to check my posts? Love My STi Off-Topic 34 07-19-2009 04:22 AM
is there a way to tell if my sti is stage II niko01979 Newbies & FAQs 20 02-18-2007 11:09 AM
Is there a way to test if my USB connections are hooked up? Stroke Off-Topic 9 04-14-2004 11:49 AM
is there a way to read what my cel is akcel Engine Management & Tuning 4 02-23-2004 06:22 AM
Is There A Way To Check How Many Posts I Have? Tek Newbies & FAQs 5 10-28-2003 04:53 AM
