Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 08-26-2006, 09:00 PM   #1
fujiwara_yingyu
Member#: 116351
1998 GC8/ 2014 GK5
2006 EVO IX MR
Default engine check light was on
i changed my car's header and catback in may...yesterday the engine check light was on , i don't have any idea, could anyone help me to answer this question?
my car is 98 2.5rs
fujiwara_yingyu is offline   Reply With Quote
Old 08-26-2006, 09:01 PM   #2
fujiwara_yingyu
Member#: 116351
1998 GC8/ 2014 GK5
2006 EVO IX MR
one of dude says: More than likely, it is the P0420 Cat inefficiency code. It is a VERY common code for a Subaru and isn't anything to worry about. Keeping it off once it flashes is about impossible, but have the code pulled to be sure.
Old 08-26-2006, 10:04 PM   #3
horrorbiz
Member#: 77290
15 VW GTI / FiST
Is your car acting funny? It could be anything, your best bet is to go have the code pulled.
horrorbiz is offline   Reply With Quote
Old 08-26-2006, 10:56 PM   #4
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
How is this different than when you posted it here?
The other "dude" (me) said "We can't do a thing to help you until you get the code pulled." It still holds true. Get the code pulled.
LetItSnow is offline   Reply With Quote
Old 08-28-2006, 07:47 AM   #5
fujiwara_yingyu
Member#: 116351
1998 GC8/ 2014 GK5
2006 EVO IX MR
code: 0163 auto sensor...
the auto sensor need to be changed...
Old 08-28-2006, 09:17 PM   #6
LetItSnow
Member#: 38222
'10 &'12 Foresters
The oxygen sensor, actually.
P0163 - O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
Old 08-29-2006, 09:51 AM   #7
fujiwara_yingyu
Member#: 116351
1998 GC8/ 2014 GK5
2006 EVO IX MR
how much for one sensor tho??i don't have any ideas
Old 08-29-2006, 10:41 AM   #8
horrorbiz
Member#: 77290
15 VW GTI / FiST
$100ish I believe.
Old 08-29-2006, 06:28 PM   #9
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
Best way to find this out is to go to a parts store and tell them what you need, they will tell you what it costs.
HondaH8er is offline   Reply With Quote
Old 08-29-2006, 08:23 PM   #10
fujiwara_yingyu
Member#: 116351
1998 GC8/ 2014 GK5
2006 EVO IX MR
NGK and Bosch sensor bosch is 149 canadian$, Ngk is 165 canadian dollar, which one is better ?
Old 08-30-2006, 05:26 AM   #11
fujiwara_yingyu
Member#: 116351
1998 GC8/ 2014 GK5
2006 EVO IX MR
where is the oxygen sensor around engine area?? i want to change it by myself
Old 08-30-2006, 08:33 PM   #12
wagonman
Member#: 971
Doesn't matter which one, alot of people run Bosch.
Both o2 sensors will be in your exhaust cat. section. You will need a special socket to make the job easy, which you can get at the parts store. Be prepared for them to be tough to get out.
wagonman is offline   Reply With Quote
Old 09-01-2006, 04:26 AM   #13
fujiwara_yingyu
Member#: 116351
1998 GC8/ 2014 GK5
2006 EVO IX MR
i changed the front o2sensor already,but how can i reset the ECU. i heard the classic impreza has a different way to reset...damn, the lihgt is still on, and i scanned again, no code is on.
Old 09-01-2006, 04:21 PM   #14
wagonman
Member#: 971
un-hook the negative battery cable and let it set for 15-20 mins. That should do it.
Old 09-10-2006, 06:05 AM   #15
william41cn
Member#: 93558
i got a brand new ntk o2 sensor, that one is the front one... and i changed it, but the engine check light is still on.
i guess does the rear sensor broke as well??? will the rear o2sensor influence the light on?? i don't have any idea. by the way my car's header also changed, but the engine check light was not on when i install the aftermarket header. anyone can help me to answer why my car's engine check light was on???
william41cn is offline   Reply With Quote
Old 09-10-2006, 10:11 AM   #16
wagonman
Member#: 971
go have it scanned again, see what the code is...then go from there. They can turn the light off as well. We cant help if we don't know what the code is this time.
Old 09-10-2006, 10:31 AM   #17
william41cn
Member#: 93558
what does "Bank 2 Sensor 3" mean?
Old 09-10-2006, 10:37 AM   #18
william41cn
Member#: 93558
i will scan again
Old 09-10-2006, 06:37 PM   #19
william41cn
Member#: 93558
today i scan the code again
p0136 O2 sensor circuit malfunction
the front sensor is brand one, i just changed it
but the light is still on? is that the rear one problem or the front sensor wire are loose or some connection problems??
Old 09-10-2006, 06:44 PM   #20
Charge
Member#: 3313
Well...I used that handy dandy search function and came up with a slew of threads that said a "P0136" code is the rear O2 sensor.
So you need to replace that sensor, or consider one of those MIL eliminator fixes(a bit cheaper). For the MIL eliminator...do a search.
Charge is offline   Reply With Quote
Old 09-10-2006, 07:35 PM   #21
william41cn
Member#: 93558
thx , search is really useful to me
engine check light is on fujiwara_yingyu Normally Aspirated Powertrain 2 08-26-2006 12:51 PM
engine check light on malibuda Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-10-2005 11:05 AM
Engine Check Light on?! ice_bomb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-07-2005 03:02 AM
Engine check light & Cruise light on Plasteredcat Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 05-19-2004 11:55 AM
Help! My "Check Engine" light is on... macrac Technical Forum Archive 6 08-07-2000 10:08 AM
