Old 10-28-2001, 10:44 PM   #1
jHughes
Member#: 608
Unhappy cruise control is broken
My cruise control suddenly stopped working. One morning it just wouldn't work. Has this happened to anyone else? It seems like it should be some loose wire or disconnected hose or fuse...? anyone have any ideas or experience with this problem?
thanks
justin
jHughes is offline   Reply With Quote
Old 10-29-2001, 01:00 PM   #2
paulnose
Member#: 4348
2001 2.5RS
Silverthorn
My switch wasn't connected when they delivered the car to me. But that was it. Might want to try checking the fuse. Check the vacuum line to the cruise control unit, and check the switch on the dash.
You can always just take the cruise control out, only took me 10 minutes, but kinda defeats the purpose. (You need to take it out/relocate for turbo mod.)
paulnose is offline   Reply With Quote
Old 10-29-2001, 04:03 PM   #3
bluesubie
Member#: 767
04 FXT
Lightbulb
Manual tranny?
Other than checking the fuse and vacuum hose, also check that the clutch pedal switch is working properly.
There is a plastic stopper covering a hole on the clutch pedal arm. If this plastic breaks or pops off, the switch that disengages the cruise when you press the clutch will always be on. The part is under $2.00.
Dennis
Old 11-03-2001, 01:34 PM   #4
Muqeem
Member#: 7299
2002 WRX Sedan
WR Blue
Smile Cruise control
I had the same problem as you did Justin. One day, my cruise control did not work and previous to that, it was working perfectly.
My buddy at the dealership looked at it and discovered that the plastic stopper on the clutch pedal arm was broken and was in fact not there anymore. He replaced the stopper and it has been fine since then.
Like Dennis mentioned, I suggest you look at that, if you have not already done so - that should be the problem.
Muqeem
Muqeem is offline   Reply With Quote
Old 11-03-2001, 02:13 PM   #5
paulnose
Member#: 4348
2001 2.5RS
Silverthorn
Oh, check your brake lights, read in another post that if your brakelights are out the cruise control wont work, not sure that this is true or not.
Old 11-03-2001, 04:42 PM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
this refers to the brake light switch not operating which is true. If the brake light switch or clutch pedal switch has gone bad your cruise control will not operate.
jeremy
Old 11-07-2001, 11:23 AM   #7
DuneHopper
Member#: 1249
2000 OBS
Yup, mine crapped out, too. Still under warranty, though.
DuneHopper is offline   Reply With Quote
Old 11-07-2001, 11:32 AM   #8
bluesubie
Member#: 767
04 FXT
Question Stopper
Regarding the stopper and switch.
Wouldn't it make more sense not to have a hole in the clutch pedal arm in the first place?
Maybe just have the switch in direct contact with the pedal arm? Or would that not be good for the switch?
Dennis
Old 11-09-2001, 01:39 PM   #9
OBS Fan
Member#: 9751
I'm having the same problem (97 OBS). Can anybody give more detail or where to find the vacuum line that might be disconnected on a 2.2L? Would the plastic stopper on the clutch pedal be white plastic? I found it on my floormat the other day. I thought it was only a bumper stop for the pedal arm, so I ignored it. Any further description on where to look for the clutch pedal switch? Can I disengage this switch?
Do check your fuses, on the 97 OBS (and probably RS) the cruise control fuse is also for ABS. So, if your cruise is out, your ABS could be out too.
Thanks for the info everybody.
-OBS Fan
OBS Fan is offline   Reply With Quote
Old 08-23-2008, 10:29 PM   #10
compleckz
Member#: 145989
1998 Impreza L
back from the dead, my cruise hasnt been working for 3 months (98 2.2), and the clutch pedal stopper thing was my problem. i stuck a small screw in the hole and all is well. that hole is the stupidest thing ever though. will be getting the right part on monday
thanks
compleckz is offline   Reply With Quote
Old 08-25-2008, 10:15 AM   #11
MrH
Member#: 186279
2016 Forester XT
Ice Silver
Muqeem
Yep. It just happend to me too. I found the stopper laying on the floor right when the cruise control stopped working. I end up buying a carpet fastener. Now it works.
MrH is offline   Reply With Quote
Old 08-25-2008, 10:32 AM   #12
winterparkmg
Member#: 187656
2003 WRX
I have been searching for this answer for a long time!!! Will try the screw method and report back. I checked relays and cables. Count on a stupid screw/plug to break a cross-country essential component...
winterparkmg is offline   Reply With Quote
Old 08-25-2008, 08:56 PM   #13
winterparkmg
Member#: 187656
2003 WRX
Put a wood screw in the hole, pointing toward the engine and called it good. Sure enough, cruise control works! I'm glad I was lazy and didn't pay someone a ton of money to do a "diagnostics check" on my cruise control. Thanks guys!
Old 08-27-2008, 02:33 PM   #14
mcarthurpaul
Member#: 80144
2004 wrx wagon
I have had to fix my switch twice before, but the cruise control has stopped working again and the switch does not seem to be the problem. Do you have a pic of the plug on the clutch arm?
mcarthurpaul is offline   Reply With Quote
Old 11-02-2008, 09:05 PM   #15
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
bump... I'm having this issue also.. I found the plug but am unsure as to where exactly it goes...
jigga is offline   Reply With Quote
Old 11-03-2008, 01:01 AM   #16
BillJC
Member#: 31002
Can someone take a picture of the plug? My cruise stopped working a few months ago and I have been too busy to diagnose it. If I know what to look for, it would make things a little simpler for me.
Thanks,
Bill
BillJC is offline   Reply With Quote
Old 11-19-2008, 05:56 PM   #17
supersuby2
Member#: 161678
2002 wrx V5 RA swap
Bump for a pic.... my boss has a 2002 forester that the cruise quit working on and i think this may be the problem
supersuby2 is offline   Reply With Quote
Old 11-19-2008, 10:25 PM   #18
BillJC
Member#: 31002
I figured it out. Go and buy a " nylon plug from a hardware store. It fits in the hold on the clutch pedal. If you follow the pedal up, it's pretty obvious where it needs to go. There is a switch that just sits there if the plug is gone.
Bill
Broken Cruise Control, HELP BlueBerryRex Electrical & Lighting 3 03-12-2004 12:54 AM
Broken Cruise control! BlueBerryRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-11-2004 02:15 AM
cruise control problem / broken avatarr Electrical & Lighting 1 10-10-2003 11:10 AM
Broken Cruise control, horn, and probably airbag rs-scooby Service & Maintenance 3 10-05-2003 12:04 PM
Broken Cruise control, horn, and probably airbag rs-scooby Tri-State Area Forum 4 10-04-2003 09:28 PM
