Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum > Western Canada
Old 08-26-2006, 10:29 PM   #1
GD8
Member#: 65085
2004 Impreza WRX
World Rally Blue
Default Cabin air filter alternative for 04 impreza (may fit other years)
For the guys that doesn't have access to a subaru dealer but have a typical car parts store in your town (ex: Fort McMurray), I have found a solution for your cabin air filter need and save you some $$.
I know for a fact the Subaru Impreza cabin air filter is not made commercially and are only available at the dealer. So I did some hunting around, I went to Nappa, Auto Value etc.. and found nothing. So I talked to the parts rep at Canadian tire and he allowed me to go to his back shelf and try to match an air filter of similar size. One hour later after opening every possible box and found a filter that worked.
Filter made for: Mercedes
Made by: micronAir
Part Number at Canadian tire: 23-3855-4
Filter Model number: MB01137P
When you get the filter you will need to cut one end so it fits in your air filter compartment:
Steps:
1. Take your filter out of box (duh...), you will notice one end of the filter is sloped. (Imagine a triangle glued to a rectangle)
2. What you want to do is to cut out the triangle half leaving you a rectangle shape
2. Measure 12.5 cementers from the bottom edge of the triangle and mark the filter.
3. Cut across the filter following the folds and you got your self a cabin air filter that fits
4. Follow the instructions in your owners manual to install the air filter
Some points: (filter at Canadian tire vs. Factory)
-This filter costs $20, I think the factory one is around $35 ish+
-$20 filter is better quality, denser fibers
-$20 filter is much more rigid in construction
-$20 filter has air flow check flaps surrounding all four borders
Ummm.. I think we have a winner
GD8 is offline   Reply With Quote
Old 08-28-2006, 12:52 PM   #2
bigbear522
Member#: 21304
2002 Impreza WRX
Funky Silver Party Wagon
The subaru filter is way more then $35, I believe it was almost $70
bigbear522 is offline   Reply With Quote
Old 08-28-2006, 03:38 PM   #3
GD8
Member#: 65085
2004 Impreza WRX
World Rally Blue
^ I knew it was expensive. But I bought my oem filter at cost which was around that price. Trust me this filter is better in every way shape and form.
Old 08-28-2006, 06:53 PM   #4
benyl
Member#: 48833
'05 Dirty STi
'08 E92 335,'03 E46 M3C
Does replacing this get rid of the smell when you turn off the air conditioning?
benyl is offline   Reply With Quote
Old 08-28-2006, 07:32 PM   #5
Airboy
Member#: 72829
2006 WRX
2015 WRX
I don't think it will because the smell comes from the evaporator area (mold related I believe). Not even sure where that is in the Subrau. The one in our VW is not accessible and the only (cheap) way that seems to help with that smell is to turn the fan on full blast and spray a whole bunch of Lysol into the AC air intake to try and kill the mold.
There is a commercial product to do this but can't remember the name.
To prevent the smell (mold build-up) I turn off the AC some minutes before my destination and let the fans dry out the evaporator.
Airboy is online now   Reply With Quote
Old 08-28-2006, 10:15 PM   #6
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Now with more clunks!
Default Or...
You can also make 6 filters out of one furnace panel filter. You never see them so who cares about the ghetto mod aspect? It's just an air filter for the cabin.
I got some info from the thread below and decided to try it.
EDIT: http://forums.nasioc.com/forums/show...t=cabin+filter
The gist of that ^ thread:
1: Buy home panel filter - Top rated by Consumer Reports = 3M Filtrete (1250,1000, or 600) <-in that order
2: Mark out 4 shapes of 8.25" x 7.375"
3: Note airflow direction on each piece
4: Cut using heavy-duty shears or snips
5: Wrap edges with duct tape or cloth tape
6: Install
I went to Home Depot today and had 3 pleasant surprises.
First, They had the newest, bestest, 3M 1500 Maximum Allergen
Second, A 2-pack was $42.39 incl. GST
Third, They were oversized @ 25" x 20" (1" thick) so I could now get 6/panel instead of 4!
I cut them with some good scissors I didn't care about nicking up...tin snips were too clumsy. I also peeled/cut back most of the cardboard on the faces of the filters but I left the vertical edge for strength. I've only peeled the left side in the pic.
I little duct tape and here's what I've got. It's pretty rigid!
Perfect fit! Snug on all sides!
I spent $45 for 12 filters. That's $3.75/filter!
02WHITEDUB is offline   Reply With Quote
Old 08-29-2006, 03:04 PM   #7
GD8
Member#: 65085
2004 Impreza WRX
World Rally Blue
SOC also have something that gets rid of the AC smell. But be very very careful. I go them to do it once and it took paint off the interior trim. SOC had to replace the trim.
Old 09-04-2006, 03:05 AM   #8
02WHITEDUB
Member#: 96793
02 ProTuned TD04
^^Updated post 2 up^^
Works great! No noticeable loss in fan pressure.
Old 09-12-2006, 12:25 PM   #9
VoltesV
Member#: 48021
"02Whitedub" that's a great mod to replace the cabin filter. The only question I have is that what is orientation of the fiter, with respect to air flow of the A/C system? Is the filter installed with the airflow pointing down? It would help if the airflow directions that you marked were visible on your picture when you showed the filter installed.
VoltesV is offline   Reply With Quote
Old 09-15-2006, 03:25 AM   #10
bezerk
Member#: 44809
2008 BMW M3
SATURDAY!!!!!!!!!!!!!!!
Just did this tonight! So simple! THANKS!
bezerk is offline   Reply With Quote
Old 09-18-2006, 01:21 AM   #11
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Airflow in the car goes from top to bottom of the slot.
Old 09-18-2006, 02:27 AM   #12
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
ohhh SNAP subaru house hold filter FTW!!
Chp_Stix is offline   Reply With Quote
Old 03-15-2007, 03:03 PM   #13
lh0628
Member#: 138256
2004 FXT
bump to a good thread.
lh0628 is offline   Reply With Quote
Old 03-15-2007, 03:52 PM   #14
02WHITEDUB
Member#: 96793
02 ProTuned TD04
w00t
I'll be changing my first one out pretty soon - I'll take a pic of the used one.
Old 03-15-2007, 03:53 PM   #15
Pee_Sack
Member#: 98266
2003 WRX Cobb Stg 2
Same as the sky
Where abouts does this filter go? I would like to replace mine as I never have in the 1+ year I have had my car. I dont know if the previous owner did it either.
Pee_Sack is offline   Reply With Quote
Old 03-15-2007, 04:30 PM   #16
GrantC
Member#: 94477
2005 WRX Stg2/STX
Behind your glovebox.
2 (i think plastic rivet things)
7 (i think screws)
voila!
While you're in there you can disable your DRL too.
GrantC is offline   Reply With Quote
Old 03-15-2007, 04:46 PM   #17
tscanuck
Member#: 83296
'07 2.5i wagon
SGM
Do 2.5i's have this filter too?
tscanuck is offline   Reply With Quote
Old 03-15-2007, 04:47 PM   #18
02WHITEDUB
Member#: 96793
02 ProTuned TD04
^^Almost certainly^^
Old 03-15-2007, 05:00 PM   #19
GrantC
Member#: 94477
2005 WRX Stg2/STX
I believe they have the holder for it, but it may have not had a filter in it. As it was an option on the non-turbo models.
Old 03-16-2007, 02:40 AM   #20
lh0628
Member#: 138256
2004 FXT
I think there are a total of 9 screws and one plastic thing on the right.
I've seen two ways with this though. Some claim to put the filter above the blower fan like this post. And some say that they put two filters (one on top of each other) on the left of the blower fan.
Old 08-05-2007, 10:12 PM   #21
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Default Update:
So I changed my first DIY cabin-air filter today:
19,000 kms - 10 months
Before:
After:
Old 08-06-2007, 12:43 PM   #22
Zuffy
Member#: 35268
2004 WRX Stg2 & with
added PDX goodness
Nice! Looks like they really do catch a lot of crap. Gotta do that too now.
Zuffy is offline   Reply With Quote
Old 08-06-2007, 03:05 PM   #23
02WHITEDUB
Member#: 96793
02 ProTuned TD04
If you do install one, make sure to change it semi-regularly. My fan pressure increased quite a bit after putting in a clean one. It had weakened so slowly that I didn't notice it was kinda weak until I put in a new one.
Old 02-23-2008, 03:27 PM   #24
BruceDude
Member#: 172571
2004 2.5RS
DRL means what?
BruceDude is offline   Reply With Quote
Old 02-23-2008, 04:31 PM   #25
bezerk
Member#: 44809
2008 BMW M3
Daytime Running Lights.
Purolator Cabin Air Filter for the Pignose Impreza subySerb Service & Maintenance 7 06-15-2009 04:58 PM
04-07 Impreza Cabin Air Filter -NEW- JayGold MWSOC Private Classifieds 3 03-31-2009 01:43 PM
2007 Impreza cover, cabin air filters, oil filters, etc. mopartodd Accessories & Misc 2 11-02-2008 04:40 AM
K&N air filter part# for 06 Impreza? mummer43 Normally Aspirated Powertrain 3 09-30-2006 10:20 PM
Cabin air filter for 2005 Impreza RS syu347 Vancouver Impreza Club Forum -- VIC 7 08-14-2006 12:12 AM
