Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 08-25-2006, 07:17 PM   #1
orthojoe
Member#: 37237
2004 Impreza WRX STi
Default water injector direction?
I ended up buying the angled water injector from coolingmist. Just wondering what everybody's opinion was on which direction to point the injector
a) towards the throttle body
b) away from the throttle body
I've heard that you get better dispersement away from the throttle body, but it also seems a little counteractive to me as well.
What do you all think?
orthojoe is offline   Reply With Quote
Old 08-25-2006, 08:38 PM   #2
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Away...you will get better atomization. If you point at the throttle it probably wont mix as well.
NavyBlueSubaru is offline   Reply With Quote
Old 08-25-2006, 08:43 PM   #3
hippy
Member#: 36528
2002 Impreza Wrx
It might clog easier pointed away....
Old 08-26-2006, 12:29 AM   #4
testes1010
Member#: 47145
2012 Gas Saver
away from the TB, as stated better atomization.
spit in the wind, see what happens...
testes1010 is offline   Reply With Quote
Old 08-28-2006, 02:07 PM   #5
Ultimate Collision Center
Member#: 69072
away...but there are some that believe otherwise, like for instance with n20 injection you are typically supposed to install towards TB...
Ultimate Collision Center is offline   Reply With Quote
Are the PE injectors direct plug and play? gtasti Newbies & FAQs 8 06-20-2008 03:26 PM
Water injector placement / basic setup wcbjr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 01-04-2005 07:24 PM
Dropping WRX injectors directly onto MY00 RS possible? kgb Normally Aspirated with bolt-on Forced Induction Powertrain 4 12-20-2004 07:33 AM
Water injectors for sale N/A Technical Forum Archive 3 07-04-2000 11:32 PM
