Old 08-28-2006, 03:33 PM   #1
alltracin
Member#: 100265
1999 powered '90
Miata
Default Whiteline 27/29 Front bar issue, please help!
Hello,
I am running a 2006 wrx in DS. I have 245/45/17 V710s, the big whiteline front sway bar, spherical bearing adjustable endlinks, and some other non-pertinent mods. At my autocross yesterday the front sway bar "flipped over" during my first run. Meaning...the "horns" of the bar that are meant to be vertical, were horizontal. This also meant the endlinks were horizontal, and the bar became useless. (If anyone still doesn't believe a large bar does wonders, wait until you no longer have any bar at all! understeer heaven) I jacked up on the endlink until the bar, very forcefully flipped back around. Same thing next run. I lengthened my endlinks two turns, and it flipped again, but took longer. Lengthened again, and it took until my third run to flip. I'm assuming if I keep going on the links that it will eventually stop, but then I am running right on the edge, and it could happen at an extremely inconvenient time (read: nationals) Has anyone ever heard of this happening, and if so, what can I do to prevent it?? Thanks,
a very annoyed class winner
alltracin is offline   Reply With Quote
Old 08-28-2006, 03:56 PM   #2
seattle944t
Member#: 18308
2005 WRX STi
Sounds like you have your endlinks too short - if the endlinks are long enough there is no way the front bar can flip, unless there is something different about the 06.
What adjustables do you have?
P.S. I didn't think that adjustable links were allowed in DS, but its been a while since I autocrossed. (looking at the rules - I'd say section 13.7 item A-4 would rule out adjustables)
seattle944t is offline   Reply With Quote
Old 08-28-2006, 04:03 PM   #3
alltracin
Member#: 100265
1999 powered '90
Miata
Interesting. I'll have to check into that further, as that could be a serious problem in about a month if they aren't! oye! I wonder if the bar will still flip with the stock units. And, thanks a bunch for the fast response.
edit: I'm not sure they will be illegal. The strano bar hasn't had an issue and it completely changes the endlink design. Is it just the adjustability factor that you think makes it illegal?
Old 08-28-2006, 04:03 PM   #4
nater
Member#: 105543
1965 Factory Five
Cobra, carbon fiber black
I have the 27/29mm bar on my 06 wrx. How long are your endlinks compaired to the stock endlinks? I have the stock ones on mine, and have never had the bar flip. But it does sound like they are too short...
nater is offline   Reply With Quote
Old 08-28-2006, 04:06 PM   #5
alltracin
Member#: 100265
1999 powered '90
Miata
I initially set them the same length as stock, and have gone longer from there. It doesn't happen with my street tires, so if you aren't running big R-comps I doubt it'll happen for you
Old 08-28-2006, 05:26 PM   #6
alltracin
Member#: 100265
1999 powered '90
Miata
Ok the endlinks are allowed in stock. As I thought. Legnthen them more, got it, thanks
Old 08-28-2006, 07:03 PM   #7
jamesohoh7
Member#: 39070
GTF off my lawn!
keep us posted on the progress. I've never seen a front bar flip either, but I've also never run 710's ( I'm an ST wuss ) ... zany stuff, but I believe all manner of wacky things can happen with really sticky tires. I know a guy who's a-arm was cracked by the Strano bar (and is supposed to be getting resolved there-with)... he is in DS on 710s.
jamesohoh7 is offline   Reply With Quote
Old 08-28-2006, 07:05 PM   #8
alltracin
Member#: 100265
1999 powered '90
Miata
Will do. He's actually broken two, and I race against him fairly regularly Hense why I got the Whiteline, and my own problems! haha
edit: probably a different guy as you're in TX, but same situation
Old 08-28-2006, 07:11 PM   #9
jamesohoh7
Member#: 39070
GTF off my lawn!
yep, in Houston, but yes, sounds like the same kind of issue. I hope they get it fixed up as well!
Old 08-28-2006, 09:53 PM   #10
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
I also have never heard of this and have installed and run many cars with that bar. Very interesting.
Turn in Concepts is online now   Reply With Quote
Old 08-28-2006, 10:22 PM   #11
alltracin
Member#: 100265
1999 powered '90
Miata
I should note that the ripken stadium lot has a lot of elevation change. It upset the car a lot, and I noticed most of the time that it popped, it was while going over a crest.
Old 08-29-2006, 02:21 AM   #12
Impreza01
Member#: 152
2002 Impreza WRX
Ironically, I use Perrin front endlinks, which are shorter at the attachment points than the OEM endlinks. I've never had my bar walk.
Impreza01 is offline   Reply With Quote
Old 08-29-2006, 02:28 AM   #13
WL Flatout
Member#: 35326
Alltracin,
What is the actuall part number of the sway bar that you have fitted to your vehicle ?
Wayne C
WL Flatout is offline   Reply With Quote
Old 08-29-2006, 04:24 AM   #14
STi-MAN
Member#: 70252
05 STI
blue
I've never had an issue of the front bar flipping either... maybe you are running the older 27/29mm bar, which i believe was only compatible with the 04 sti's?
STi-MAN is offline   Reply With Quote
Old 08-29-2006, 04:36 AM   #15
alltracin
Member#: 100265
1999 powered '90
Miata
Originally Posted by WL Flatout View Post
Alltracin,
Wayne C
I'll double check the stamp on the bar when I get home from work.
Old 08-29-2006, 06:17 AM   #16
cr125r
Member#: 104908
2005 Lotus Elise
weird, i have the same bar and endlinks on my 06 and it works great for me. I made the endlinks the same length as stock and have never had a problem. Are you sure the bushings are tight enough as well?
cr125r is offline   Reply With Quote
Old 08-29-2006, 03:07 PM   #17
Scooby921
Thanks Sir Alex!
Member#: 88606
2011 GMC Sierra
1990 Miata
Alltracin,
Wayne C
Judging by the screenname, this is your best option...getting help from the source.
I hope its not a wrong bar...that would be pretty frustrating.
Scooby921 is offline   Reply With Quote
Old 08-29-2006, 06:35 PM   #18
alltracin
Member#: 100265
1999 powered '90
Miata
The bar ends in 33XXZ which is about as much as I couuld read without digging into the car too much. But that's the important part I see, which means it is the right part. Whiteline I'm going to PM you too.
Old 08-29-2006, 06:35 PM   #19
alltracin
Member#: 100265
1999 powered '90
Miata
Are you on R-comps? Mine doesn't flip on street tires.
Old 08-29-2006, 06:45 PM   #20
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
alltracin,
Whose endlinks are you using? I don't see why that should affect the bar into flipping but as far as I know of you are the first to have this happen in any DS Subaru. Do you have the stock endlinks still? Although I can't imagine why the stock ones would do something different I can't think of an alternate solution at this point. I'm quite confused; definitely would like to hear what happens as you progress.
-Biggly
DrBiggly is offline   Reply With Quote
Old 08-29-2006, 07:01 PM   #21
alltracin
Member#: 100265
1999 powered '90
Miata
I have the whiteline spherical bearing adjustables. I still have the stock bar and links. I have a 24 hour event this weekend where I WILL be figuring this problem out, even if it involves putting the stock bar back on
Old 08-29-2006, 08:04 PM   #22
WL Flatout
Member#: 35326
Alltracin,
It appears that you have the correct part number for an 06 WRX sedan.
Is there any chance that you can take a couple of pictures of the swaybar and end-links mounted on the vehicle at normal ride height (from a couple of different angles if possible) and e-mail them to me at wayne@whiteline.com.au , I can then have a good look and see if there is anything noticable that is causing this problem and hopefully come up with a solution for you before your next event.
Cheers
Wayne C
Old 08-29-2006, 08:13 PM   #23
alltracin
Member#: 100265
1999 powered '90
Miata
Will do, but it is dark out now. Tomorrow as soon as I get home from work you'll have mail (about 3:30 Eastern Standard Time)
Old 08-30-2006, 12:05 AM   #24
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
I'll be at the 24hr. If you can replicate the problem there, I'll ride with you and see if I can provide some assistance. In person is always better than on teh internets.
-Biggly
Old 08-30-2006, 05:11 PM   #25
alltracin
Member#: 100265
1999 powered '90
Miata
Wayne, email is sent. Thank you
Biggly, look me up at the 24 hours either way, I'd like to meet you. Just make sure you tell me your forum name or I'll meet you and never know it was you
FS: (OH) Whiteline 27/29 Front Sway Bar loworbitSI Suspension/Brakes/Handling 3 05-29-2009 08:23 AM
Whiteline 27-29mm Front bar question xcdhridr Brakes, Steering & Suspension 7 05-08-2009 07:06 PM
New Whiteline 27/29 Front Swaybar BSF36XXZ UpPweez Suspension/Brakes/Handling 10 04-15-2008 07:43 AM
FS: Whiteline XSF36XXZ 27-29 Front Bar MaxSE03 Suspension/Brakes/Handling 3 01-16-2008 05:41 PM
Zerosports Front Sway Bar issue! PLEASE help! adamsrs Brakes, Steering & Suspension 6 08-13-2004 11:49 PM
Message Board Statistics All times are GMT -4. The time now is 08:36 PM.
