Old 08-26-2006, 08:28 PM   #1
damonmlime
Member#: 54525
2000 ej20g rs
blue ridge pearl
Default Can anybody help me with this voltage clamp?
I have the split second vc2 voltage clamp and for the life of me, I cant get the damn thing dialed in right. I cut the wire on the ecu, it was on the b136 connector wire #29. I'm really frustrated right now, the voltage from the sensor is lower than it says it should be on the diagram. I'm really at a loss. Anybody else have problems?
damonmlime is offline   Reply With Quote
Old 08-27-2006, 11:54 AM   #2
Aphex28
Member#: 11506
2015 WRX
Try b136 pin 6.
The Pressure Sensor
Aphex28 is offline   Reply With Quote
Old 08-27-2006, 12:28 PM   #3
damonmlime
Member#: 54525
2000 ej20g rs
blue ridge pearl
Originally Posted by Aphex28
Try b136 pin 6.
The Pressure Sensor
On northuralia, the chart for the 00 says that is the front 02 sensor
Old 08-28-2006, 01:25 AM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
B136/29 is the atmospheric pressure sensor -- the sensor that tells the ECU what the pressure of the outside air is around the car. The one you want is B136/5, the Pressure Sensor wire.
Old 08-28-2006, 04:11 PM   #5
damonmlime
Member#: 54525
2000 ej20g rs
blue ridge pearl
Well if that's the case, everyone with the FAT kit should take note, the instructions for the kit are wrong. 8complex, I just cut the red wire on the map sensor and spliced it in there and it seems to be working for now. The car idles a little rough but I'm gonna try to mess with the vc2 sometime this week. Thanks 8complex for the reply.
Old 08-28-2006, 06:39 PM   #6
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Thats definitely the right wire for an 00... I read it out of the service manuals I have in my closet. I used them to wire up my Haltech, so I'm fairly sure they're right.
You should contact FAT and let them know, that is definitely a fairly serious issue.
can anybody help me with my car godfather2112 Rocky Mountains Impreza Club Forum -- RMIC 0 03-29-2004 01:46 AM
can someone help me with this HTML exercise sumit Mid Atlantic Impreza Club -- MAIC 11 11-24-2003 08:06 PM
X-post, can anyone help me with this? luvmyrs Tri-State Area Forum 0 06-04-2003 06:31 PM
can anyone help me with this idea? NateDogg Electrical & Lighting 0 03-30-2003 02:19 AM
Can everyone help me with this question ?? setiawani Off-Topic 16 09-19-2002 07:43 PM
