Old 08-27-2006, 12:08 PM   #1
Numbchux
Member#: 71658
'84 Brat
4" lift and 29" tires
Default Phase 1 EJ22 swap wiring problem
ok, swapping an EJ22 out of a '92 legacy into my '92 loyale....
I've got:
spark
compression
fuel pressure (to the rails)
but no combustion...
any ideas? I'm going to go try to hook up the CEL, and see if I can get a trouble code, and I'll go from there.
Numbchux is offline   Reply With Quote
Old 08-28-2006, 02:58 AM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
I read the thread on USMB and can't think of any one thing that stands out. It could be the way you have the fuel pump wired, try closing the OEM relay without the load, so the ECU sees it activiating. Maybe the TPS? Make sure it's not telling the ECU you're at WOT during the cranking cycle?
Besides that, I got nothing....
Jay Storm
Old 08-28-2006, 11:42 AM   #3
Numbchux
Member#: 71658
'84 Brat
great....me either....although I still haven't figured out the CEL
I got the fuel pump relay wired how it should now. I hardwired it before because my ECU wasn't grounding it like it should. but then I got the ECU all the powers/grounds it needed, and I could hook the relay up right again.
and I'm assuming that all my sensors etc. work right, since the motor ran great before we pulled it from the donor car, just a few feet from where it sits now.....
Old 08-28-2006, 12:30 PM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
Hmmm....
Maybe it's that ECU?
Old 08-28-2006, 01:49 PM   #5
Numbchux
Member#: 71658
'84 Brat
Hmmm....
it should be good since the engine ran, but I though just in case I short-circuited something, I swapped it for another one I have that should be good...and still no go.
When my dad get's home this afternoon, I'll plug it into the '94 and see if it works there...
I just went out and double-checked the fuel lines....again...and they're all correct
only thing I can think of, is the pressure regulator...how does it work? is it possible I disconnected a vacuum line somewhere and it wouldn't let any fuel through?
I think I'm going to disconnect the regulator, and put a bucket under it, and turn the ign on, and see if fuel comes out that end of the rail....maybe something got in there while I was swapping it....
EDIT: just plugged the ECU into our '94 legacy, works fine.
then I went back and I pulled the pressure regulator off, and there is fuel running all the way through the rails. so it has to be the injectors. I'm having trouble beleiving that all 4 signal wires from the ECU to the injectors are getting bad signal, but I'll rig something up to test that today.
is there a sensor (i.e. crank angle etc.) that JUST controls fuel? and wouldn't effect the spark?
EDIT 2: I just checked, and I have good continuity between all 4 injectors, the TPS, and the knock sensor and the ECU...
Old 08-29-2006, 05:43 PM   #6
Numbchux
Member#: 71658
'84 Brat
bump and update:
the timing belts are fine. I sprayed some carb cleaner in the throttle body....and got nothing. I added a couple grounds in a couple places under the hood. made sure all my solders for crank and cam sensors had held, and weren't shorting to any adjacent wires. I'm going to have dinner, and then pull a fuel rail and see if the injectors are getting signal...
Old 08-31-2006, 05:24 AM   #7
Numbchux
Member#: 71658
'84 Brat
IT WORKS!!! but it's 4am...full explanation of what I did to make it work tomorrow....but it took about 10hrs....
Old 12-14-2006, 05:27 PM   #8
gloyale
Member#: 134923
1989 GL w/96 EJ22
What did you have to do to get it to bolt in to Tranny? Crossmember? clutch,torque converter? ETC. I want to do this swap in my 89 GL FT4WD.
gloyale is offline   Reply With Quote
Old 12-14-2006, 11:04 PM   #9
Numbchux
Member#: 71658
'84 Brat
Join the USMB. www.ultimatesubaru.org and check out the Retrofitting forum...
I'm in the process of compiling a full writeup on the swap. the first draft of it is available for download. it covers everything except wiring...
need an adapter plate to adapt the EJ engine to an EA tranny. and the flywheel needs to be modified a bit. full explanation in the write-up.
adapter plates available here: www.mroseusa.com
1995 subaru legacy l with 2002 subaru wrx swap wiring problem hybridpatient95 Subaru Conversions 1 05-29-2008 06:43 AM
Headgasket VS. Phase II EJ25 to Phase II EJ22 swap- "Simple"? 99legacyL Newbies & FAQs 0 03-01-2008 04:09 PM
1998 Phase 1 DOHC swap for a newer Phase 2? adam555 Subaru Conversions 4 06-03-2004 05:44 PM
Phase 1 EJ22 mated to Phase 2 EJ25 SHortblock? huckedup16 Normally Aspirated Powertrain 0 03-25-2004 09:24 PM
Help engine swap wiring problems. james_gt Electrical & Lighting 2 08-13-2003 07:48 PM
