Old 10-02-2008, 06:48 PM   #76
spike93
Member#: 190292
2005 stage II wrx
CGM
Originally Posted by orchidrider View Post
so does the 2.20 ohm resistor just simply wire into the EGT sensor? thats what i think it does but im a visual person, and all ive had to go by was hear say
i believe so,
http://www.clubwrx.net/forums/engine...istor-mod.html
this should help clear it up
spike93 is offline   Reply With Quote
Old 11-24-2008, 05:55 PM   #77
roadtrip1098
Member#: 185688
2006 STi
WR Blue
Originally Posted by Uncle Scotty View Post
...and I know of 2 guys working together that have swapped one in just under an hour.....after having done a few.
It really isn't a big deal if ya have all the right tools, ready, and the sequence down.
....and that one bolt at the bottom of the UP is a LOT easier with a 12" extention and a couple 'flex sockets' in 12mm and 14mm and a set of gearwrenches make the job a LOT easier.
Thanks for the tool list. Has anyone done a header swap? I am thinking to avoid trouble, I want to do the headers with the up-pipe. Since I have the 2008, I wont need to do the oil pan and pump change, it is said to be a direct fit with no mods needed. Looking for first hand experience as to the performance gains....
roadtrip1098 is offline   Reply With Quote
Old 06-30-2009, 05:37 PM   #78
down_for_the_scooby
Member#: 78314
04 PSM WRX
Audi mask the right way
I did my downpipe in 2 minutes. Its real easy when the tranny is 10 feet away, sitting on a bench lol. Screw Liquid wrench though. Get PB Blaster. Spray it on the night before and right before you start and it will save you a lot of tears.
down_for_the_scooby is offline   Reply With Quote
Old 06-30-2009, 10:52 PM   #79
SlverEJ20
Member#: 157158
05 WRX stage 2
Holy thread bump!
SlverEJ20 is offline   Reply With Quote
Old 06-30-2009, 11:11 PM   #80
PostaL cm
Member#: 156654
2002 Dom 3.0 Hybrid
hahah BEST thread opener I have ever enjoyed reading..
And +1 to PB Blaster. It's die-rust-die in a can.
PostaL cm is offline   Reply With Quote
Old 06-30-2009, 11:15 PM   #81
woodys77
Member#: 192147
2007 STI EfiLogics
422whp 421wtq fpgreen
Originally Posted by SlverEJ20 View Post
Holy thread bump!
woodys77 is offline   Reply With Quote
Old 06-30-2009, 11:32 PM   #82
MF-DIF
Member#: 62197
2002 PSM WRX
LG/Blurple FZ-09
My friend and I did the uppipe, injector install (GBOD), VF turbo, and fuel pump in about 4hrs. I remember cutting a section of the heatshield to get to the 02 sensor...all we had was a big oil wrench so no way it was fitting in that hole. Then the exhaust manifold bolts where frozen...so we torqued and torqued until they snapped.
The GBOD where pretty easy with ratchet wrenches. Dunno what the big deal about those are about it.
I have heard that gutting the cat is horrible though. My friend just ended up cutting the damn thing apart from the side, gutting, then welding the pipe back shut. He works at a muffler shop so he had access to all these tools, but he did mention even with that it was PITA and would never do it again.
MF-DIF is offline   Reply With Quote
Old 06-30-2009, 11:44 PM   #83
SlverEJ20
Member#: 157158
05 WRX stage 2
^^^^ gutting my up pipe cat was a pain...to any one gutting a up pipe anytime soon, go with a larger drill bit.
Old 07-01-2009, 01:58 AM   #84
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
The op is hilarious, It only took me about an hour and a half to do this with a friend on his car. I also had to drill a hole and weld a bung into the uppipe for the temp sensor.
crpwrx is offline   Reply With Quote
Old 07-01-2009, 05:24 PM   #85
2.5ReallySexy
Member#: 167943
Make sure you guys are cutting off the tip of the 02 sensor or it will break off into your turbo.
2.5ReallySexy is offline   Reply With Quote
Old 07-01-2009, 05:24 PM   #86
2.5ReallySexy
Member#: 167943
Also everyone saying they did it in whatever time. Gutting takes the most time. I dont think any of you can take it out gut it and put it back in in less then 2 hours.
Old 07-01-2009, 06:08 PM   #87
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
gutting an up pipe is an idiots task and fools errand
just get one with no cat and be done
Old 07-01-2009, 08:14 PM   #88
neversummer489
Member#: 153729
PSM Bugeye
Missing rod bearing??
Did mine a couple times first one took 2 days cuz the guy before me didn't use anti sieze on the dp I used everything I could think of to get through them but alas I broke all 5 studs/bolts after that only took 3 hrs to take off then go get parts and what not got it cleaned up the next day. Since then I took 2 hrs on jackstands and 1.5 hrs on a lift to do it. Once you have done it it's not bad. And for God sake use anti sieze on everything you want to ever come off again
neversummer489 is offline   Reply With Quote
Old 07-01-2009, 08:18 PM   #89
neversummer489
Member#: 153729
PSM Bugeye
words of wisdom as usual
Old 07-01-2009, 10:17 PM   #90
Ryan314
Member#: 82989
Hybrid EJ257
....or just not use a sensor at all in your uppipe.
Ryan314 is offline   Reply With Quote
Old 07-01-2009, 10:34 PM   #91
2.5ReallySexy
Member#: 167943
well yeah but if you plan on putting that sensor back in, the whole little thing needs to be cut off. Just a warning.
also uncle scotty that is true and all but not everyone wants to spend 100 dollars on a catless up pipe when the stock one is just as efficent when you gut the cat. Half way through mine i was ready to go out and buy a up pipe but i just stuck through it.
Old 07-01-2009, 11:47 PM   #92
sargepk
Member#: 154335
<i> not everyone wants to spend 100 dollars on a catless up pipe when the stock one is just as efficient when you gut the cat. </i>
You can get them on ebay including shipping for < $50. Granted, mine showed up with extra long bolts that had to be replaced, but I guess that's the price I pay for going on the cheap.
Nonetheless, my install took about 1.5 days. Ugh! If you don't run into any problems, I don't doubt it could happen in about 6 hours. However, I've never really had any repair that didn't have something unexpected happen in the middle.
sargepk is offline   Reply With Quote
Old 07-09-2009, 05:45 PM   #93
sourcandy
Member#: 212410
I alotted all day to do this and I'm still not done. It's not the turbo bolts or uppipe/ downpipe bolts. It's the damn exhaust bolts on the midpipe with the spring the 12/14 combo that snapped in half. PB Blaster is your friend, makes everything easier. I ended up having to cut a slit in the front heatshield to slid it off around the 02 sensor, even with a couple hours of resoaking the 02 sensor it just wasn't budging. I went and bought a 02 sensor socket just for this task, but there was no point. Maybe I'll be finished before 7
sourcandy is offline   Reply With Quote
Old 07-09-2009, 06:02 PM   #94
alenk37
Member#: 211850
03 WRX
Midnight Black Pearl
up-pipe installation sucked! hands down, especially when you strip the bolt that you need to remove to lift the engine, try doing it without that step. it is a PITA!!! If i had to re-do my installations I would just pay someone to do that and do the rest myself. I got the 50 dollar one too shipped from ebay... it is good, but longs bolts as said, but does the job just like any other ridiculously expensive 1 in half foot pipe that people try to charge $200 plus. Why?
alenk37 is offline   Reply With Quote
Old 07-09-2009, 06:12 PM   #95
Jons_uurx
Member#: 189180
04 wrx jbp stg dos
03 Infiniti G35s
yeah some cars have old rusted bolts and what not, my install took like 20 minutes and was actually kinda fun, i know but i had no trouble. Maybe using a lift is what helped out, i think putting the down pipe was harder.
Jons_uurx is offline   Reply With Quote
Old 07-09-2009, 06:44 PM   #96
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
^ 20 minute uppipe install???? You = Teh liarz!!!!
paintbing is offline   Reply With Quote
Old 07-09-2009, 08:19 PM   #97
Jons_uurx
Member#: 189180
04 wrx jbp stg dos
03 Infiniti G35s
So.... its not possible? I swear a lift is the way do do it. i also had 3 guys helping me though. I could imagine doing it in my drive F-that!
Old 07-09-2009, 09:53 PM   #98
rkramer
Member#: 118209
2015 WRX Limitec
yeah i agree, there is no way an uppipe could be completed in 20 minutes! Video tape the next one! 3 experienced guys with a lift and all the right tools could probably go from start to finish under an hour if everything went perfectly.
Old 07-09-2009, 10:31 PM   #99
Jons_uurx
Member#: 189180
04 wrx jbp stg dos
03 Infiniti G35s
An hour, dude are you serious? I was in a hurry that day so we attacked like no other, the thing that took the longest was lining up the engine mounts to screw her back in place. Oh in it was four guys including my self, these guys are crazy fast they have years of experiance working on wrx's and sti's.
Old 07-10-2009, 12:45 AM   #100
sourcandy
Member#: 212410
Wow... what a huge pain in the ass that was. The only bolts that gave me problems where the 12/14 mm bolts connecting the midpipes, the nuts were pretty much welded to the bolt and they sheared. Honestly the part that gave me the most problems was once everything was undone for the uppipe, actually gettting it out... I raised the engine with wood, but I ended up having to back it out from the top and drop it down by the trans to get the sucker out. I couldn't pull it out from the bottom as other have.
Definatley have a good set of 6 points for this install, and some PB blaster.
It's finally done though!
for the sake of man, and mans best friend. please help seventhsign North West Impreza Club Forum -- NWIC 75 06-25-2009 06:15 PM
Pa. 07 sti uppipe and 02 wrx uppipe project x Engine/Power/Exhaust 4 05-05-2007 08:50 AM
f/s 2004 wrx stock turboback exhaust and stock wrx uppipe Scooby_Wong SCIC Private Classifieds 14 03-05-2007 09:08 PM
FS: TurboXS Uppipe and OEM WRX Uppipe. paper_tiger Private 'For Sale' Classifieds 13 11-04-2005 02:27 PM
What's the update on the "Battle of the Turbos"? Jonathan Kent General Forum Archive 5 08-29-2000 09:29 AM
