Old 08-28-2006, 01:39 AM   #1
bl_easy
Member#: 91407
Ver. 2 WRX STi wagon
BRetty green
Question Injector removal.
What's the trick to getting the injectors out of the fuel rail?
I'm trying to find out why I've got a misfire and want to swap the misfiring cylinder's injector with another cylinder's to see if the code follows, that's all.
I saw I had to unscrew the metal caps and unplug the harness, but couldn't figure out what more it needed before giving up.
Thanks.
-Brett
EDIT: This is on a '97 EJ22.
bl_easy is offline   Reply With Quote
Old 08-28-2006, 03:22 AM   #2
redgrocerygetter
Member#: 42044
1998 Legacy GT
I have a 98 legacy gt and all I had to do was just pull them out. I was really tuff but that's all you have to do after you unscrew the caps. I had to use pliers and being very careful. Also use some lube to put them back in the fuel rail. You can use just regular (clean) motor oil. It burns off after some run time, besides your only using a little bit on your finger to smear around the gaskets.
redgrocerygetter is offline   Reply With Quote
Old 08-28-2006, 07:54 AM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
Spray a little WD40 in after taking off the caps (sidefeed right?) and work the injectors around some. They'll come out eventually....it takes some effort at first, then your fingers get bloodied and numb and you don't care anymore.
Jay
Old 08-28-2006, 10:29 AM   #4
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
Pull. Hard.
t3hWIT is offline   Reply With Quote
Old 08-28-2006, 09:15 PM   #5
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
If you pull the fuel rails, you can simply stick the end of the injector on the edge of a table, tap the fuel rail sharply, and the injector will pop out. Done this many, many times.
Old 08-28-2006, 10:02 PM   #6
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
What a perfectly appropriate topic. I was just trying to remove a set of side feed injectors last night. WOW they just don't want to come out.
So, just pull harder and use some wd-40 huh?
Ok I'll give it a shot.
Thanks guys.
Tim Sanderson is offline   Reply With Quote
Old 08-28-2006, 10:09 PM   #7
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
I vote again for fuel rail removal. I have crushed an injector or two trying to pull them out.......
Old 08-29-2006, 01:29 AM   #8
bl_easy
Member#: 91407
BRetty green
Well, I am going to hold off on this, since I haven't gotten a misfire code since I SeaFoamed this bitch the other day. If I get it again, I'll get to pulling these injectors. But thanks to all so far.
Old 08-29-2006, 01:48 AM   #9
SubNiSmO
Member#: 104417
2007 STi
White Satin Pearl
silly brett, yank those suckas!!!!
adrian
SubNiSmO is offline   Reply With Quote
injector removal help gomikeyp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 03-19-2006 08:24 PM
Quick question on injector removal Rick Schu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-12-2005 01:17 PM
MY99 \ MY00 Injector Removal rexee Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-21-2005 05:24 AM
04 Sti injector removal DIY? trail*of*dead Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 01-22-2005 06:11 PM
injector removal montyj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-26-2003 12:22 PM
