Old 08-28-2006, 05:58 PM   #1
ix8vii
Member#: 77623
0508 STi OBP
0008 Forester S/LLB
Default Racegas
What is the difference between the 100, 103 or 105 unleaded compare to 110 leaded?
ix8vii is offline   Reply With Quote
Old 08-28-2006, 06:36 PM   #2
Sharky NRK
Member#: 29549
2003 WRX
well besides the fact that one is leaded and the others are unleaded they have different octane ratings of 100->103->105->110
consequently they will make more power in that order
Sharky NRK is offline   Reply With Quote
Old 08-29-2006, 04:48 AM   #3
ix8vii
Member#: 77623
0508 STi OBP
0008 Forester S/LLB
Thank you but besides the obvious.
Is 110 advisable to be use with a cat?
Old 08-29-2006, 04:53 AM   #4
hippy
Member#: 36528
2002 Impreza Wrx
Could be wrong, but from what I've hear it's not a good idea to use leaded gas with a cat. It's also said to shorten the life of o2 sensors, and put a nice lead film on the planet(from the exhaust).
peace
Old 08-29-2006, 08:56 AM   #5
Sharky NRK
Member#: 29549
2003 WRX
leaded gas is a definate no with a cat, and a debated no with 02 sensors
Old 08-29-2006, 09:46 AM   #6
ix8vii
Member#: 77623
0508 STi OBP
0008 Forester S/LLB
Thanks guys. Now I'll remember not to even use 110
One last Q, I heard someone use 91 craptane and mixed with 110 to make 95 octane. Is that even possible? I thought 110 are leaded
Old 08-29-2006, 10:10 AM   #7
Sharky NRK
Member#: 29549
2003 WRX
you can mix any 91 with X octane and depending on the ratios get varying octane ratings. I would still stay away from running leaded gas even mixed (just my personal paranoid preference). Run the highest unleaded you can get -> and if you feel so moved mix the craptacular pump 91 with the highest octane unleaded you can find
Old 08-29-2006, 03:05 PM   #8
ix8vii
Member#: 77623
0508 STi OBP
0008 Forester S/LLB
Thanks I like the idea. I can get the 103 or 105 a little cheaper than the 100 octane in a 5 gl pail.
Old 08-29-2006, 03:33 PM   #9
hippy
Member#: 36528
2002 Impreza Wrx
From what I've heard, mixing 91 and 100 unleaded to get 93 is not the same as using 93. The 93 would be 1 fuel, and have the properties of that fuel. The 91/100 mix is just that, a mix. The 91 would still burn faster, and explode easier without a light. Adding a leaded fuel might be different, but I wouldn't know because I'm not sure if the lead compount would effect the 91 or not. To reiterate, as far as I know, 100 octane unleaded along with 91 in equal parts does not make 95.5(<point).
peace
Old 08-29-2006, 04:08 PM   #10
Sharky NRK
Member#: 29549
2003 WRX
^^^^ that is not quite what I have heard, but I am not an expert. I do know that adding 100 octane to 91 will in fact give you more detonation resistance and I have experienced it. Whether if is 95.5 or 93 or 97 I do not know, but mixing will increase the knock index of the fuel according
Old 08-29-2006, 04:13 PM   #11
hippy
Member#: 36528
2002 Impreza Wrx
That was my point. I don't think people get the octane equivalent they think they'd get from a given mixture. Not saying that adding 100 octane to 91 doesn't help, but it's like water injection in the way that the 100 octane seperates the 91 up more, and cools it down more then it would normally be cooled, and stops a lot of it from being lit quickly, but it's still 91 octane in there.
peace
Old 08-29-2006, 04:39 PM   #12
Sharky NRK
Member#: 29549
2003 WRX
peace
agreed
Old 08-29-2006, 04:48 PM   #13
Ultimate Collision Center
Member#: 69072
i can attest to the blown o2 sensors due to race gas, if you use it enough they will go bad and are quite costly to replace, its the main reason i switched to methanol...
Ultimate Collision Center is offline   Reply With Quote
Old 08-29-2006, 04:58 PM   #14
Sharky NRK
Member#: 29549
2003 WRX
^^^^ race gas or leaded race gas
Old 08-29-2006, 05:09 PM   #15
Member#: 69072
sorry I meant to write leaded race gas (I used to use c16 like it was my job haha)
Racegas in Akron, OH q2brass General Community 3 08-11-2005 07:32 PM
Chicagoland racegas locations stefano Mid West Subaru Owners Club Forum -- MWSOC 11 02-19-2005 11:11 AM
HR Area: Where to buy C16 Racegas jetskizero Mid Atlantic Impreza Club -- MAIC 10 11-02-2004 09:00 PM
Vishnu Stage 2 STi dynosheet 91 octane and racegas pio!pio! Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 09-10-2004 01:42 PM
Going lapping, want a bit of racegas to increase det prevention Turbo Tin Can Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-01-2003 12:56 PM
