Old 08-28-2006, 02:30 AM   #1
TurboJew
Member#: 119029
2003 WRX
Question JDM V7 suspension on 2003 WRX...
I did some searching but I couldnt find a straight answer to this question:
1. Will the suspension from a JDM V7 STI be a direct bolt-on to a 2003 WRX
2. How much of a drop will this give me on an otherwise stock suspension '03 WRX
3. Will the ride quality go to absolute hell
I was thinking of just a set of Tein H-Tech springs for a bit of a drop to make the car look less goofy and to stiffen things up a bit but I worry about doing springs without dampers. I drive this car in NYC alot so I dont want a crazy drop (1.5" drop in front at most) or super-stiff ride quality but this car is definately softer than I'd like it. I drove a couple of '04 STI's while searching for a car and I liked the ride on those with their stock suspensions.
The car in question:
I'm not a car n00b (this is my 3rd turbo and 2nd turbo/awd car and I've done plenty of weekend wrenching) but I am a sc00b n00b so have mercy
TurboJew is offline   Reply With Quote
Old 08-28-2006, 04:05 AM   #2
Mark Avery
Member#: 10313
2002 WRX wagon
Yes
Very little - maybe 10mm or so
It will obviously be more aggressive than a WRX, but compared to an STi? No. Using lowering springs, however, may look cool, but it gives you less bump absorbing suspension travel. What that means to you depends on how bad the roads are where you drive.
Mark Avery is offline   Reply With Quote
V7 JDM Sti suspension and 06 wrx suspension Wannascooby Brakes, Steering & Suspension 4 10-07-2006 09:35 AM
JDM STI V7 suspensions on 06 WRX, is it possible? Lam Brakes, Steering & Suspension 2 04-28-2006 02:38 PM
v7 suspension on 05 wrx? bigworm Brakes, Steering & Suspension 3 01-12-2006 11:45 AM
jdm sti suspension on usdm wrx response Brakes, Steering & Suspension 1 01-01-2005 07:09 PM
STi suspension on 2003 WRX ApexMaster Brakes, Steering & Suspension 2 01-15-2004 11:16 AM
